Modern Engine's Grenading?
by Nickdfresh. 12/17/18 11:15 AM
Magnetic Smartphone Holders
by willbur. 12/17/18 11:06 AM
1991 Caprice 5.0l hard starting in the AM
by WyrTwister. 12/17/18 10:55 AM
Question about new Peak OEM coolants
by PD001. 12/17/18 10:21 AM
Rev X
by Big_3_Only. 12/17/18 10:04 AM
Cleanliness
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
114 registered members (atikovi, 911Don, bdcardinal, badtlc, ARB1977, ArrestMeRedZ, 11 invisible), 2,101 guests, and 48 spiders.
Topics295,182
Posts4,929,363
Members66,700
Most Online2,553
Oct 27th, 2018
Not cleaning rimfires ? #4582586
11/23/17 03:33 AM
11/23/17 03:33 AM
'Stralia
Shannow Offline OP
Shannow  Offline OP
'Stralia
Had the Krico (will have owned it 35 years in 32 days time) out at the range yesterday arv.
I grew up putting 50-100 rounds a year through it, rabbit hunting. cleaned it religiously after every outing...1996 after Oz' Port Arthur and compulsory registration and licencing contingent on joining a club, I shot LOTS more through it, but still cleaned it every week after shooting.
Always took a couple of "foulers" in order to shoot OK, but my wife's Microgroove Brno always outshot it.
Read the discussions on other forums about the military rimfire teams not cleaning, so that the wax on the bore remained stable for next time.
So haven't cleaned it in 4 trips over six months (by cleaning, I mean cleaning, I use a loose patch to push the powder residue out).
Yesterday, it hit smack on very first shot, and put 30 Winchester 42gr subsonics into the centre 1" square at 50 metres in a row...honestly, it has never shot that well.
Change ammo, change point of impact for some ammos (CCI minimag a LOT...and wild)...CCI blue box didn't move it, just like my wife's Brno (teh fact that both rifles are interchangeable on those two staples is good).
Maybe I would have been MUCH better at hitting rabbits in the day if I'd cut back on the cleaning...was always worried about the storing the rifle for 4 months.
Got a couple of misfires towards the end, maybe 500 rounds into the new regime, but over 6 months...rinsed the bolt in my "two stroke" of wax and grease remover and ATF. The firing pin is light, as is the spring on the Krico.
So I'm a convert, leave the wax in the bore.
Re: Not cleaning rimfires ? [Re: Shannow] #4582593
11/23/17 05:03 AM
11/23/17 05:03 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Somewhat unrelated, but I thought guns were banned in 'Straya?
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Not cleaning rimfires ? [Re: dlundblad] #4582595
11/23/17 05:10 AM
11/23/17 05:10 AM
'Stralia
Shannow Offline OP
Shannow  Offline OP
'Stralia
There's more guns in Oz now than before the bans.
They never got half of the target guns in the 1996 era, but many left the sport. Many of us were forced into joining gun clubs, and I know many who went from a .22 with 50-100 rounds per year to 4-5 guns, and 3-4,000 rounds per year, as a result of having to join a club to keep their 15 y.o. birthday present.
There's always continued and ongoing onslaught of legislators...e.g. pump and auto shotguns banned...works well for 20 years until the media find out that there's lever action shotguns out there, which they portray as a loophole, get facebook thumbsup, and it's same old all over again.
Yes, there are gun owners in Oz.
Re: Not cleaning rimfires ? [Re: Shannow] #4582597
11/23/17 05:15 AM
11/23/17 05:15 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Good to know. Thanks for the info.
Re: Not cleaning rimfires ? [Re: Shannow] #4582605
11/23/17 05:37 AM
11/23/17 05:37 AM
MA.
Camprunner Offline
Camprunner  Offline
MA.
I shoot competition with .22 Rimfire rifle and I build custom Ruger 10/22 rifles with custom barrels and chambers. I have read extensively on this subject and also talked to several rifle manufacturers. The real issue with cleaning is the wear on the chamber not so much the barrel bore unless you are cleaning it wrong then the barrel bore could get damaged. Cleaning the bore is a "Sweet spot" with a .22 once you match the ammo to the barrel you have to experiment with how many rounds you can get away with before accuracy drops off. What wears out most barrels is the powder in the .22 bullet actually hardens and collects on the bottom of your barrel bore.
