ACDelco Dexos 0W20 UOA
by DanMiller
Today at 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
Today at 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
Today at 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
Today at 10:18 AM
What to do when your Glock jams
by bigj_16
Today at 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
Today at 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
Today at 09:03 AM
Brisket flat on charcoal
by 04SE
Today at 08:45 AM
Weird Oil level question
by audia6
Today at 08:27 AM
DNA test and opening a can of worms
by WhyMe
Today at 08:11 AM
Ghetto testing a wheel speed sensor
by Nayov
Today at 06:23 AM
dash cam
by DAC2018
Today at 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
Today at 01:08 AM
Plastic burning smell when WOT
by Jaha24k
Today at 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
Today at 12:00 AM
Ruger LCP .380
by PW01
Yesterday at 11:24 PM
Launching boat with stick shift
by troutfisher
Yesterday at 11:22 PM
Free oil
by Spitter
Yesterday at 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
Yesterday at 10:04 PM
RC cars
by red7404
Yesterday at 09:36 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
67 registered (93cruiser, AdmdeVilleneuve, andyd, 4WD, ammolab, 10 invisible), 1504 Guests and 62 Spiders online.
65303 Members
67 Forums
285902 Topics
Page 1 of 2 1 2 >
#4583511 - 11/24/17 09:47 AM '07 Scion tC looks like burnt intake valves?
crazy_raccoon Offline
Loc: USA
When my buddy and I installed an aftermarket header a couple months ago we noticed the intake valves were white on the header side and it looks like some kind of deposit build up is there. Has anyone ever ran into this issue and found a good way to solve it without taking the engine apart? Usually when I see dirty intake valves they are black.
Status on vehicle:
- I do a lot of short trips because I don't live far from the base and did a lot of short intervals driving to different buildings within a couple of miles.
- Highway driving is usually less than 10 minutes a day because there is no need for me to be on there.
- I have a short ram intake that I've been running since 15,000 miles and car currently has 97,000.
- Valve cover gasket is leaking a little bit and I just switched to Valvoline FS w/Max Life 0W-20 because of the bad piston design and seals are probably old by now. (There's a TSB for oil consumption on these vehicles)
So yeah I'm just pretty curious if anyone has ever ran into thi before.
'07 Scion tc
- 98K miles
- Valvoline FS w/ML 0W-20 D1G2
- FRAM Ultra
'07 Honda Accord coupe 4cyl
- 120K miles
- FRAM Ultra
#4583558 - 11/24/17 10:36 AM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
JohnnyJohnson Online   content
Loc: Wet side WA
That isn't going to help Toyota build on the good name is it?
2004 Toyota Corolla 121790
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4583559 - 11/24/17 10:38 AM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
cronk Offline
Loc: Watertown, New York
If that is from the exhaust header side, those are exhaust valves.
If those are exhaust valves, than that looks normal.
1998 GMC C1500
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
#4583561 - 11/24/17 10:40 AM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
BobsArmory Offline
Loc: Michigan
Are you running any aftermarket additives in the oil and/or fuel?
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
#4583571 - 11/24/17 10:51 AM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
DuckRyder Offline
Loc: Atlanta
Intake valves do not burn
That picture does not show a burned valve (at least you canít see if it is burned)
You canít fix a burned valve without removing it
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
#4583572 - 11/24/17 10:52 AM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
rooflessVW Offline
Loc: North Carolina
Looks like normal exhaust valves to me.
"Zed's dead baby, Zed's dead."
#4583579 - 11/24/17 11:04 AM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
SubLGT Offline
Loc: Idaho
Originally Posted By: crazy_raccoon
When my buddy and I installed an aftermarket header a couple months ago we noticed the intake valves were white on the header side...
You can't generally see the intake valves from the "header side". Those look like normal exhaust valves.
Edited by SubLGT (11/24/17 11:07 AM)
#4583622 - 11/24/17 12:13 PM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
BrocLuno Offline
Loc: Kalifornia Kollective
A bit white to me, but not terrible. I'd like to see tan instead ... Only a tuner chip with a slight increase in air/fuel ratio will get there ...
The changes you are making are likely leaning it out some. The ECU is not compensating ...
Edited by BrocLuno (11/24/17 12:14 PM)
#4583628 - 11/24/17 12:23 PM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
Alex_V Offline
Loc: Campbellsville, KY
Unless the engine has both manifolds on the same side, which is uncommon in more recent decades as it's less efficient, you're looking at the exhaust valves and unless you have a misfire your valves aren't burned. That's probably just a sign of a good clean burn.
When a valve burns, is when part of the shoulder (where it contacts the seat) begins eroding giving combustion gasses a route to escape and compression loss is the result. Intake valves are exposed to cooler air and gasoline (except in DI) passing over them so run cool enough that they almost never burn.
Edited by Alex_V (11/24/17 12:24 PM)
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 112K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 167K
'67 Suburban, 350, 331K
#4583644 - 11/24/17 12:36 PM Re: '07 Scion tC looks like burnt intake valves? [Re: SubLGT]
Linctex Offline
Loc: Waco, TX
Yep - those are "Normal" EXHAUST valves, yo.... dude
#4583665 - 11/24/17 12:51 PM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
Crispysea Offline
Loc: TN USA
They look good to me, too, especially for 97K miles. Dirty valves look way worse than those.
#4583695 - 11/24/17 01:22 PM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
Quest Offline
Loc: beaver land EH?
2 things of note:
(1) the picture showed seems to be the exhaust port (exhaust valves), not intake.
(2) when in doubt: always perform compression checks.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#4583748 - 11/24/17 02:46 PM Re: '07 Scion tC looks like burnt intake valves? [Re: rooflessVW]
Trav Offline
Loc: MA, Mittelfranken.de
+1
#4583774 - 11/24/17 03:24 PM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
FlyNavyP3 Offline
Loc: Jacksonville, FL
Those aren't intake valves, they're exhaust valves. Their color and slight buildup are both perfectly normal.
Luke
#4583941 - 11/24/17 07:11 PM Re: '07 Scion tC looks like burnt intake valves? [Re: crazy_raccoon]
TinyVoices Offline
Loc: Vienna, VA
Will resonate with everyone here. Those look like perfectly normal exhaust valves for a 2az engine. We have had a few of these apart and they looked similar. No issue to report on your car.
1993 Toyota MR2 Hardtop N/A - 157k miles - Valvoline Max Life 5w30
2006 Toyota Matrix XR AWD (Fiancee) - 126k miles - Valvoline Max Life 5w30
Page 1 of 2 1 2 >
