Best oil drain plug gasket
Might have to do that for the Altima.
Not sure how much longer the ford will be around
I always bill out/install a new drain plug washer with an oil change. I use the same gasket type and material that the vehicle came with from the factory. If it is a VW/Audi car, I replace the entire plug since the washer is captive.
