Pennzoil - SN Plus and 0W-16 Q&A
Click here to participate in the Pennzoil Q&A
New 2018 Subaru Forester Touring 2.5l
by Joeescape63
03/18/18 08:05 AM
2018 Chevy Impala V6 Rental - Quick Review
by Delta
03/18/18 07:53 AM
Oil filter Yoga
by Snagglefoot
03/18/18 07:32 AM
Oil change w/ CC Zinc additive - 500m or next oci?
by Hemispheres
03/18/18 06:58 AM
0W-16 Oil....... Really ??
by billt460
03/18/18 05:46 AM
Looks like Valvoline is trying again.
by demarpaint
03/18/18 05:42 AM
Johnson 25/40 4 stroke marine oil.
by passgas55
03/18/18 05:00 AM
Oil Filter That Hasn't Been Changed In 3 Years
by BlueOvalFitter
03/18/18 02:44 AM
by dishdude
03/18/18 02:28 AM
Control Arm Bushings Bad?
by RoGuE
03/18/18 01:36 AM
Free Pizza, April 2, 2018....
by mattwithcats
03/18/18 12:15 AM
Low mileage seven year old tires
by Corollaman
03/17/18 11:31 PM
Mobil 1 UOAs showing more wear?
by mbacfp
03/17/18 10:35 PM
2011 Silverado work truck 6000 miles
by Corollaman
03/17/18 10:25 PM
PP Practically Free at O'Reilly
by John_K
03/17/18 10:22 PM
Toyota oil filter cartridge assembly
by pda1122
03/17/18 10:14 PM
Carrying IWB 1911 vs Glock 19
by lukejo
03/17/18 09:01 PM
Broken stuff this weekend - great service 'though.
by Shannow
03/17/18 08:57 PM
Denso Air and Cabin Filters?
by maverickfhs
03/17/18 08:41 PM
Sticky door latch 2nd generation Golf
by vavavroom
03/17/18 08:35 PM
minnowhooker, hkj13510, Aristarkhov, oil_burner, Clickws
64491 Registered Users
83 registered (Ammofirst, Astro14, 2009Edge, AZjeff, aquartlow, Astro_Guy, 5 invisible), 1272 Guests and 123 Spiders online.
64491 Members
68 Forums
279993 Topics
Page 1 of 2 1 2 >
#4584567 - 11/25/17 02:15 PM Brake grease
mb32 Offline
Loc: Canada
I'm doing the front brakes on my 06 G35. After finishing up I went to flush the brakes and noticed that the rear caliper slide boots were completely shrunken.
I was fortunately able to get the pins out but it was obvious all the grease had escaped.
I did the rear brakes 2.5 years ago and used Permatex synthetic disc brake lube (green colour). I obviously want to clean everything up, replace the boots and get new grease on the pins and clean off what I just applied to the front.
Any recommendations on what grease to get use that won't kill the rubber?
#4584574 - 11/25/17 02:18 PM Re: Brake grease [Re: mb32]
Rand Offline
Loc: NE,Ohio
2017 Jeep Cherokee Trailhawk V6
#4584585 - 11/25/17 02:23 PM Re: Brake grease [Re: mb32]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
Permatex brake grease goop of any color is bad news for pin seals and bushings.Sil-Glyde
#4584589 - 11/25/17 02:26 PM Re: Brake grease [Re: mb32]
Jimzz Offline
Loc: NoVA
Dielectric grease or sil glyde is what I always use.
#4584591 - 11/25/17 02:28 PM Re: Brake grease [Re: mb32]
andyd Offline
Loc: Marshfield , MA
Sil-glyde. How bad were the boots? Rubber tends to get mushy in petroleum based stuff.
'16 Camry LE STP synth 0w20 and STP filter.
'16 Camry SE, Valvoline bulk 0w20 and ? filter
#4584606 - 11/25/17 02:48 PM Re: Brake grease [Re: mb32]
JTK Offline
Loc: Buffalo, NY
I've made the same mistake and had similar results in the past.
