Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
21 registered members (bbhero, 2015Corolla, dishdude, Aero540T, Char Baby, Exhaustgases, 1 invisible), 776 guests, and 38 spiders.
Topics295,007
Posts4,925,890
Members66,664
Most Online2,553
Oct 27th, 2018
CV axle seal...part 3? Ugh #4586976
11/27/17 07:53 PM
11/27/17 07:53 PM
WI
HoosierJeeper Offline OP
WI
Couple weeks ago I replaced the driver's side CV axle seal on my Liberty. Leaked again. Figured out it was because I didn't pack the back of it with grease and the metal "rubber band" thing got deformed and I also stupidly pounded on the inner lip. Took it back out, put a new seal in and back the whole back of it, the seal around the CV shaft and then the part that touches the diff with this stuff...basically anything rubbery I coated with this.
https://www.summitracing.com/parts/lbg-1...wgaAietEALw_wcB
Drove it for about a week, no leaks. Perfect! Checked it today and there was a blue drip. Ugh. Felt waxy. I'm assuming it's just the excess assembly lube that was outside the seal working itself out? I figure that stuff has a low melting point so it's not permanent.
Think I screwed up again?
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: CV axle seal...part 3? Ugh [Re: HoosierJeeper] #4587065
11/27/17 09:36 PM
11/27/17 09:36 PM
NY, USA, etc.
oilpsi2high Offline
oilpsi2high  Offline
NY, USA, etc.
The axle shaft that goes through the seal could be scored and allowing fluid to leak, even with a new seal.
I have a car that is like this. I would replace the seal and it kept leaking because the CV shaft was scored.
I resorted to just topping up the trans fluid at oil changes, but recently noticed the axle was starting to leak from the boot, so I finally ordered new axles and seals to go along with them.
Re: CV axle seal...part 3? Ugh [Re: HoosierJeeper] #4587071
11/27/17 09:51 PM
11/27/17 09:51 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
How is the surface that the flange presses up against ? If that surface is damaged, you'll have a leak.
Re: CV axle seal...part 3? Ugh [Re: HoosierJeeper] #4587225
11/28/17 06:24 AM
11/28/17 06:24 AM
WI
WI
The CV shaft is 6 months old (no damage on it, looks/feels new) and the diff isn't scratched/marred at all. There's no play in the CV at all.
Re: CV axle seal...part 3? Ugh [Re: HoosierJeeper] #4587240
11/28/17 06:48 AM
11/28/17 06:48 AM
WI
WI
I just don't understand how it can be fine for a week/100-150 miles (whereas the first time I replaced it, it leaked instantly upon driving it).
Re: CV axle seal...part 3? Ugh [Re: HoosierJeeper] #4587300
11/28/17 08:19 AM
11/28/17 08:19 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
That stuff is designed to melt into the transmission fluid, its harmless and doing pretty much what its supposed to. I doubt you have an issue.
Re: CV axle seal...part 3? Ugh [Re: HoosierJeeper] #4588541
11/29/17 09:01 AM
11/29/17 09:01 AM
WI
WI
Here's a pic of the seal, I colored in the areas I put the grease on. I put it all around the outer part but didn't shade the whole thing so I didn't clutter up the pic too much.
I guess my thinking is that grease might take a while to melt. Since a diff probably doesn't get all that warm (at least doing shorter trips and in cooler weather), I'm thinking it might be a while before it all comes out. I'm just concerned what I'm seeing come out is from inside, but I guess there's no real way of knowing that.
