CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
61 registered members (antik, 87sammy, Anthony, 2015_PSD, A1O, 7 invisible), 735 guests, and 27 spiders.
Topics287,674
Posts4,932,035
Members67,838
Most Online2,967
Mar 10th, 2019
Seized set screw removal #4585603
11/26/17 02:17 PM
11/26/17 02:17 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
On 1920s-ish hardware on a same age door.
Knobs were loose, but set screw was stuck. Someone long ago already stripped the screw thread, so Ive tried to remove it.
Kroil, ATF, etc don't help. I assume there's a combo of human oils, chemical bonding, etc.
Going to break the extractor if I try any harder.
So what's next??
Re: Siezed set screw removal [Re: JHZR2] #4585608
11/26/17 02:21 PM
11/26/17 02:21 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Drill it out.
Re: Siezed set screw removal [Re: JHZR2] #4585626
11/26/17 02:38 PM
11/26/17 02:38 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
Pardon my ignorance, isn't that what I did?
I used a #2 extractor with a hole pre drilled. Used a slightly undersized hole so the extractor had more bite and less chance to bottom out.
A shallow extractor bites but distorts the brass around the screw vs removing it. Ask how I know frown
New set screw will be 1/4-20, are you implying to just drill and tap as is?
Re: Siezed set screw removal [Re: Warstud] #4585633
11/26/17 02:46 PM
11/26/17 02:46 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Originally Posted By: Warstud
Drill it out.
I agree.
To answer your follow on question I think what Warstud was saying and what I'm suggesting is to drill the set screw in your drill press as you end already done for the tap drill size for the size of the set screw, then tap and use a new set screw. No need to go over size from original, just make new threads.
Luke
Re: Siezed set screw removal [Re: JHZR2] #4585640
11/26/17 02:50 PM
11/26/17 02:50 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That's the wrong kind of extractor. What those kind do is exert outward force on the fastener as you turn it to the left. Counterproductive is the word I use to describe those kind of extractors.
Re: Siezed set screw removal [Re: JHZR2] #4585643
11/26/17 02:52 PM
11/26/17 02:52 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Back that extractor out before it snaps. Continue to drill going up in size gradually until there is no screw left. Then tap, I would use the smallest over size possible. a 10-32, 12-24 3/16? I'm surprised you don't have a set of left hand bits. Not that I've had any success with my LH index grin2
Thick oil is better grin2
Re: Siezed set screw removal [Re: JHZR2] #4585673
11/26/17 03:21 PM
11/26/17 03:21 PM
Southeastern, PA
Rick in PA Offline
Rick in PA  Offline
Southeastern, PA
I'd keep up-sizing the drills gradually. If you get lucky, the threads on the old set screw can be picked out like a spring. I've seen it done. Then clean up the threads on the door knob with a tap of the same size threads and you're good-to-go.
That was a popular style door knob. We have the same ones in our house.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
Re: Siezed set screw removal [Re: Merkava_4] #4585689
11/26/17 03:47 PM
11/26/17 03:47 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
Yup, observed that, though from one of the "seen on tv" types HD sells. Thought a more aggressive taper (get fatter in shorter distance) was good given that I can't get the rod out.
The brass gave easily as a result.
So what is the better kind of extractor. For me and for this sort of a job I certainly don't mind paying good money upfront to have the right tool and do a proper job with minimal hang ups.
I like DIY and on Sunday my time isn't money, but I don't care to waste my day if there's a better tool.
Re: Siezed set screw removal [Re: andyd] #4585692
11/26/17 03:48 PM
11/26/17 03:48 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
Don't have left hand bits. But then again, my 1950s dp is one way only smile
Re: Siezed set screw removal [Re: Rick in PA] #4585725
11/26/17 04:08 PM
11/26/17 04:08 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Exactly - it just takes time, precision.... and a LOT of patience.
It saves the original threads.
Re: Siezed set screw removal [Re: JHZR2] #4585729
11/26/17 04:10 PM
11/26/17 04:10 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
this kind:
Re: Siezed set screw removal [Re: JHZR2] #4585746
11/26/17 04:26 PM
11/26/17 04:26 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
Is there a name for those?
Even snap on seems to be selling spiral/multi-spline types.
Re: Siezed set screw removal [Re: JHZR2] #4585865
11/26/17 05:46 PM
11/26/17 05:46 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
Drilled out to #7 then tapped to 1/4-20. Success.
It was crooked, not sure how I could do that better - I was a bit sensitive to clamping the handle in a vice.
Re: Siezed set screw removal [Re: JHZR2] #4585891
11/26/17 06:03 PM
11/26/17 06:03 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Very nice work and fix sir smile
Re: Siezed set screw removal [Re: JHZR2] #4585892
11/26/17 06:05 PM
11/26/17 06:05 PM
out there
spasm3 Offline
spasm3  Offline
out there
Nice work! I would not have clamped it in a vise either. Crooked won't matter for that, with the set screw in, you will never know.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
