Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
35 registered members (Aero540T, 69Torino, 2strokeNorthstar, 4WD, 1WildPig, Anduril, 1 invisible), 1,049 guests, and 38 spiders.
Topics295,135
Posts4,928,342
Members66,691
Most Online2,553
Oct 27th, 2018
Camshaft Profile Question #4586246
11/27/17 03:07 AM
11/27/17 03:07 AM
Toronto, Canada
George7941 Offline OP
Toronto, Canada
I did a valve clearance adjustment on a Caterpillar C7 inline 6 truck engine. Firing order is 153624. I thought I had the engine at TDC at the end of the exhaust stroke for cyl 1 to adjust 1I&E, 2I, 3E, 4I and 5E. I found out later that I had not turned the engine over enough, the engine was only half way through its exhaust stroke and I was off by 90 deg/quarter turn. Similar situation for the second half of the valve adjustment when I thought I had TDC for cyl 6.
Do I need to pull the valve cover off again and recheck? Engine sounds normal now with no clatter indicating excessive lash.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Camshaft Profile Question [Re: George7941] #4586250
11/27/17 03:17 AM
11/27/17 03:17 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You might be fine, butt he ONLY way to be sure is check the valve lash again.
Trust, but verify.
Re: Camshaft Profile Question [Re: George7941] #4586261
11/27/17 04:24 AM
11/27/17 04:24 AM
New Zealand
Silk Online content
Silk  Online Content
New Zealand
Setting valves by the TDC method is too troublesome - set them on the back of the cam...so when No6 inlet is wide open, set No1 inlet, and so on. You can still set 2 valves at once because there will always be another valve nearly fully open. If you get confused, mark each valve you set.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Camshaft Profile Question [Re: George7941] #4586320
11/27/17 07:23 AM
11/27/17 07:23 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I would absolutely 're check the lash.
I learned how to lash valves quickly and easily from a friend who used to crew a fuel funny car. The method works on any 4 cycle engine.
Start on cylinder #1 rotate the engine until the exhaust valve just starts to open, once the exhaust valve just starts to open, adjust the intake valve on the same cylinder.
Continue to rotate the engine over, once the intake valve has fully opened and just starts to close, adjust the exhaust valve on that cylinder.
Now cylinder #1 is done.
Repeat process for the remaining 5 cylinders.
The beauty of this method is that it works regardless of firing order and you can start on any cylinder. It's how I've lashed valves for at least 20 years now.
Luke
Re: Camshaft Profile Question [Re: George7941] #4586492
11/27/17 11:12 AM
11/27/17 11:12 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Re- check. It isn't the noisy ones that burn.
Thick oil is better grin2
Re: Camshaft Profile Question [Re: FlyNavyP3] #4586649
11/27/17 02:01 PM
11/27/17 02:01 PM
New Zealand
Silk Online content
Silk  Online Content
New Zealand
That's how I do single cyls, if I can't see the cam itself. But apart from triples and V twins, multi cyl engines will have one cyl 360 degrees firing from another cyl, so these ones are easy to do with the valve opening method - just so much easier to flick the engine over on the starter, see a valve fully open and adjust it's opposite number.
Re: Camshaft Profile Question [Re: Silk] #4586768
11/27/17 03:48 PM
11/27/17 03:48 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Originally Posted By: Silk
... But apart from triples and V twins, multi cyl engines will have one cyl 360 degrees firing from another cyl, so these ones are easy to do with the valve opening method -...
Apart from 5-cylinder engines, too.
2011 Toyota Prius now at 94K
Re: Camshaft Profile Question [Re: George7941] #4586830
11/27/17 05:29 PM
11/27/17 05:29 PM
New Zealand
Silk Online content
Silk  Online Content
New Zealand
7, 9, 11.....
Re: Camshaft Profile Question [Re: andyd] #4586964
11/27/17 07:43 PM
11/27/17 07:43 PM
Toronto, Canada
Toronto, Canada
Thanks for all the feedback. I will recheck valve lash.
No risk of burning from my error. There is a possibility of excessive lash, no risk at all of insufficient lash.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Camshaft Profile Question [Re: George7941] #4587114
11/27/17 10:56 PM
11/27/17 10:56 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have always used charts very similar to this one:
Re: Camshaft Profile Question [Re: Linctex] #4587164
11/28/17 02:42 AM
11/28/17 02:42 AM
Toronto, Canada
Toronto, Canada
Oops! I made a mistake in my original post. It should have been "I thought I had the engine at TDC at the end of the COMPRESSION stroke for cyl 1---".
Linctex's chart shows the exact way I did it.
1987 BMW R80 - sold
2015 Honda CBR300R
