Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
85 registered members (billt460, ARCOgraphite, Bailes1992, BamaE92, andyd, 10 invisible), 1,723 guests, and 70 spiders.
Topics286,446
Posts4,908,459
Members67,626
Most Online2,967
Mar 10th, 2019
Limited slip gear oil in a non-limited slip diff #4585124
11/26/17 04:54 AM
11/26/17 04:54 AM
Texas
WyrTwister Offline OP
Texas
Would this cause a problem ?
https://www.oreillyauto.com/detail/valvo...evrolet/caprice
Thanks , :-)
Wyr
God bless
Re: Limited slip gear oil in a non-limited slip diff [Re: WyrTwister] #4585125
11/26/17 05:00 AM
11/26/17 05:00 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
No problems that I am aware of as I do it all the time.
I use Mobil 1 75w90 LSD gear oil in my non LSD Firebird FORMULA in my sig and have also used it in my wife's previous Lexus AWD TC & Diff(non LSD).
I bought a gallon of PEAK 80w90 LSD gear oil from Pep Boys for around $15/gal. I believe this was their regular price. IDK if PEAK has a 80w140 LSD.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Limited slip gear oil in a non-limited slip diff [Re: WyrTwister] #4585128
11/26/17 05:03 AM
11/26/17 05:03 AM
Texas
Texas
Thanks , :-)
Wyr
God bless
Re: Limited slip gear oil in a non-limited slip diff [Re: WyrTwister] #4585129
11/26/17 05:07 AM
11/26/17 05:07 AM
Nowthen, MN
KD0AXS Offline
KD0AXS  Offline
Nowthen, MN
No problem, all it means is that the oil contains the friction modifier to make LS work properly. Won't hurt anything to have the friction modifier if you don't have LS.
Re: Limited slip gear oil in a non-limited slip diff [Re: WyrTwister] #4585136
11/26/17 05:28 AM
11/26/17 05:28 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I have done it w/o problems.
The "thinking" man's friend.
Re: Limited slip gear oil in a non-limited slip diff [Re: WyrTwister] #4585142
11/26/17 05:56 AM
11/26/17 05:56 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
No, it won't cause any problem.
Re: Limited slip gear oil in a non-limited slip diff [Re: WyrTwister] #4585150
11/26/17 06:16 AM
11/26/17 06:16 AM
Texas
Texas
Thanks , all , :-)
Wyr
God bless
Re: Limited slip gear oil in a non-limited slip diff [Re: WyrTwister] #4585162
11/26/17 06:28 AM
11/26/17 06:28 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Btw, what's the differential housing temperature recorded .... if you had done one?
Re: Limited slip gear oil in a non-limited slip diff [Re: WyrTwister] #4585191
11/26/17 07:45 AM
11/26/17 07:45 AM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
No, it's usually the other way around that poses an issue.
2010 Mazda RX8 Sport - 37k miles - ????
2006 Toyota Matrix XR AWD (Wife) - 130k miles - Valvoline Max Life 5w30
Re: Limited slip gear oil in a non-limited slip diff [Re: WyrTwister] #4586016
11/26/17 08:13 PM
11/26/17 08:13 PM
MI, USA
Whitewolf Offline
Whitewolf  Offline
MI, USA
It probably wont cause a problem but generally the FM's required for LS applications tend to detract from oxidation and seal performance.
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
Re: Limited slip gear oil in a non-limited slip diff [Re: WyrTwister] #4586045
11/26/17 08:33 PM
11/26/17 08:33 PM
Texas
Texas
I found 2 quarts of the Valvoline ( which I linked to ) that do not say limited slip . At AAP + 20% online discount . :-)
Thanks , :-)
Wyr
God bless
