Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
Door Hinges
by Scrum67
06/23/18 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
06/23/18 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
Super Tech Conventional 15w40 HDEO. CK-4/SN
by Snagglefoot
06/23/18 09:38 AM
1 gallon jug of Sta-bil for $7 at Rural King
by classic70
06/23/18 09:34 AM
Anger on BITOG
by Gebo
06/23/18 08:55 AM
2010 Acura MDX w/ 3.7 lire oil consumption issue
by Varbill
06/23/18 08:45 AM
Surprising oil filter service interval.
by jakewells
06/23/18 08:12 AM
World Population
by CourierDriver
06/23/18 08:11 AM
SBC Finned Aluminum Dress Up Kit $32
by hatt
06/23/18 07:35 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
73 registered (93cruiser, Atesz792, 2015_PSD, 1998CamryCE, AP9, AZjeff, 9 invisible), 1583 Guests and 37 Spiders online.
65303 Members
67 Forums
285855 Topics
#4581773 - 11/22/17 10:41 AM Same tire, same price, different speed rating...
RoGuE Offline
Loc: Atlanta, GA
I'm looking at getting some General Altimax RT43s from Discount Tire for my Malibu, and they have the T and H speed ratings available for the same price. They are the same except for some minor differences. The T has 44 max psi, B temp grade, and 75k mile warranty. The H has 51 max psi, A temp grade, and 65k mile warranty. The mileage doesn't matter enough as I don't drive enough mileage before they need to be replaced from age anyway. From what I understand, the H may be a stiffer tire making the car ride stiffer.
For the same price which would you guys get?
2007 Chevrolet Malibu
2.2L Ecotec
#4581779 - 11/22/17 10:49 AM Re: Same tire, same price, different speed rating... [Re: RoGuE]
SatinSilver Offline
Loc: OH
I have the T rated on the Camry which gets better winter weather traction ratings than the higher speed rated versions. The only thing I don't like about it is the B temp rating since I can see the psi fluctuations inside the car on a monitor. Kind of annoying esp in summer when trying to get the psi correct. But all in all happy with the tire. You can hear a tiny bit of noise from the tread as you're driving but hardly worth mentioning. Ride isn't too soft either. Have about 18k on them and tread looks like new.
The CR buying guide that just came out ranks it highly and on their recommended list.
Edited by SatinSilver (11/22/17 10:51 AM)
#4581785 - 11/22/17 10:57 AM Re: Same tire, same price, different speed rating... [Re: RoGuE]
IndyIan Offline
Loc: Ontario, Canada
Capriracer and others here recommend an H speed rated or higher tire as they usually have a cap belt which makes them much less likely to have an internal belt failure. For me I'd get the T rated tire on the CRV for the floaty ride and the H rated on the Focus to help it handle.
07 Focus ZXW, 5spd manual, 206km M1 5W30
18 Outback 2.5 CVT 5km FF
#4581822 - 11/22/17 11:36 AM Re: Same tire, same price, different speed rating... [Re: RoGuE]
Traction Offline
Loc: iowa
A V speed rating is what I like to use. Have had 3 4cylinder Camry's since 2001, and they all came from the factory with V rated tires. I ran a set of H-rated on the 07 I had and it had much less straight line tracking for one. Always chasing the steering wheel back and forth. Did not do that with any of the V tires I've tried with several different brands.
Edited by Traction (11/22/17 11:37 AM)
Tire Industry Association Certified Tire Service Instructor since 2009
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
12 Camry
81 Camaro
55 Chevy C4
#4581858 - 11/22/17 12:09 PM Re: Same tire, same price, different speed rating... [Re: IndyIan]
PandaBear Offline
Loc: Silicon Valley
Many T rated tires also have the cap ply now too. I checked before I bought my Yokohama Avid Ascent in T because it has the same internal structure as the H.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#4581905 - 11/22/17 01:10 PM Re: Same tire, same price, different speed rating... [Re: RoGuE]
raytseng Offline
Loc: CA
higher rating
if specs are exactly the same physical properties sometimes its the exact same tire layup except ones that tested to be slightly inferior get binned to be Ts.
#4581942 - 11/22/17 01:43 PM Re: Same tire, same price, different speed rating... [Re: raytseng]
Wolf359 Offline
Loc: MA
Originally Posted By: raytseng
higher rating
I think that usually applies in electronics, but with tires, I would think the compound would be different. Possibility construction too. That's why you get a longer treadwear rating on the lower speed rating, a harder compound that lasts longer.
I usually go for the T speed rating over the H. T is good for 118 and tested at that speed for 70 minutes. Don't intend to go anywhere need that fast and I'm not taking corners at that high speed so don't really need the extra traction that an H rated tire would give you. But if you don't intend to get the full mileage out of the tire, I'd go for the H rating.
#4582069 - 11/22/17 03:43 PM Re: Same tire, same price, different speed rating... [Re: RoGuE]
slacktide_bitog Offline
Loc: USA
I would get the H
#4582626 - 11/23/17 06:50 AM Re: Same tire, same price, different speed rating... [Re: slacktide_bitog]
ET16 Offline
Loc: MD
Originally Posted By: slacktide_bitog
I would get the H
Me, too.
#4587375 - 11/28/17 10:03 AM Re: Same tire, same price, different speed rating... [Re: Wolf359]
RoGuE Offline
Loc: Atlanta, GA
The tires on there now are V rated Kumho Ecsta ASXs (great deal on them because they were being discontinued) and they've never been a very great ride, and I think one of them is out of round now or has a slipped belt (feels like a square tire at exactly 20-30mph).
higher rating
Yeah, I have no intentions of taking this car that fast, lol. But I only drive 5-6k miles per year so the tires will rot out long before I reach 65k miles.
I went ahead and ordered the H rated. $70 a piece which I think is a pretty decent price. Should be $388 out the door and $75 less after rebate.
2.2L Ecotec
#4587599 - 11/28/17 12:57 PM Re: Same tire, same price, different speed rating... [Re: RoGuE]
nthach Offline
Loc: California
The T-rated tire will use a tread compound that places emphasis on wear instead of traction. The ply layup might be the same, I know Dunlop made to Toyota specs a T-rated version of the SP Sport 4000 for the 2004-2009 Siennas and the plies/tread was the same as the V-rated version used on the V6 Camrys and Lexus LS430s.
Michelin did make the Defender in some H-rated sizes, now the replacement for it is almost all H-rated.
#4588448 - 11/29/17 07:25 AM Re: Same tire, same price, different speed rating... [Re: nthach]
CapriRacer Offline
Loc: Somewhere in the US
Just to clear up a possible misconception.
As a general rule, S and T rated tires do not need a cap ply - typically made of nylon. H rated tires generally need a single cap ply, and V and higher rated tires need 2.
So the ply layup is very likely different between T, H, and V rated versions of the same make and model. This would be in addition to the tread compound difference.
CapriRacer
Visit my web site: www.BarrysTireTech.com
