New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
105 registered members (addyguy, 2004tdigls, 92saturnsl2, 2015_PSD, 2002 Maxima SE, 12 invisible), 2,222 guests, and 61 spiders.
Topics286,351
Posts4,906,907
Members67,608
Most Online2,967
Mar 10th, 2019
What ATF & periodicity for 2002 Camry 4 cyl? #4583305
11/24/17 12:48 AM
11/24/17 12:48 AM
Connecticut
69GTX Offline OP
69GTX  Offline OP
Connecticut
OK. I'm going to ask for your guy's expertise. I did about an hour of reading on these cars. My brother owns a 2002 Camry V4 automatic with 155K miles. We were discussing our "old" cars and I asked him about transmission fluid. He knew really nothing except it never needing changing per the manual (and printed on the dip stick)....and that his mechanic took care of that kind of stuff. He trusts him to do the right thing.
He's had the car for a long time yet has no knowledge of trans fluid being changed, never mind how often. It could factory fill. What I came up with is that 30K drain and refills are pretty popular and make sense. 100K-150K full flushes, filter (rock catcher) might be in order. I think 3 successive drain and refills (3.5 qts?) make sense over the next 12 months. Fluid choices seem to be OEM T IV, Mobil 3309, Valv ML, Castrol Import ATF, Mobil 1, Amsoil ATF, Redline D4, etc. This is a Dex3/Mercon/Mercon V type trans right? There's some sort of differential using the same trans fluid. That sounds strange to me. Is it a transaxle of sorts? Pan drain and refills seem very easy as this has a 10mm plug.
Am I missing anything? Other words of advice? He intends to keep the car for as long as it runs well. I'm not a fan of 155K miles on factory fluid...or even on 2 OCI's so far. I read some old Bitog threads on the these trans. It wasn't like there was a single fluid of choice other than sticking with factory T IV at $9/qt. Nothing fancy here - just what will work and makes great sense. I don't want to be part of a 10 qt flush only to have his trans fail a month later. We all know the saying: "no good deed goes unpunished."
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583313
11/24/17 01:23 AM
11/24/17 01:23 AM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
Lets dispense with internet myth and focus on what is best. If it is full of original fluid beat to death, changing a little is foolish. Dropping the pan and cleaning the magnets, inspecting the filter, and refreshing all the fluid is the smart play.
Also, if this is the U140e transmission, which I think a 2000 i4 had, anything other than optimal care is insane. They have a serious, known flaw in the thrust bearing behind the forward planetary set. Look in the door jamb on the plate for the code. They can grenade w/o warning. More common behind the V6 like in the Lexus ES, but the I4 applications are not immune when neglected.
If it is the u140e, you need to get serious. If it is still an A series 4 speed, you can get away with being lazy as you indicated.
Regardless of which it is, stick to a TIV compatible fluid with the same viscosity. Castrol Transmax High Mileage is my fave here, though there are others. If it is a u140e, lubegard red as an additive is wise. If it has a mesh steel filter, donít replace it. Aftermarket ones have flowed low enough to starve the pump.
Do the ps system at the same time. The ps pump is a pita on these engines/bodies. Donít neglect ps fluid maintenance.
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583314
11/24/17 01:24 AM
11/24/17 01:24 AM
South Texas
Insertcoolname Offline
South Texas
I think Toyota recommends service around 100k or 10 years and every 50k after that
I have same car but changed fluid at 30k, 60k,100k,130k,180k.
Maybe you can use whatever's cheap to clean and flush and refill with genuine Toyota t4 on the final drain n fill.
My local shop uses Valvoline universal ATF.
Approaching 200k with no issues on universal fluid so I don't think this transmission is too picky.
I do think the original T4 was not a synthetic formula though.
04 Camry 2az-fe 209k
M1 5w30
PremiumGuard filter
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583321
11/24/17 01:39 AM
11/24/17 01:39 AM
Connecticut
69GTX Offline OP
69GTX  Offline OP
Connecticut
Good, detailed inputs. More to ponder than I thought....as always on Bitog. Thanks
1969 Ply GTX/RRs
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583323
11/24/17 01:56 AM
11/24/17 01:56 AM
Connecticut
69GTX Offline OP
69GTX  Offline OP
Connecticut
Wiki info
At least according to this link, the troublesome U140E is only on the V6's. The V4's got the U241E (no transaxle). No idea if those were troublesome too. The lower HP rating certainly was of benefit to the transmission. Toyota sure used a lot of different transmission in that era.
1969 Ply GTX/RRs
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583330
11/24/17 02:21 AM
11/24/17 02:21 AM
New Jersey
THafeez Offline
THafeez  Offline
New Jersey
I asked the same question about the car in my sig. Did a full change at 160k, and I think 168k. If its a 10mm hex plug on the pan make sure to hammer it in because thats the only way to properly seat it. Also get a new drain plug washer from the dealer as the old one I found was rusted. Most people I asked about this a year ago said that there's no need to change the pan filter. I used castrol import both times and it works just fine. I'd use any you put on your list, whichever is cheapest. Mind you I have no prior knowledge of anyone changing the fluid before I owned the car. First change it was black and after ~8k second change was also black. It has a 7 qt capacity so you're not getting all of the fluid out with a regular d&f. Some mechanics do a full flush through the trans cooler line, but I did not want to take that risk since I didn't know the history and it has 150k+. Next fluid change will probably be in a year or every other oil change until the fluid doesn't smell burned or look dark.
