Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Bring back Merkava_4
by mjoekingz28
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
Any apple experts here?
by maverickfhs
06/18/18 02:50 PM
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
06/18/18 02:34 PM
Pittsburgh Dad, this guy is a trip
by Rat407
06/18/18 02:06 PM
14 Jeep GC 5.7, PP 5w20 & 0w20
by Vigg
06/18/18 01:52 PM
Sell me on a SSD drive...........
by ZZman
06/18/18 01:07 PM
need some ideas on my issue
by matrass
06/18/18 12:36 PM
Put Pennzoil Platinum Euro L in a Honda.
by dunlop0078
06/18/18 12:36 PM
BMW V8 Oil Consumption Fix
by doc540
06/18/18 11:25 AM
3horseman, Firedog45, WtsTacoma01, Orion62, Revd
65264 Registered Users
90 registered (08z06, ARB1977, 4WD, Astro14, andyd, 9 invisible), 1674 Guests and 41 Spiders online.
65264 Members
67 Forums
285538 Topics
#4584136 - 11/25/17 12:42 AM ASTM test / determining miscibility of motor oils
wemay Offline
Loc: Southeast Florida
2017 Hyundai Sonata Sport 2.4L
2013 Hyundai Santa Fe Sport 2.0T
#4584137 - 11/25/17 12:55 AM Re: ASTM test / determining miscibility of motor oils [Re: wemay]
Shannow Online   content
Loc: 'Stralia
Thanks for sharing that...
I raised it here
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3503628/Re:_The_oft_quoted_ASTM_D6922
and reference back to it in threads, and get met with "of course" two Sn rated oils mixed meet all the SN standards, there's a "compatibility test".
Just means that they can be mixed, cooled, heated and cooled without splitting or blowing chunks...with the reference oils that is.
#4584138 - 11/25/17 01:01 AM Re: ASTM test / determining miscibility of motor oils [Re: wemay]
wemay Offline
I know, there's a lot of confusion concerning this. But if you're not a bitoger, this information will never get read. The average joe will only see, "compatible with all other oil", as seen on the labels. But technically, however minute, a risk does exist.
#4584281 - 11/25/17 08:05 AM Re: ASTM test / determining miscibility of motor oils [Re: wemay]
69GTX Offline
Loc: Connecticut
6 reference oils are used for mixing with the test specimen. Therefore, how can it be said that the oil being tested can mix safely with all the permutations of different manufacturers? PQIA tests the oils of dozens of producers/blenders. I guess all that can be said is that it passed this particular test with those 6 specific ref oils.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4584330 - 11/25/17 09:26 AM Re: ASTM test / determining miscibility of motor oils [Re: 69GTX]
wemay Offline
Exactly. There would be no way to test the infinate ways different formulations mix.
#4584454 - 11/25/17 12:15 PM Re: ASTM test / determining miscibility of motor oils [Re: wemay]
Linctex Offline
Loc: Waco, TX
When it comes to motor oils, miscibility is absolutely the lowest of any of my concerns.
I have yet to hear of any real problems.
#4585139 - 11/26/17 04:47 AM Re: ASTM test / determining miscibility of motor oils [Re: Linctex]
Loc: 'Stralia
I've posted before the couple of SAE papers where REAL problems occurred, with PPD and VII interaction causing failures to pump at what people would consider fairly benign temperatures.
Has happened, is fairly rare, and the "W" rating is the most likely thing to be affected. And if you REALLY need that W rating, then you don't want to mix.
#4586277 - 11/27/17 05:20 AM Re: ASTM test / determining miscibility of motor oils [Re: Shannow]
bbhero Offline
Loc: Virginia
Yeah that is a great point Shannow. If one really needs their 5w to truly be thin enough to pump at -22F then it really matters a whole lot. If one lives in Orlando Florida where it may get down to 32F then it doesn't matter no where near as much.
Nissan Altima 3.5 Coupe Valvoline Advanced Full Synthetic 5w30 Federated Auto 4612ex
"Treat your family like your friends and treat your friends like your family."
#4586887 - 11/27/17 06:31 PM Re: ASTM test / determining miscibility of motor oils [Re: bbhero]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Exactly. I already hit that temperature once this fall. In Orlando, not so much. wink
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
