March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
129 registered members (albenjoseph, 92saturnsl2, 928, 4WD, 77GrandPrix, 01rangerxl, 10 invisible), 2,010 guests, and 51 spiders.
Topics286,086
Posts4,902,290
Members67,560
Most Online2,967
Mar 10th, 2019
Oil for new snowblower #4585602
11/26/17 02:17 PM
11/26/17 02:17 PM
ma
NHRATA Offline OP
NHRATA  Offline OP
ma
I picked up a new snowblower this year. After my 5 hour break in. I plan on dropping the oil and putting in synthetic 5w 30. My dealer told me I should stay away from standard Automotive oils and use a good four cycle synthetic oil such as Briggs & Stratton, Amsoil or a few of the others that are intended for small engines. Is their suggestion a valid one? They said something about today's oil being intended for vehicles that are liquid cooled that have catalytic converters.
Re: Oil for new snowblower [Re: NHRATA] #4585623
11/26/17 02:36 PM
11/26/17 02:36 PM
NEUS
Bandito440 Offline
Bandito440  Offline
NEUS
Just avoid energy-conserving oils. Castrol 0w-30, 0w-40, or Mobil 1 0w-40 are easy enough to come across.
I use Rotella T6 5w-40 in mine, because it goes in the Jeep too.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: Oil for new snowblower [Re: NHRATA] #4585650
11/26/17 03:00 PM
11/26/17 03:00 PM
MN
TmanP Offline
TmanP  Offline
MN
I use M1 AFE because it's the easiest-to-find 0w30 around me. No problems with it in a ~8 year old MTD. But realistically any 5w30, even conventional, would suffice.
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: Oil for new snowblower [Re: NHRATA] #4585698
11/26/17 03:52 PM
11/26/17 03:52 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Does it have OHV if so a standard automotive oil will be fine. If it's not OHV then I would suggest a higher ZDDP oil or something like Amsoil 4-Stroke, B&S small engine oil etc.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Oil for new snowblower [Re: NHRATA] #4585709
11/26/17 03:59 PM
11/26/17 03:59 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: NHRATA
My dealer told me I should stay away from standard Automotive oils and use .... a few of the others that are intended for small engines.
No..... not one tiny bit.
Re: Oil for new snowblower [Re: StevieC] #4585712
11/26/17 04:00 PM
11/26/17 04:00 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
There is no basis for this decision.
Last generation "flathead" Briggs engines used a PLASTIC camshaft!!! (springs pressures are like, 20lbs...)
No need for ZDDP in nearly any part of a flathead engine.
Re: Oil for new snowblower [Re: NHRATA] #4585750
11/26/17 04:29 PM
11/26/17 04:29 PM
Cave City KY
jakewells Offline
jakewells  Offline
Cave City KY
any 5w30 will work fine even 0w30.
1994 Ford F150 302 4R70
Chevron Delo SAE 30 CF/SL Fram XG8A
1978 Chevy Nova 250 I6 Borg Warner T5
Rotella 10W40 Fram XG5
Re: Oil for new snowblower [Re: NHRATA] #4585869
11/26/17 05:48 PM
11/26/17 05:48 PM
ma
NHRATA Offline OP
NHRATA  Offline OP
ma
Does anyone have experience with the Briggs and Stratton 5w 30 synthetic
Re: Oil for new snowblower [Re: NHRATA] #4585875
11/26/17 05:51 PM
11/26/17 05:51 PM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
Yup, as everybody has said, any 5/30 is fine. As was also said, you don't have to work about spring pressures, as I can squeeze most all of them with my fingers.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: Oil for new snowblower [Re: NHRATA] #4585877
11/26/17 05:53 PM
11/26/17 05:53 PM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
I am sure the Briggs oil is fine, but I was a briggs dealer for 40 years, and never used it or recommended it to my customers. Why pay double?
Re: Oil for new snowblower [Re: NHRATA] #4585908
11/26/17 06:22 PM
11/26/17 06:22 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
The fuel system on the snowblower will fail you long before you have any oil related failure, regardless of any semi-sane oil choice.
Plain, simple Garak.
Re: Oil for new snowblower [Re: Linctex] #4585957
11/26/17 07:08 PM
11/26/17 07:08 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Well some oils intended for OPE might be better able to handle high heat from a mower where the cooling fins are clogged with grass and its getting mighty hot.
2015 Ford F250 w/Powerstroke
Re: Oil for new snowblower [Re: NHRATA] #4586734
11/27/17 04:08 PM
11/27/17 04:08 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
I run PPPP 5w30 in my LCT powered Poulan. Next oil change will probably be the left over Castrol Edge black bottle. Snowblower does not care and runs great. The fuel system was the first problem and since that has been sorted out, it runs great. In -30C ambient it starts first pull. Does not burn any oil either.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: Oil for new snowblower [Re: NHRATA] #4586781
11/27/17 05:11 PM
11/27/17 05:11 PM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
I use PP 5w30 in my 1980's Honda HS55 snowblower. It's a gigantic step ahead to what the machine was spec'd for. Still burns no oil.
13 Civic Si 2.4L- 69Kkms(43Kmi)-PP,Wix
05 LeSabre 3.8L-210Kkms(134Kmi)-PP,Wix
03 Sierra 2500 6.0L-204Kkms(127Kmi)-PP,Wix
All with mpg > EPA
Re: Oil for new snowblower [Re: NHRATA] #4587135
11/28/17 01:00 AM
11/28/17 01:00 AM
ma
NHRATA Offline OP
NHRATA  Offline OP
ma
I ended up getting the Briggs & Stratton oil for $5 per quart from a local shop. I figured that was a pretty good price for full synthetic. It's half of what Tractor Supply sells the same stuff for
