How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
jcr1293, maxwellk, BlueFog, Frank_G35, captobvious
66681 Registered Users
98 registered members (bdcardinal, andyd, 2004tdigls, aquariuscsm, 4WD, 12 invisible), 1,986 guests, and 41 spiders.
Topics295,062
Posts4,927,086
Members66,681
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
2001 4.6 misfire on one cylinder #4583929
11/24/17 07:01 PM
11/24/17 07:01 PM
TN
terry274 Offline OP
terry274  Offline OP
TN
My son in law has a 2001 F150 with the Triton 4.6 engine. It has 190,000 miles on it. A few weeks ago he had a misfire that set a PO302 code. He changed the COP on cylinder number 2 and that cleared the problem.
Now he has a PO307, cylinder number 7 misfire. He and I installed a new COP and put a new Motorcraft plug in 7.
It still generated a PO307. We swapped the new COP for one of the other COP's and still got a 307.
We then put a new fuel injector in that cylinder. That didn't help.
I connected a vacuum gauge to the brake booster hose and at idle the truck has a steady 18 hg of vacuum.
I realize I need to do a compression test at this point. Thats going to be a hassle on this truck. Is there anything else for me to check?
I can check the fuel pressure tomorrow but that shouldn't be on only one cylinder if it's low should it?
The misfire is severe enough to be noticeable in the cab.
Thanks,
Terry
1996 Ford F150
2011 Toyota Avalon
2012 Honda Accord
2009 Ford Taurus
Re: 2001 4.6 misfire on one cylinder [Re: terry274] #4583932
11/24/17 07:06 PM
11/24/17 07:06 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Sounds like that cylinder is having trouble for sure... Compression test is what I would suggest given all that you have tried.
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: 2001 4.6 misfire on one cylinder [Re: terry274] #4583944
11/24/17 07:15 PM
11/24/17 07:15 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
You didn't say anything about spark plug replacement...
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: 2001 4.6 misfire on one cylinder [Re: Nick1994] #4583948
11/24/17 07:18 PM
11/24/17 07:18 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
"He and I installed a new COP and put a new Motorcraft plug in 7" Coffee2
Re: 2001 4.6 misfire on one cylinder [Re: terry274] #4583966
11/24/17 07:36 PM
11/24/17 07:36 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
I would check for fuel and spark at that cylinder. Just because you replaced them doesn't mean some electrical issue didnt rear its head and they are not working.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: 2001 4.6 misfire on one cylinder [Re: Colt45ws] #4583971
11/24/17 07:43 PM
11/24/17 07:43 PM
TN
terry274 Offline OP
terry274  Offline OP
TN
I have to pull that plug out to do a compression test, so I suppose I could crank the engine with the plug out and grounded just to make sure the coil is getting a signal.
1996 Ford F150
2011 Toyota Avalon
2012 Honda Accord
2009 Ford Taurus
Re: 2001 4.6 misfire on one cylinder [Re: StevieC] #4583990
11/24/17 08:10 PM
11/24/17 08:10 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Oooh! I thought he was still talking about number 2
Still weird to replace only 1spark plug...
Re: 2001 4.6 misfire on one cylinder [Re: terry274] #4583999
11/24/17 08:15 PM
11/24/17 08:15 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
If you hold the gas pedal to the floor, it activates "flood clear" mode in the ECU and will not operate the injectors, so you can crank without it starting.
Good for compression check, too.
-Colton
Re: 2001 4.6 misfire on one cylinder [Re: Nick1994] #4584004
11/24/17 08:26 PM
11/24/17 08:26 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
No worries... cheers
Re: 2001 4.6 misfire on one cylinder [Re: terry274] #4584009
11/24/17 08:36 PM
11/24/17 08:36 PM
MB - Manitoba
FastLane Offline
FastLane  Offline
MB - Manitoba
Check the connector hat runs to the COP. They are known to cause misfires.
2010 Silverado 4.8 4x4 Mobil 1 5W30 ACDelco PF48E
2002 Mustang GT 4.6 Mobil 1 5W30 MC FL-820S
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
Re: 2001 4.6 misfire on one cylinder [Re: terry274] #4584056
11/24/17 09:30 PM
11/24/17 09:30 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
This is when you really need a nice bidirectional scan tool so you can run a relative compression test, monitor the cam signal, et cetera. I think the PC version of the ForScan app can do relative compression actually.
Re: 2001 4.6 misfire on one cylinder [Re: terry274] #4584095
11/24/17 10:34 PM
11/24/17 10:34 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
I would think that a low cylinder would show up on a vacuum gauge as a fluttery needle or something?
Thick oil is better grin2
Re: 2001 4.6 misfire on one cylinder [Re: Colt45ws] #4584148
11/25/17 03:05 AM
11/25/17 03:05 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Why do that when you can throw parts at it ?
Re: 2001 4.6 misfire on one cylinder [Re: terry274] #4584215
11/25/17 07:09 AM
11/25/17 07:09 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
So, you know for sure that it's cylinder number 7? If you disconnect that cylinder, there is no/minimal change?
Or is it that the other plugs are old and not firing well?
Re: 2001 4.6 misfire on one cylinder [Re: Cujet] #4584276
11/25/17 08:02 AM
11/25/17 08:02 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Just for info's sake:
My friend has a '97 F-150 w/ 4.6l and he has the pair of 4 socket coils with spark plug wires going to each plug.
Since he bought the vehicle Fords come up in threads (like this) and in conversation and it appears to me that Ford used coils and COPs all over the year range of the 4.6 and 5.4 engines.
There seems to be no rhyme or reason to it.
What is a "connector hat going to the COP", a plug of sorts?
Page 1 of 3 1 2 3
