ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
104 registered members (2whlgeezer, 2015_PSD, 53' Stude, 2012AccentSE, 15 invisible), 2,182 guests, and 62 spiders.
Topics286,159
Posts4,903,310
Members67,569
Most Online2,967
Mar 10th, 2019
Rotela T4 -> now without API SM ? #4584035
11/24/17 10:12 PM
11/24/17 10:12 PM
Montreal,Quebec,Canada
Yannick Offline OP
Yannick  Offline OP
Hello,
I always put Rotela Triple action 15w40 in my 350 gas engine boat.
it seems that Rotela changed their formula with T4 instead of Triple Action.
Triple action has these API :
API: CJ-4, CI-4 Plus, CI-4, CH-4, CG-4, CF-4, CF. ·
API: SM, SL, SJ, SH ·
ACEA: E9, E7 ·
etc...
We can see API : SM , for gasoline engine.
Now T4 has these API :15W-40 CK-4, CJ-4, CI-4 Plus, CI-4, CH-4; ACEA E9; JASO DH-2, MA, MA2; Caterpillar ECF-2, ECF-3; Cummins CES 20086, 81; Detroit Fluids Specification (DFS) 93K222, 93K218; Deutz DQC III-10 LA; MACK EO-S 4.5, EO-O Premium Plus; MAN M3575; MB-Approval 228.31; MTU Category 2.1; Allison TES-439; Volvo VDS-4.5, VDS-4
no more API SM !!
Is there a reason ?
Re: Rotela T4 -> now without API SM ? [Re: Yannick] #4584047
11/24/17 10:24 PM
11/24/17 10:24 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
It's been addressed a number of times. With an SN in an ILSAC HDEO grade (i.e. 0w-30, 5w-30, 10w-30), P has to be cut if an SN is to be shown. Some companies have brought SN with the CK-4 for their 15w-40 products (and other non-ILSAC grades), whereas others haven't, depending upon their formulation and marketing plans.
Plain, simple Garak.
Re: Rotela T4 -> now without API SM ? [Re: Yannick] #4584058
11/24/17 10:30 PM
11/24/17 10:30 PM
Yannick Offline OP
Yannick  Offline OP
Is it still safe to put Rotela T4 in gasoline engine ? or the formula changed ?
Re: Rotela T4 -> now without API SM ? [Re: Yannick] #4584067
11/24/17 10:38 PM
11/24/17 10:38 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
It is safe, but not ideal. If you need that heavy an oil in your gasoline engine, go with a high mileage 10W-40 such as Maxlife or Castrol.
Re: Rotela T4 -> now without API SM ? [Re: Yannick] #4584092
11/24/17 11:30 PM
11/24/17 11:30 PM
Garak Offline
Garak  Offline
You can. The formulation has obviously changed with CK-4 coming out, but it didn't become a marine lube or a two stroke diesel lube. It's still E7, E9, so it's safe. Oil companies prefer you to buy within specifications, of course, notably in the 40 grades when it comes to expensive A3/B4 lubes. wink
Re: Rotela T4 -> now without API SM ? [Re: Yannick] #4584318
11/25/17 10:04 AM
11/25/17 10:04 AM
Michigan
Building3 Offline
Building3  Offline
Michigan
I called up the Shell tech hot line on Tuesday and asked if T-4 was still recommended for flat tappet engines. They said it was so I will continue to use it in my 1960's muscle cars. So in my case anyway, nothing has changed.
Re: Rotela T4 -> now without API SM ? [Re: Yannick] #4585207
11/26/17 08:20 AM
11/26/17 08:20 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
It still meets SM but shell has chosen to drop PCMO certification because of zddp levels.
One of the shell contributors here stated that the formula hasn't changed.
That said there are many other options for 40grade in PCMO
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
