A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
92 registered members (94astro, 2010Civic, ABomb369, askani79705, Ablebody, Al, 6 invisible), 1,316 guests, and 50 spiders.
Topics290,702
Posts4,848,575
Members66,021
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
'16 F150 2.7 Ecoboost #4582076
11/22/17 04:52 PM
11/22/17 04:52 PM
oh
roadrunner1 Offline OP
oh
This is the third OC on this truck, all following the IOLM.
Oil in sample is Citgo SuperGard 5w-30, which is labeled as a syn.
The oil and filter were changed at the time of sampling, I used the same Citgo SuperGard and MotorCraft filter.
9,190 mi. on sample
29,190 mi. total on truck.
Fe...............30
Cr...............<1
Pb...............<1
Cu................4
Sn...............<1
Al................4
Ni...............<1
Ag...............<1
Ti...............<1
V................<1
Si...............30
Na................2
K................<1
Mg...............14
Ca.............2045
Ba...............<1
P...............712
Zn..............719
Mo.............. 35
B................<5
Viscosity cST 100C........7.3
Fuel.......................3%
Viscosity is low, but wear levels remain in check. I will continue to follow the IOLM as long as wear metals remain in check.
'15 F350 6.7
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4582125
11/22/17 05:49 PM
11/22/17 05:49 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
It bothers me that the viscosity has dropped out of the 30 range, and that fuel dilution is 3%. 9.3 cSt is the low limit for 30 weight, so 7.3 is 20% below that. Maybe you should talk to your dealer about the fuel dilution, which is also contributing to the loss in viscosity; what is acceptable on the Ecoboost? Is 5w30 the recommended viscosity for the 2.7 Ecoboost? I would consider going to an oil thick enough to keep viscosity in the 30 grade at the end of an OCI.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4582153
11/22/17 06:16 PM
11/22/17 06:16 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I'd try to get the iron number down with a different 5W-30. Maybe the Castrol 5W-30 Euro A3/B4.
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4582221
11/22/17 07:29 PM
11/22/17 07:29 PM
oh
oh
At 9,190 mi. an Fe # of 30 is not high. I don't like the lowered viscosity either, but wear numbers seem to be in check. I will sample at next OC and see if fuel dilution has settled in at this level, as long as wear rates stay at an acceptable level there really isn't an issue.
'15 F350 6.7
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4582274
11/22/17 08:22 PM
11/22/17 08:22 PM
SE Texas
2015_PSD Offline
2015_PSD  Offline
SE Texas
As compared to what? Another engine in that family or another engine from a different family or other manufacturer?
2018 MB AMG GLC43 3.0L Coupe - Castrol 0W-40/Purflux
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 15W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4582376
11/22/17 09:32 PM
11/22/17 09:32 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That may be but why not try to bring the number down anyway ? Plenty of oil brands out there.
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4582427
11/22/17 10:12 PM
11/22/17 10:12 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Id run a shorter interval on same product or change oil brands like Merkava said and do another OCI with 9190 or as close to that mileage as possible for comparison. Did you get the truck on a good run prior to changing the oil? Is it short tripped alot? These might be the indicators and might reflect the need to reduce the oil change interval if another oil gives you similar results. Maybe need to reduce to 7k mile changes instead of 9...
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4582467
11/22/17 11:03 PM
11/22/17 11:03 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
Roadrunner,
Is this the first UOA on this truck?
Re: '16 F150 2.7 Ecoboost [Re: bigj_16] #4582577
11/23/17 03:45 AM
11/23/17 03:45 AM
oh
oh
Originally Posted By: bigj_16
Roadrunner,
This is the second UOA, and I forgot to add TBN of 2.1.
I bought this new and it gets driven round trip of 45 mi. daily in mixed city highway. It also serves as a delivery truck delivering light loads.
3 ppm per 900 mi. of Fe is not high in any engine family.
'15 F350 6.7
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4582610
11/23/17 06:54 AM
11/23/17 06:54 AM
SE Texas
2015_PSD Offline
2015_PSD  Offline
SE Texas
I did not realize it was only the second UOA, so higher FE readings would be expected. It should drop as wear metals wash out. Long term, 3PPM would be double what I have experienced per 1000 miles. Splitting hairs in the end though, it is parts per million.
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4582857
11/23/17 12:42 PM
11/23/17 12:42 PM
The Garden State
Whimsey Offline
Whimsey  Offline
The Garden State
Just curious, did you check the iOLM to see what % oil life was indicated at the 9190 miles. I'm betting that it was showing about 10% life left. The iOLM in our Explorer seems to drop 10% for every 1000 miles driven, no matter the driving conditions are.
Whimsey
Re: '16 F150 2.7 Ecoboost [Re: Whimsey] #4583055
11/23/17 05:17 PM
11/23/17 05:17 PM
oh
oh
Whimsey
I did and it was at 2%.
'15 F350 6.7
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4583240
11/23/17 10:02 PM
11/23/17 10:02 PM
Buffalo, NY
Nickdfresh Offline
Nickdfresh  Offline
Buffalo, NY
I would cut down the OCI to 7,500. Oil is cheap with rebates and I think you'd see better wear numbers and lower fuel dilution...
I agree the iron is nothing to be particularly worried about...
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4584206
11/25/17 07:59 AM
11/25/17 07:59 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
rr1 -
I don't have enough data on these newer little engines yet, but given it's only 30k miles "new", and your OCIs are around 9-10k miles, this is probably a bit of break in lingering.
I hear good things about the performance of these little units; how do you like it?
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: '16 F150 2.7 Ecoboost [Re: roadrunner1] #4584333
11/25/17 10:30 AM
11/25/17 10:30 AM
US
TheOilWizard Offline
US
Is anyone else alarmed by the extremely low viscosity?
Page 1 of 3 1 2 3
