Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
The Beater is Even Uglier Now!
by Delta. 03/19/19 08:28 AM
Oil viscosities at 200 to 225 F
by Snagglefoot. 03/19/19 07:35 AM
What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
jmd, alexislaborda, tbann, LisaMC, chops
67556 Registered Users
108 registered members (aircooled, AirBull, Arminius, Astro14, bfleeman, b1amgm47, 11 invisible), 2,215 guests, and 58 spiders.
Topics286,067
Posts4,901,918
Members67,556
Most Online2,967
Mar 10th, 2019
Proper Generator Shut Down #4586078
11/26/17 09:05 PM
11/26/17 09:05 PM
California
SavagePatch Offline OP
California
For a generator that's only used during power outages and is stored the rest of the time what is the proper way to shut them down?
Turn the key to OFF and kill it or turn the fuel cock off and let it starve and die?
Thanks in advance!
Fuel tank is 5g capacity and filled with Chevron 91 w/ Stabil 360 additive.
Re: Proper Generator Shut Down [Re: SavagePatch] #4586083
11/26/17 09:11 PM
11/26/17 09:11 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
If you're not going to empty the tank let the generator run it dry.
2004 Corolla 129892
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Proper Generator Shut Down [Re: SavagePatch] #4586085
11/26/17 09:12 PM
11/26/17 09:12 PM
California
MadAmos Offline
MadAmos  Offline
California
Fuel off let it run till it starts to die then full choke to empty the carb.
2000 Ford F250 7.3
1999 Miata
2014 Cadillac ELR
2017 Cruze RS Hatchback 6MT
Re: Proper Generator Shut Down [Re: SavagePatch] #4586095
11/26/17 09:19 PM
11/26/17 09:19 PM
Kalifornia Kollective
BrocLuno Online content
BrocLuno  Online Content
Turn fuel off and let it die on it's own. I would not use choke as if fuel there, will go rich and wash cylinder walls ...
Re: Proper Generator Shut Down [Re: MadAmos] #4586106
11/26/17 09:38 PM
11/26/17 09:38 PM
NJ
Padawan Offline
Padawan  Offline
NJ
This is the procedure I follow, except I gradually engage the choke to keep it running as smoothly as possible as the carb empties.
Re: Proper Generator Shut Down [Re: SavagePatch] #4586112
11/26/17 09:42 PM
11/26/17 09:42 PM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
I do the same thing. It's served me well for the last 16 years with my Subaru Generator. Never a carb problem. Choke increased carefully at the last minute to keep it running. It eventually goes lean and dies, so no risk of washing cylinder walls on shutdown.
Re: Proper Generator Shut Down [Re: SavagePatch] #4586113
11/26/17 09:42 PM
11/26/17 09:42 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
I have a 5KW Powermate with a Subaru engine. In between runs I use Sta-Bil and shut the engine down by turning off the fuel valve. The gen is 10 years old and it starts on the second or third pull after every 3-4 month run.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 65K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Proper Generator Shut Down [Re: SavagePatch] #4586174
11/26/17 11:02 PM
11/26/17 11:02 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
This is how I do things.
If it has a metal tank, I store it completely full with non-ethanol fuel and Stabil to prevent the tank from rusting. Turn the petcock, and run the engine until it dies.
If it has a plastic tank, I store it empty, and let the engine run until it dies.
About every 3 months, I'll pull my generator out of storage, and run it for about 45 minutes with a portable 1500 watt heater plugged into it to exercise it. It always starts on the first pull. I change the oil every two years in these conditions, UNLESS I have to actually use it, in which case I change the oil every 50 hours (no oil filter).
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Proper Generator Shut Down [Re: Padawan] #4586251
11/27/17 04:19 AM
11/27/17 04:19 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes, same here.
Once it stumbles for sure, go ahead and hit the "off switch" so the automatic voltage regulator doesn't try to keep up as RPM falls off.
Re: Proper Generator Shut Down [Re: MadAmos] #4586260
11/27/17 05:12 AM
11/27/17 05:12 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
AND drain the tank of gas...
The "thinking" man's friend.
Re: Proper Generator Shut Down [Re: SavagePatch] #4586281
11/27/17 06:34 AM
11/27/17 06:34 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I run our back-up generator a couple times a year. (Fall, Spring) I always turn off the fuel and let it run to a stop this way. Never had to take the carb apart yet and I'm using E-10 with no fuel additive.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Proper Generator Shut Down [Re: Lubener] #4586465
11/27/17 11:26 AM
11/27/17 11:26 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I like to turn the valve off and keep the tank full.
Re: Proper Generator Shut Down [Re: SavagePatch] #4586871
11/27/17 07:20 PM
11/27/17 07:20 PM
Canada
boraticus Offline
boraticus  Offline
Canada
With my Yamaha EF2000is inverter generator I just turn off the fuel valve, run the carb dry and leave it for the winter. Going on my 5th year and so far, no issues with starting in the spring. One year I forgot to drain the carb and the float stuck in the closed position. Had to tap the float bowl a couple times to get it to drop.
Re: Proper Generator Shut Down [Re: SavagePatch] #4587259
11/28/17 08:25 AM
11/28/17 08:25 AM
Illinois
javacontour Offline
javacontour  Offline
Illinois
Whatever technique you choose, remove the load before you shut it down. Otherwise, it may damage the generator or anything plugged in.
network down, IP packets delivered via UPS -BOFH
Re: Proper Generator Shut Down [Re: javacontour] #4588225
11/28/17 11:30 PM
11/28/17 11:30 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
+1. A must.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
