Nissen Radiator Warning.
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
140 registered members (01rangerxl, 4WD, 2015_PSD, 92saturnsl2, 02z, 928, 18 invisible), 2,002 guests, and 53 spiders.
Topics286,087
Posts4,902,326
Members67,560
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Opinions on this mix/blend? #4586374
11/27/17 09:46 AM
11/27/17 09:46 AM
New England
jdavis Offline OP
jdavis  Offline OP
New England
I'm trying to come up with a middleish weight 30 weight and have a 5qt jug of M1 0w-40 FS (GTL version).
I'm thinking about buying 3 quarts of PPPP 0w-20 (GTL version D1G1 which is high calcium no mag like M1).
3 quarts of each making a 6 qt blend, what's your thoughts? Both are GTL, both have high calcium, no mag, etc.
Re: Opinions on this mix/blend? [Re: jdavis] #4586384
11/27/17 09:58 AM
11/27/17 09:58 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
IMO it's not good to mix chemistries of oils. Not because impending harm will come to your engine but you might not get the same performance characteristics out of the blend that you would with one oil. You would be better off looking at the data sheets to find the middle weight in an oil and go with that only.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Opinions on this mix/blend? [Re: jdavis] #4586390
11/27/17 10:04 AM
11/27/17 10:04 AM
New England
jdavis Offline OP
jdavis  Offline OP
New England
I hear ya, just looking to use the M1 rather than throw it out..
Re: Opinions on this mix/blend? [Re: jdavis] #4586399
11/27/17 10:09 AM
11/27/17 10:09 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
What engine would this being going in and what's it rated for now?
Re: Opinions on this mix/blend? [Re: jdavis] #4586405
11/27/17 10:17 AM
11/27/17 10:17 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
From some of the mixes I've seen around here, yours actually makes sense with similar chemistry. Such blending in New England weather poses less risk in the spring-fall since you aren't worried so much on the oil mix works at the low viscosity end of the spectrum.
If the car weren't anything special I'd be mixing those same oils if I wanted to use up the M1. Ideally, an OCI less than what either oil can normally do.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Opinions on this mix/blend? [Re: jdavis] #4586408
11/27/17 10:19 AM
11/27/17 10:19 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
People do "franken-brews" all the time - I have NEVER heard of a single negative outcome.
Re: Opinions on this mix/blend? [Re: jdavis] #4586412
11/27/17 10:20 AM
11/27/17 10:20 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: jdavis
...just looking to use the M1 rather than throw it out.
What person who isn't clinically insane throws away an item of great value?
Re: Opinions on this mix/blend? [Re: StevieC] #4586420
11/27/17 10:27 AM
11/27/17 10:27 AM
New England
jdavis Offline OP
jdavis  Offline OP
New England
LGX (in trucks) LGZ (in cars) 3.6 calls for 5w-30 normally, probably fine to run straight 0w-40 m1 in it, just not sure how much it would affect mileage..
Re: Opinions on this mix/blend? [Re: Linctex] #4586421
11/27/17 10:27 AM
11/27/17 10:27 AM
New England
jdavis Offline OP
jdavis  Offline OP
New England
Yeah, I wouldn't throw it out, it'd get used in something smile
Re: Opinions on this mix/blend? [Re: jdavis] #4586422
11/27/17 10:28 AM
11/27/17 10:28 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
You need 6 quarts ~ use the whole jug and one quart ... quarts are expensive unless grabbed on clearance …
That is not a thicker 40 to start with … I run it in our Cruze now …
Re: Opinions on this mix/blend? [Re: jdavis] #4586428
11/27/17 10:31 AM
11/27/17 10:31 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Run it in the summer as it is, you will be fine. smile
Re: Opinions on this mix/blend? [Re: jdavis] #4586621
11/27/17 02:32 PM
11/27/17 02:32 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Just sub 1 qt out of your sump with the 40 in spring through fall
Everytime ive done a dumbbell blend its never been good.
evertime ive added a 40 to a 30 its been all gravy, Davey!
throw out euro 40 ? Nuts! Throw out the junk ILSAC GF
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Opinions on this mix/blend? [Re: Linctex] #4586673
11/27/17 03:15 PM
11/27/17 03:15 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Here you go
http://papers.sae.org/932831/
I personally think its' likely that most of us don't push the extremes of the "W" rating that we hear of relatively few.
The linked SAE papers, the oils gelled at comparatively "normal" temperatures due to VII/PPD interaction between the factory fill residual and the service fill.
Re: Opinions on this mix/blend? [Re: jdavis] #4586760
11/27/17 04:37 PM
11/27/17 04:37 PM
5600 feet elevation, Arizona
double vanos Offline
I wouldn’t have the first thought about using it in anything ‘round here. Might cut the OCI interval a little short tho...
Someone here once opined that if your heart meds clash, you die. If your oil add packs clash, you wind up with 10 more ppm Fe in your UOA...
Blend on brother, blend on!
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Opinions on this mix/blend? [Re: jdavis] #4586763
11/27/17 04:41 PM
11/27/17 04:41 PM
New England
jdavis Offline OP
jdavis  Offline OP
New England
Wouldn't it make sense to use it up in an oil change soon as it's a 0w? Why wait until summer to do the 0w-40 run?
Page 1 of 3 1 2 3
