Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
29 registered members (billt460, alcyon, Bailes1992, 2015Corolla, 4WD, 4 invisible), 521 guests, and 57 spiders.
Topics286,442
Posts4,908,266
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
2018 Highlander V6 #4584764
11/25/17 07:07 PM
11/25/17 07:07 PM
Tennessee
SWS Offline OP
SWS  Offline OP
Tennessee
Thinking about a 2018 Highlander V6. Would appreciate your thoughts.
Replacing 2000 Odyssey that I bought new & still running well at 190K miles.
Also have 2006 Accord V6 with 90K (no VCM).
Some Points:
-> Plan on long-term ownership > 10 years.
-> Impressed by Toyota D-4S V6 engine with Port and Direct Injection.
Seems like this design will keep intake valves clean. True?
-> NOT impressed with fuel dilution typical of DI, and especially with my short-trip, in-town driving.
Don't know if D-4S is better in this regard. Comments?
-> Looking everywhere for a UOA on D-4S - don't find even one! Can you help?
-> I love the Honda V6, but not impressed with fuel dilution of DI or VCM.
-> Also not impressed with Honda I4 Turbo fuel dilution (e.g CR-V).
Thanks for your help!
SWS
Re: 2018 Highlander V6 [Re: SWS] #4584771
11/25/17 07:13 PM
11/25/17 07:13 PM
CA
The Critic Offline
The Critic  Offline
CA
I would not hesitate to buy one. But keep in mind that Toyota V6s are more difficult to work on than Honda V6s, and the new D4S V6 engine requires new spark plugs every 60k (manifold removal required) and a new vacuum pump every 120k.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: 2018 Highlander V6 [Re: SWS] #4584802
11/25/17 07:51 PM
11/25/17 07:51 PM
PimTac Offline
PimTac  Offline
Is this particular Toyota engine a known diluter? While GDI engines have this trait there are some exceptions. Mazdaís SkyActiv engines seem to handle the issue better. It might also be a case by case issue. Break the engine in properly and one thing I do since I short trip a lot is take the long way home when I can. These engines want to run.
Cannot see signatures any longer so it doesn’t matter.
Re: 2018 Highlander V6 [Re: SWS] #4584818
11/25/17 08:11 PM
11/25/17 08:11 PM
Ohio
Dorian Offline
Dorian  Offline
Ohio
The 2018 Highlander is still a solid choice. I was not aware of the Toyota engine requiring new plugs every 60K, and the new vacuum pump every 120K. Remember though that the Honda V6 has a timing belt. One complaint about the new 2018s I hear frequently is that the new 8-speed is not the smoothest in the segment.
15 Camry Hybrid SE 48K 0W20 Kendall bulk
14.5 Camry SE 2AR 0W20 M1 AFE 44K (Mom's)
98 Chevy Prizm 1ZZ M1 AFE 0W30 148K (Brother's)
Re: 2018 Highlander V6 [Re: SWS] #4584821
11/25/17 08:13 PM
11/25/17 08:13 PM
Utah
CKN Offline
CKN  Offline
Utah
You have fallen victim to a BITOGism.
All "Direct Injection" motors are bad.
Simply NOT TRUE.
Does it have a CVT-or any "driver assist" features?
Maybe we could go for a trifecta.
Re: 2018 Highlander V6 [Re: The Critic] #4584856
11/25/17 08:58 PM
11/25/17 08:58 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Wow, that's a lot of stuff to do. Makes plugs tough to do, huh?
I do like the lines of the highlander though.
Re: 2018 Highlander V6 [Re: SWS] #4584901
11/25/17 09:50 PM
11/25/17 09:50 PM
Michigan
khittner Offline
khittner  Offline
Michigan
If the V-6 makes you nervous, save some money and opt for the base FWD Highlander with the 2.7 liter 4-cylinder. My wife has this engine in her 2011 Highlander, with 123K miles on it, and it has been fine for our family of four. We donít tow anything, but itís fine for full loads (6 people plus luggage).
