New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
30 registered members (Ablebody, Bjornviken, BlakeB, Ag76, 5 invisible), 852 guests, and 38 spiders.
Topics290,744
Posts4,849,442
Members66,033
Most Online3,590
Jan 24th, 2017
What is causing my roof to droop? #4585856
11/26/17 05:40 PM
11/26/17 05:40 PM
FL, USA
gregk24 Offline OP
gregk24  Offline OP
FL, USA
As you can see from the picture, the roof over my carport is sagging. Many of the houses in my neighborhood (most built in the 50's) are the same way. What causes this and do you think its a problem or just cosmetic? I was up on the roof putting up Christmas lights a week ago and it did NOT feel soft or bouncy walking on it.
2012 Honda Accord EX-L K24z3
54,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
40,xxx miles
Castrol OEM dealer fill / OEM filter
Re: What is causing my roof to droop? [Re: gregk24] #4585870
11/26/17 05:48 PM
11/26/17 05:48 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Are you able to get into that attic section of the roof to see the structure? Could.be joists shifting or plywood getting soft. Or is the sheathing thsoe strips of wood that they used to use a long time ago?
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: What is causing my roof to droop? [Re: JC1] #4585874
11/26/17 05:51 PM
11/26/17 05:51 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
I agree, no way of knowing unless somebody is looking what is going on underneath.
May be the underlayment board broke or the supporting wood broke.
They are not designed to last for 60 years.
  • 2017 Toyota Sienna
Re: What is causing my roof to droop? [Re: gregk24] #4585899
11/26/17 06:10 PM
11/26/17 06:10 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Built in the 50's, I'm going to guess that it is conventional rafter design (vs. trusses). That it is happening only over the car port is your first good clue. I would look at the front and back fascia areas to see if they look pushed out a tiny bit, allowing the ridge to sag. My guess is that they continued the same roof design over the car port that they used on the rest of the house. But, the car port has almost nothing (no front/side/center bearing walls) supporting and holding the rafter system together as the "locked together" unit it is designed to be. Or, maybe that HUGE joist span over the car port is just too long. Look for sagging joists too, which would allow the ridge to sag.
An inspection by a trustworthy builder would reveal the root cause. Since you have no snow load in Florida, and if their are no major structural deficiencies (i.e., cracked ridge board, etc.), it might be just a cosmetic thing. There are sagging roofs that have lasted for centuries.
Re: What is causing my roof to droop? [Re: gregk24] #4585930
11/26/17 06:45 PM
11/26/17 06:45 PM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
I don't like all that weight only supported by two steel poles.
A roofer has a better idea and knowledge of why your roof is lower.
Re: What is causing my roof to droop? [Re: gregk24] #4585938
11/26/17 06:52 PM
11/26/17 06:52 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Where are your roof vents?
Also, how much insulation is under that roof and is any insulation-roll attached directly to the inside of the roof - between the beams?
She's the only sister-in-law I have. But she's not my favorite.
Re: What is causing my roof to droop? [Re: gregk24] #4585951
11/26/17 07:05 PM
11/26/17 07:05 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Best would be to get a structural engineer. They might be $80 per hour and he should be able to examine the roof and write a report in 2-3 hours. But he will need to get into the attic area to look.
Roof trusses are engineered and so they should not be a problem assuming no insect or water damage. I spent my college summers building way too many roof trusses, using massive machines to press the plates into the wood.
2015 Ford F250 w/Powerstroke
Re: What is causing my roof to droop? [Re: gregk24] #4585985
11/26/17 07:39 PM
11/26/17 07:39 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Gravity
Re: What is causing my roof to droop? [Re: gregk24] #4585997
11/26/17 07:47 PM
11/26/17 07:47 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Not enough of a collar tie on the rafters. Looks easy to fix though. Put a couple of A shores up under the fascia to carry rafters and ceiling joists put a couple A shores at half span of the ceiling Jack up shores an inch above where they were. Install collar ties or a W tying a rafter to to a ceiling joist.
Thick oil is better grin2
Re: What is causing my roof to droop? [Re: gregk24] #4586002
11/26/17 07:58 PM
11/26/17 07:58 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
If built in the 50's, then odds are it was stick framed. What's the distance, front-to-back?
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: What is causing my roof to droop? [Re: gregk24] #4586024
11/26/17 08:20 PM
11/26/17 08:20 PM
New England
madRiver Offline
madRiver  Offline
New England
Plenty of homes around here with similar roofs. However built between 1690 to 1850 and it simply adds character.
Re: What is causing my roof to droop? [Re: Ducked] #4586057
11/26/17 08:39 PM
11/26/17 08:39 PM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
Originally Posted By: Ducked
Gravity
And entropy. Maybe with some termites adding to the molecular chaos.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: What is causing my roof to droop? [Re: gregk24] #4586059
11/26/17 08:40 PM
11/26/17 08:40 PM
Soviet State of Washington
PimTac Offline
PimTac  Offline
As suggested already, you or someone needs to get up into the attic. There are a lot of causes for a sagging roof and since you are in Florida the first thing I thought of was termites. A visual inspection is needed.
Also check your storage room too. Does the door open smoothly? Any signs of settling?
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: What is causing my roof to droop? [Re: gregk24] #4586092
11/26/17 09:16 PM
11/26/17 09:16 PM
Utah
CKN Offline
CKN  Offline
Utah
You can start with a roofer-then a structural engineer-if needed.
Re: What is causing my roof to droop? [Re: gregk24] #4586093
11/26/17 09:17 PM
11/26/17 09:17 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
The steel poles are good for like 10,000 each as long as kept "in column". The sag is not effective collar ties.
Jack up the center +1" in the middle. Install some 2x6 collar ties from rafter to rafter and let it settle. Use modern self tapping screws and some good PL8X on the faces to be joined. Should come out pretty straight smile
