2015 Dodge Dart 8,073 Valvoline Synpower 0W 20
Grand Rapids, Michigan
2015 Dodge Dart 2.4L
Code:
Time on unit 42,286 34,213 26,460
Time on oil 8,073 7,753 7,840
SAE 0W 20 Valvoline Valvoline Pennzoil
Type Synpower Daily Protection Platinum
Metals
Iron 10 14 11
Chromium
Lead 1 1
Copper 5 5 8
Tin 1 2
Aluminum 6 8 7
Nickel
Sliver
Titanium
Vanadium
Contaminants
Silicon 15 18 19
Sodium 339 352 21
Potassium 30 12 13
Additives
Magnesium 10 10 8
Calcium 2133 2305 2226
Barium
Phosphorus 614 658 648
Zinc 721 749 762
Molybdenum 7 18 74
Boron
Contaminants
Water
Coolant No No No
Physical Tests
Viscosity 9 7.5 9.0
Physical/Chemical
Base Number 3.7 3.0 4.3
About a year ago I witnessed a Ford modular V8 with its valve covers off to replace the valve cover gaskets it had 325,000 miles and the motor was spotless! The owner used Valvoline Synpower 5w30 changed around 7,500 miles since new. Not that other oils would not do the same I'm just saying the Synpower worked.
Yeah and my picture of using Amsoil for 300K miles in my Santa Fe got dismissed as being too clean.
Originally Posted By: TheOilWizard
Why does the middle report have a significantly lower viscosity?
I can tell you that it is the Daily Protection Valvoline Full Synthetic that was only sold at Meijer stores for a few months than discontinued, not sure if that's it but could be.
TOTO.
TOTO.
Can you confirm it was the same viscosity as the other two? If so, that’s very interesting.
Originally Posted By: MParr
That Valvoline is holding up just as well as the Pennzoil. I may just go back to it.
Other than marketing what makes Pennzoil better than Valvoline?