Re: 2018 Highlander V6 [Re: The Critic] #4584925
11/25/17 10:11 PM
11/25/17 10:11 PM
Cloquet Mn.
bobbobtar Offline
bobbobtar  Offline
Cloquet Mn.
I just looked at my 2017 Highlander maintenance manual, spark plugs replace at 120,000 miles, no mention of vacuum pump replacement. What are you basing this on?
2017 Toyota Highlander
2018 John Deere 2032R
2014 CanAm Spyder
1981 Chevy Malibu 355cu 425hp
Re: 2018 Highlander V6 [Re: khittner] #4584932
11/25/17 10:20 PM
11/25/17 10:20 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I politely disagree. The 2018 is heavy..even the Venza with the 6 wasnt impresively fast. I think the V6 is sufficient, maybe even a tad underpowered. It rides smooth the highlander but it is a big machine! The older highlanders look small in comparison...id love to buy a highlander, unfortunately the price is what has me leaning to alternatives.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: 2018 Highlander V6 [Re: bobbobtar] #4584933
11/25/17 10:20 PM
11/25/17 10:20 PM
CA
The Critic Offline
The Critic  Offline
CA
The Highlander uses the 2GR-FKS engine.
Re: 2018 Highlander V6 [Re: CKN] #4584937
11/25/17 10:21 PM
11/25/17 10:21 PM
saginaw michigan
saginawmale50 Offline
saginaw michigan
Simply NOT TRUE.
Not all DI engines are "bad" , but all of them do have valve coking and eventually all will need servicing at some point in the future.
Re: 2018 Highlander V6 [Re: bobbobtar] #4584946
11/25/17 10:27 PM
11/25/17 10:27 PM
Tennessee
SWS Offline OP
SWS  Offline OP
Tennessee
I just downloaded the 2018 Highlander Warranty and Maintenance Guide.
The Critic is correct.
Spark Plugs at 60K miles or 72 months: "Maintenance services of spark plugs are required under the terms of the Emissions Control Warranty"
At 120K miles or 144 months: "Replace vacuum pump for brake booster (2GR-FKS engine only)"
Thanks for the replies - I am learning so much!
Re: 2018 Highlander V6 [Re: SWS] #4584988
11/25/17 11:11 PM
11/25/17 11:11 PM
Lake County, Ohio
ls973800 Offline
ls973800  Offline
Lake County, Ohio
[quote=SWS]I just downloaded the 2018 Highlander Warranty and Maintenance Guide.
I follow the 3rd Generation Highlander forum at this link
http://www.toyotanation.com/forum/333-highlander-3rd-generation-2014/
I have heard of the vacuum pump calling for replacement due to the Start/Stop system for some reason. There was a post regarding that concern on the forum in the past.
I also read on the forum that the 2018 requires a fuel additive at certain miles, and if I'm not mistaken, it might have been for the state of Hawaii and also for Puerto Rico?
Haven't heard about the spark plugs due at 60K, wonder if that would be done for free since they require it for the warranty? I had a Ford which called for a part ( I think it was the PCV valve) which had to be replaced under the maintenance schedule for the Emission Warranty to remain in effect. The first replacement while under the warranty was free.
Re: 2018 Highlander V6 [Re: SWS] #4584993
11/25/17 11:17 PM
11/25/17 11:17 PM
Lake County, Ohio
ls973800 Offline
ls973800  Offline
Lake County, Ohio
Here's the discussion regarding the fuel additive on the Highlander Forum
http://www.toyotanation.com/forum/333-hi...difference.html
Re: 2018 Highlander V6 [Re: SWS] #4584998
11/25/17 11:23 PM
11/25/17 11:23 PM
CA
The Critic Offline
The Critic  Offline
CA
If I am looking at the correct vacuum pump, this will be a big ticket item:
https://www.toyotapartsdeal.com/oem/toyota~pump~assy~vacuum~29300-0p010.html?Make=Toyota&Model=Highlander&Year=2017&Submodel=&Filter=()&Location=vacuum-pump,,29300
Page 1 of 3 1 2 3
