STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
108 registered members (ARCOgraphite, Ag76, Altima2, acme, 2012AccentSE, AandPDan, 10 invisible), 1,981 guests, and 63 spiders.
Topics286,230
Posts4,904,725
Members67,582
Most Online2,967
Mar 10th, 2019
Penn Euro or M1 esp-lowest NOACK? #4584731
11/25/17 06:19 PM
11/25/17 06:19 PM
Illinois
BTLew81 Offline OP
BTLew81  Offline OP
Illinois
Iím current formulation does PPE 5w40 or esp 5w30 have a lower noack?
Thanks!
2018 Honda Accord Sport 2.0T/10 Speed
Modern Steel Metallic/Black
Factory Fill/Filter
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BTLew81] #4584758
11/25/17 07:03 PM
11/25/17 07:03 PM
Australia
toyota62 Offline
toyota62  Offline
Australia
Mobil1 ESP 5w-30 has 5.6 Noack...........
Bob.
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BTLew81] #4584796
11/25/17 07:47 PM
11/25/17 07:47 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I would use Mobil1 ESP 5W30 as it has lower ash content. Noack doesn't matter, the ash content does. Oil gets on the valve stems from seeping past the valve stem seals. It happens by design and typically doesn't affect older engine designs which have fuel wash over the intake valves. The ash is left over on the valve stems which is why you want a lower ash content.
Note: My car ran like a top until I had to replace the intake manifold at 82K miles. The secondaries wouldn't open. Well know problem on the OLDER TSI 2.0. The new intake was less than $200 at a local VW dealership. Removing the intake and cleaning the valves is easy. I bet my wife could do it. After cleaning the intakes valves and replacing the intake, my car ran great again, but it didn't feel any faster or get better fuel economy.
Enjoy your Alltrack and don't worry about intake valve deposits.
Me: 13' VW GTI 3 door 6 speed manual
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BTLew81] #4584898
11/25/17 09:47 PM
11/25/17 09:47 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Where do you even find ESP these days for a decent price?
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BTLew81] #4584990
11/25/17 11:14 PM
11/25/17 11:14 PM
Illinois
BTLew81 Offline OP
BTLew81  Offline OP
Illinois
Whatís the word on PPE 5w40?
Factory Fill/Filter
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BTLew81] #4585049
11/26/17 12:29 AM
11/26/17 12:29 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Itís good oil, and has the certs to prove it. IMO, there is very little that different types of oil do to affect the amount of intake port and valve carbon buildup. The problem is the engine design itself. M1 ESP is also fantastic oil, but itís hard to find and very expensive, and not capable of extended drains.
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BTLew81] #4585158
11/26/17 06:24 AM
11/26/17 06:24 AM
Indiana
BobFout Offline
BobFout  Offline
Indiana
I bought my ESP 5w-30 from NAPA or Amazon. And while the price isn't as cheap as you'd find at Wal-mart etc, it's not very expensive.
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BTLew81] #4585768
11/26/17 04:40 PM
11/26/17 04:40 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Another solid option that's readily available is PP Euro L 5W-30. What does your VW spec, 502 or 504?
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BTLew81] #4586154
11/26/17 10:26 PM
11/26/17 10:26 PM
Illinois
BTLew81 Offline OP
BTLew81  Offline OP
Illinois
Technically 502. I do 5k oci so a 504 should be fine. However, euro L doesnít meet any vw specs if I recall correctly.
Factory Fill/Filter
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BTLew81] #4586202
11/27/17 12:03 AM
11/27/17 12:03 AM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Just checked, youíre right. 5k on a 504 oil is definitely ok. Just too bad 504 oils are so hard to come by. Motul also makes a good 504 oil (8100 x-clean+). Available on most the European parts websites. Do you know if your engine also had port fuel injectors? I know so DI engines have been adding them due to the carbon buildup issue. If so, the whole point is moot.
Re: Penn Euro or M1 esp-lowest NOACK? [Re: skyactiv] #4586663
11/27/17 03:11 PM
11/27/17 03:11 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Both are equally important in preventing CBU and especially preventing clogging DPF in diesels, hence low-ash content and lower NOACK requirements for those oils.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BTLew81] #4587906
11/28/17 07:34 PM
11/28/17 07:34 PM
Indiana
BobFout Offline
BobFout  Offline
Indiana
It doesn't state 502.00, 503.00 or 504.00 that is 5w40 or 5w30, or other grade as necessary for climate?
Re: Penn Euro or M1 esp-lowest NOACK? [Re: BobFout] #4587955
11/28/17 08:01 PM
11/28/17 08:01 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
VW 504.00/507.00 are only 0/5W30 grade.
Euro L does not meet any VW standards.