All those different flavor "caliper greases" are super misleading IMO. They're more for the pad ears and backings and not so much for the rubber areas. I too use Sil Glyde for those and still have an expensive jar of purple "synthetic" caliper grease that is real sticky and stringy that I barely use.
2016 Subaru Forester 2.5, CVT. 2016 Nissan Quest SV (Babe magnet IV)
#4584612 - 11/25/17 02:57 PM Re: Brake grease [Re: mb32]
Timo325 Offline
Loc: AL,NC,TX,Germany,Korea,Italy
2011 Odyssey Touring Elite 80k mi. M1 EP, 0W-20, FU
2008 Mustang GT 81k mi. Edge EP (Gold) 5W-20, FU
#4584623 - 11/25/17 03:12 PM Re: Brake grease [Re: mb32]
Merkava_4 Offline
Loc: Clovis, CA
I used Dow Corning 111 on the slide pins the last time I did brakes; only because that's what I had on hand at the time. It's a high viscosity silicone grease used to lubricate plastic water softener valves and o-rings. It seems to be working OK. It's probably similar to Sil-glyde.
#4584742 - 11/25/17 05:36 PM Re: Brake grease [Re: Yah-Tah-Hey]
Rock_Hudstone Offline
Loc: New Jersey
Right. There is nothing "Perma" about Permatex brake grease, that stuff never failed to dry out and disappear within a few months.
Nothing but Sil-Glyde now for me. The 3M silicone paste is good as well but pricey.;gclsrc=aw.ds
#4584794 - 11/25/17 06:42 PM Re: Brake grease [Re: mb32]
Ducked Offline
Loc: Taiwan
I have some silicon grease, and some red rubber grease, bought in Japan, and some Bendix Ceramlube, bought in Australia.
So far I've only used the silicon. Since it didnt have a very high temp spec I backed it up by wrapping the pins in teflon tape. Been OK so far but I'll probably remove that the next time I strip them.
Dunno whats in the (recommended?) red rubber grease but IIRC the "traditional" Castrol equivalent was a castor oil/bentonite base, so it should be fairly rubber compatible but might eventually harden in service.
On paper the Bendix stuff should be the best but its pretty expensive.
The only readily available rubber compatible grease in Taiwan is earwax, and there isn't much of that.
#4584823 - 11/25/17 07:13 PM Re: Brake grease [Re: mb32]
NHGUY Offline
Loc: USA
King Kaliper/BBB Industries only uses a SilGlyde type lube in its assembled brake calipers...the previous Massachusetts owner of the King brand also only used the same product.And they had been around for 25+ years...
#4584826 - 11/25/17 07:19 PM Re: Brake grease [Re: mb32]
slacktide_bitog Offline
Loc: USA
I usually use whatever grease comes with the pads, and the last time I did rear brakes, I got new calipers anyway, which cane with the slide pins pre-greased hide
#4584831 - 11/25/17 07:28 PM Re: Brake grease [Re: mb32]
ZebRuaj Offline
Loc: MN
I use Permatex Extreme purple goo on all the contact points and shims, but only 3M silicone paste on slide pins and boots.
Too many horror stories of anything but silicone on rubber components.
~Shade tree mechanic for friends and family.
#4584837 - 11/25/17 07:39 PM Re: Brake grease [Re: Rand]
Donald Offline
Loc: Upstate NY
Originally Posted By: Rand
2015 Ford F250 w/Powerstroke
#4584855 - 11/25/17 07:56 PM Re: Brake grease [Re: Merkava_4]
doitmyself Offline
Loc: MI
Pay attention in class, Merk. Very little about Sil-Glyde is similar to 111 grin:
1. Polypropylene Glycol 25322-69-4 45-60%
2. Castor Oil 8001-79-4 30-45%
3. Silicon Dioxide, Amorphouse (silica) 7631-86-9 5-15%
4. Polydimethylsiloxane (silicone) 63148-62-9 1-5%
5. Oleoyl Sarcosine 110-25-8 1-5%
Page 1 of 2 1 2 >