Now for proper cleaning I do not recommend using a rod and patch on a quality barrel it is just to easy to mess up and damage the barrel or the throat/chamber of the barrel. Use either a bore snake or some weed wackier line with a knot on one end and small patches run one with solvent then one dry and I like to do one run with Remoil or simple gun oil. Every time you run a brush down your barrel it wears the throat of the barrel where the bullet sits before ignition and over time it will wear to a point where it will effect accuracy.
On a side note many .22 rifles shoot best with barrels between 16" to 18" long especially bull barrels why? Because.22 ammo powder is all used up at about 12" inches the rest is just gravy. And short bull barrels are real stiff with less vibration. I hope this helps.
Re: Not cleaning rimfires ? [Re: Shannow] #4582616
11/23/17 06:28 AM
11/23/17 06:28 AM
Texas,USA
ATex7239 Offline
ATex7239  Offline
Texas,USA
Iím not particularl about cleaning my guns and itís never done any harm. So long as youíre not shooting corrosive ammo itíll been fine.
Heck, come to think of it, I think Iíve only ever cleaned my .22 rifle once, which was when I first got it. And Iíve shot it gobs of times with no issue.
'12 Buick Enclave 150,xxx
Valvoline ML SynBlend 5w30
ACDelco PF63E
'17 Ford Fusion (Company Lease) 54,xxx
Oil ÔŅĹ Don't know
Filter ÔŅĹ Don't care
Re: Not cleaning rimfires ? [Re: Shannow] #4582621
11/23/17 06:41 AM
11/23/17 06:41 AM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
I think the biggest thing to keep clean on .22's is the action, more so than the barrel. Especially on semi autos. Most .22 ammo is FILTHY and really can gunk up a gun quickly. I simply wash them out in clean Kerosene, and give them a good blowing with compressed air. Then lubricate. For the barrel I just run an oily patch down the bore.
Re: Not cleaning rimfires ? [Re: Shannow] #4582643
11/23/17 07:20 AM
11/23/17 07:20 AM
Pennsylvania
Slick17601 Offline
Slick17601  Offline
Pennsylvania
Anschutz only recommends cleaning the bore every 5,000 rounds. They are final word in rimfire accuracy.
2018 Ram Bighorn 5.7
2008 Toyota Sienna 3.5
Re: Not cleaning rimfires ? [Re: billt460] #4582701
11/23/17 08:50 AM
11/23/17 08:50 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
I have noticed this, particularly on anything with a short barrel like a 22 pistol. I have a 22 caliber slide conversion for my SIG P220 and when I shoot rimfire.. boy there's all sorts of unburned powder all inside the frame of the pistol.
Re: Not cleaning rimfires ? [Re: Shannow] #4582704
11/23/17 08:55 AM
11/23/17 08:55 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
I run a CLP'd Boresnake only. My .22's have never seen a rod.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Not cleaning rimfires ? [Re: billt460] #4582705
11/23/17 08:57 AM
11/23/17 08:57 AM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
I agree and I was going to say clean the action and the chamber. A clean action and chamber will keep the gun reliable. For basic cleanings in between shooting sessions, A CLP type product with a few passes with a bore snake is more than good enough while being gentle.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: Not cleaning rimfires ? [Re: Shannow] #4582744
11/23/17 09:39 AM
11/23/17 09:39 AM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
I've had .22's I've cleaned regularly and some I didn't clean much at all, and it never seemed to make a difference.
Re: Not cleaning rimfires ? [Re: Shannow] #4582769
11/23/17 10:10 AM
11/23/17 10:10 AM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
cool to hear you have a brno..i have a brno model 4 and a few cz 452 models..they all go about 1k between bore cleanings..most shoot better this way, altho one cz shoots great right away after a cleaning.
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: Not cleaning rimfires ? [Re: LotI] #4582791
11/23/17 10:37 AM
11/23/17 10:37 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
LOL do you step on your Boresnake to drag it through the barrel. I hear that dirt from you shoes and the ground does wonders for the crown and bore. I can't tell you how many people I've seen people do this at the range. When you ask them about it the just get this blank stare on their face.
2004 Corolla 126884
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Not cleaning rimfires ? [Re: Slick17601] #4582816
11/23/17 11:00 AM
11/23/17 11:00 AM
Canada
i_hate_autofraud Offline
Canada
That's more specific to Anschutz.
I don't know if most folks will shot 5,000 rnds on a single gun, that seems like a lifetime.
Last time I ran a patch thru a .219 Zipper barrel it came out green, meaning there was
old copper in the rifling. Lots of .22 loads have a thin copper plating that'll do the same thing.