Link to my original question about tranny fluid https://bobistheoilguy.com/forums/ubbthr...ny_#Post4215475
2004 Toyota Solara SE 2.4 2AZFE
187,000 miles
Castrol Magnatec Semi-Syn 5W30 3 quarts and 1 quart of Valvoline Syn-Power 5W30 that I had left over
Fram Ultra XG3600 oversize 1st run
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583336
11/24/17 02:46 AM
11/24/17 02:46 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I always thought that trans fluid changed every 30K was the universal norm for all cars.
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: Merkava_4] #4583339
11/24/17 02:59 AM
11/24/17 02:59 AM
Connecticut
69GTX Offline OP
69GTX  Offline OP
Connecticut
But is that 30K pan drain and refill? Full flush via cooler line? Or? And if your OEM manual says it never needs changing, then what?
But I agree, 30K is pretty "universal" if you're shooting for 200K miles and up. My own 2002 Linc calls for 30K. Then again, I know people who swear by doing 15K-20K because the AX4N transmission can be problematic at 75K-125K miles if driven hard. One's driving style - heavy or light footed, highway vs. mostly stop and go, ambient temps, installed coolers, conv vs. synthetic etc. can all factor in so that one size might not fit everyone.
Thanks THafeez for your personal Solara input.
1969 Ply GTX/RRs
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583347
11/24/17 04:08 AM
11/24/17 04:08 AM
CA
The Critic Offline
The Critic  Offline
CA
I service a lot of these cars (Toyota's). I drain the pan, pull the cooler line and do a fluid exchange with 11-12 quarts of Toyota T-IV from the dealer. Toyota does not require replacement of T-IV under normal maintenance conditions, but I advise customers to replace (flush) at least every 60K miles. For the Toyota transmissions that require WS, I advise minimum every 100k but preferably every 60K. To date, have not had any issues with this routine. In fact, I have flushed several Toyota trans that still had the original fill of T-IV at almost 200k miles.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: Merkava_4] #4583361
11/24/17 06:07 AM
11/24/17 06:07 AM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
You couldn't be more wrong. That's a ludicrously low mileage interval for most vehicles. Many now have lifetime synthetic fluid though some debate that lifetime means closer to once every 100K mi. People who don't change their fluid at 100K, typically get around 250K without any problems. Except certain makes and models with bad design which is ironic because they thought they were buying for reliability.
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583371
11/24/17 07:04 AM
11/24/17 07:04 AM
New York
pbm Offline
pbm  Offline
New York
I've used Castrol IMV in a few Toyota's with zero issues. The newer Castrol Full Synthetic claims to "be suitable" for all Toyota A/Ts but I prefer the IMV because it's closer to the viscosity of T-IV.
'Journalism is Dead'
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583438
11/24/17 09:24 AM
11/24/17 09:24 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
It needs a complete exchange including filter. But I would not get involved. Suggest he take it to a Indy shop or Indy transmission shop or dealer. A JiffyLube will not change the filter, they may even say their flush cleans the filter (it does not).
You want OEM ATF or a high quality ATF that specs the Toyota spec. Some places use a generic ATF with an additive for Toyota. Avoid that.
2015 Ford F250 w/Powerstroke
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583439
11/24/17 09:25 AM
11/24/17 09:25 AM
BerksCounty/Pa.
thorromig Offline
thorromig  Offline
BerksCounty/Pa.
I had a 2004 Camry XLE with the 2.4L & auto trans. I would use the Toyota Type 4 tranny fluid to just do drains & fill with 3 quarts of tranny fluid at 30K intervals. Tranny shifted smoothly at all times. Aunt bought the car brand new & she was a fanatic about maintenance.
00 Dodge Ram 5.2L 4x4 Edge 10W30 FU (91K)
08 Acura TL Type S 3.5L PUPP 5W20 FU (101K)
17 Jetta TSI SE 1.4L Turbo - Edge 0W40 FU (Hers) (4K)
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583442
11/24/17 09:31 AM
11/24/17 09:31 AM
USA
slacktide_bitog Offline
USA
Use Maxlife smile
Re: What ATF & periodicity for 2002 Camry 4 cyl? [Re: 69GTX] #4583455
11/24/17 09:48 AM
11/24/17 09:48 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
The car is easy to do changes with the drain plug, so why not drain and refill periodically. I would use only Toyota T IV, the others are not the same. Look on the specs, they have other vehicles listed. If they say only for Toyota, then OK. It does make a difference I found on an 02 Camry v6 that had previously been Jiffy and Firestone lubed. The one size fits all's are not the same.
