Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
27 registered members (BenZahel, Bjornviken, Bama, BigRich954, chance, 4 invisible), 828 guests, and 46 spiders.
Topics295,092
Posts4,927,668
Members66,684
Most Online2,553
Oct 27th, 2018
Honda CR-Z Valvetrain Pictures and GE8 Transplant #4586232
11/27/17 01:26 AM
11/27/17 01:26 AM
TN
HX520W Offline OP
HX520W  Offline OP
TN
I recently helped replace the stock camshaft and rocker assembly in the CR-Z with junkyard parts from a GE8 Fit that had 19,000 miles on it. Unlike the CR-Z, the GE8 Fit fully opens both intake valves regardless of RPM. The GE8 camshaft also uses higher lift and duration intake cam lobes and has a separate cam lobe on it that is only used during VTEC.
The differences between the two camshafts can be seen here.
The CR-Z was purchased used with about 17,300 miles on it and has about 52,300 miles on the odometer now. The car also spends three to four weekends a year at track days and has accumulated over 1,300 miles of use on the racetrack. Low-end torque has definitely improved with the new parts. We'll really know how much of an improvement it's made at the next track day.
The engine has mostly used Castrol Edge since it was purchased. It's been running 0W-20 in the winter and 10W-30 in the summer.
Here it is with the new cam and rocker assembly installed. All the casting marks were removed from the rockers and the valve adjustment screw lock nuts were replaced with titanium ones to reduce strain on the assembly.
Re: Honda CR-Z Valvetrain Pictures and GE8 Transplant [Re: HX520W] #4586236
11/27/17 02:05 AM
11/27/17 02:05 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
The rocker setup appears to save a lot of space and make for a very narrow top end.
Re: Honda CR-Z Valvetrain Pictures and GE8 Transplant [Re: HX520W] #4586369
11/27/17 08:42 AM
11/27/17 08:42 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
How did you get the power vtec to work on the crz?
I had a Fit sport 5M with my previous commuter. Would be a semi-hoot on a 300lb diet, but its no Fiat 128.
IIRC It does fully open both valves, but has an aggressive powerlobe (using VTEC) in the intake that seems to come in around 4500 or so rpm depending on load. As an engineer I poopoo the L shaped Intake rockers that will add a significant rotating moment to the rockershaft bearing. Almost elegant due to compactness but BAD engineering.
Car was an O.K. buy for 13Kmax NEW but not for 18K. Let down by mushy Garbage-bin strut front suspension with the wimpiest components. Def not a handler like the old 80's and 90's Civic with a proper SLA front suspension.
I will say Again, S.Honda-san is roiling in his grave over the fat boring pigs his subcompact cars have become.
Such price "safety".
here's a HONDA TSB (PDF) on lost motion springs:
I guess not.. Wont allow.
synopsis:
HONDA Service Bulletin 11-010
Feb 19 2011
Safety Recall: Lost Motion Springs
BACKGROUND
The lost motion springs in the engine's variable valve
timing and lift electronic control (VTEC) may break. In
rare cases, the broken pieces of the lost motion spring
may jam the rocker arm and cause the engine to stall
and prevent it from being restarted. An engine that
stalls while driving increases the risk of a crash.
VEHICLES AFFECTED
2009 Fit
FromVIN JHMGE8...9S000027
thru JHMGE8...9S075923
FromVIN JHMGE8...9C000005
thru JHMGE8...9C007783
2010 Fit
FromVIN JHMGE8...AC000001
thru JHMGE8...AC013589
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Honda CR-Z Valvetrain Pictures and GE8 Transplant [Re: ARCOgraphite] #4587083
11/27/17 10:07 PM
11/27/17 10:07 PM
TN
HX520W Offline OP
HX520W  Offline OP
TN
Both the CR-Z and GE8 Fit have the same VTEC solenoid, so all we needed to do was program the ECU to make it have the same VTEC window as the Fit (3,500-5,400 RPM).
The CR-Z handles quite well (especially with all the chassis bracing that it has now) and is very good under braking. The car has surprised quite a few driving instructors.
Thanks for the heads-up on the TSB, I wasn't aware of that potential issue. Looks like I got lucky, the rocker bridge that I have was made 7/05/2012.
