Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
21 registered (Deltona_Dave, Falcon_LS, car51, CleverUserName, Bjornviken, 2 invisible), 718 Guests and 34 Spiders online.
65265 Members
67 Forums
285574 Topics
#4584927 - 11/25/17 09:13 PM Can I bleed the master cylinder using the car?
JLawrence08648 Offline
Loc: NJ
I need to replace my master cylinder.
The instructions say to bench bleed by filling and using tubing pumping the brake fluid back into the master cylinder by pushing the rod with your hand.
I've always bled it on the car. I bled it the same way, disconnectimg tje brake lines and hooking up tubing to re-use the new brake fluid by funneling back into the master cylinder, same as in a vise.
I find it easier for my wife to pump the brake pedal and me watch the "operation" under the hood.
Then when bled, I hook up the lines and do the normal bleeding of each wheel until the brake fluid comes clear in a clear soda bottle with a hose attached from the bleeder screw.
Anything wrong with this method?
#4584931 - 11/25/17 09:18 PM Re: Can I bleed the master cylinder using the car? [Re: JLawrence08648]
bdcardinal Offline
Loc: Santa Barbara, CA
Nothing wrong with your method. Supposedly bench bleeding became popular when a lot of cars had the master cylinders mounted low on the frame.
Just take care to not get brake fluid on the paint and if you think you might have run a bunch of water all over the area, obviously with the master cylinder cap on.
Edited by bdcardinal (11/25/17 09:19 PM)
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4584936 - 11/25/17 09:20 PM Re: Can I bleed the master cylinder using the car? [Re: JLawrence08648]
Billbert Offline
Loc: California
It is Not recommended to do it that way. There is little feeling for what is going on, and you can, under some circumstances ruin the rubber cups inside the master cyl. Bench bleed ing is required prior to installation.
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
#4584958 - 11/25/17 09:34 PM Re: Can I bleed the master cylinder using the car? [Re: JLawrence08648]
eljefino Offline
Loc: ME
If the part says you have to, you have to. They wouldn't spend the nickle on that plastic tube if you didn't need it.
Most likely your car's MC tilts backward at the firewall and there'd be no way to get at the air bubble on the far forward side of your particular unit.
Other MCs you've dealt with have had a more vertical firewall.
Some MCs are tapped for a line at the far forward end; yours does not sound like one.
IOW, just follow the directions. laugh
#4584986 - 11/25/17 10:04 PM Re: Can I bleed the master cylinder using the car? [Re: JLawrence08648]
andyd Offline
Loc: Marshfield , MA
Until the innards are immersed in brake fluid, they are dry and stiff. A bench bleed will ease the rubber into duty. Here's a tip, All the hydraulic parts come with instructions. Reading them a few times will help you get the idea, if you've never played with one before. grin2
Thick oil is better grin2
#4585011 - 11/25/17 10:40 PM Re: Can I bleed the master cylinder using the car? [Re: JLawrence08648]
spasm3 Offline
Loc: North Carolina
I bench bleed. I do it to make sure the MC goes full stroke. Can you be sure the brake pedal makes the MC go all the way? Also i can watch and see when the air bubbles stop.
13 elantra 68k 5w30 QSUD
03 chevy avalanche76k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 3900 miles m1 0w20/0w40 mix
#4585079 - 11/26/17 12:14 AM Re: Can I bleed the master cylinder using the car? [Re: JLawrence08648]
andyd Offline
I rig an air lock, a little brake fluid in a hot sauce bottle and 2' of clear tubing sized to make a tight fit at the bleeder. Once you don't see bubbles,you move on. It is cheap and you don't need help. If you can't bleed, it is because the system is sucking air some where. Now you have to get a gravity bleed running. A system won't gravity bleed if it isn't air tight.
