Replaced halogen headlight with LED
by gman2304
24 minutes 48 seconds ago
Web Archive
by Duffyjr
Today at 10:25 AM
Sonoma This weekend!
by racin4ds
Today at 10:22 AM
low water pressure on new kitchen faucet
by Joe1
Today at 09:40 AM
Flashing third tail light
by Brigadier
Today at 08:59 AM
Intermittent AC Cooling
by Gebo
Today at 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
Today at 08:45 AM
Crude and foul behavior
by mjoekingz28
Today at 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
Today at 08:30 AM
Wrecking Yards
by Snagglefoot
Today at 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
Today at 08:14 AM
AAP 25% Off
by Egg_Head
Today at 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
Today at 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
Today at 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
Today at 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
Yesterday at 10:41 PM
Chevy brought the blazer back
by WiskyBadger
Yesterday at 10:07 PM
LC20 and uses in modern motor oil
by synman
Yesterday at 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
Yesterday at 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
Yesterday at 08:37 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
74 registered (2012AccentSE, 4WD, bdcardinal, asiancivicmaniac, Al, beanoil, 4 invisible), 1470 Guests and 37 Spiders online.
65294 Members
67 Forums
285764 Topics
#4581707 - 11/22/17 08:53 AM Top off ATF
ECUADOR4X4 Offline
Loc: Ecuador
Hi everyone, i have a Chevrolet Captiva, the tranny uses DEXRON VI compliant ATF, it is ok to top off with DEXRON III? Im asking this since where i live its hard to find DEXRON VI, and i need to top off a little. Thanks!
#4581712 - 11/22/17 08:59 AM Re: Top off ATF [Re: ECUADOR4X4]
khittner Offline
Loc: Michigan
May not hurt, but probably not a good idea; Dexron III is not "forward compatible" with Dexron VI.
Perhaps more important: Why do you need to top off ATF in a vehicle as new as a Captiva?
Edited by khittner (11/22/17 09:01 AM)
#4581724 - 11/22/17 09:16 AM Re: Top off ATF [Re: khittner]
Egg_Head Offline
Loc: North Carolina
I would say any possible harm (if there is any) that would come by topping off with DEX III is far outweighed by the harm of running low ATF levels.
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
#4581737 - 11/22/17 09:45 AM Re: Top off ATF [Re: Egg_Head]
Kira Offline
Loc: Champlain/Hudson Valley
Get the right stuff.
How far away from civilization could you possibly be?
How low could you be?
Give your old Dex to a friend who can use it.
#4581768 - 11/22/17 10:34 AM Re: Top off ATF [Re: ECUADOR4X4]
MolaKule Offline
Loc: Iowegia - USA
Are we to assume you have leaks?
Get a new gasket and seals installed and you shouldn't need to top off.
What ATF products do you have access to in Ecuador?
For sure.
#4581781 - 11/22/17 10:51 AM Re: Top off ATF [Re: ECUADOR4X4]
WyrTwister Offline
Loc: Texas
Can you order Dexron 6 ? Can you do Amazon or one of the other internet vendors ?
Is there a GM dealer close enough to get Dexron 6 , there ?
I agree , if you have a leak , get it fixed & make sure the mechanic uses Dexron 6 . How much are you needing , any way ?
Just found this with a google search ;
https://search.yahoo.com/search?ei=utf-8...pe=54431_021017
Best of luck to you , :-)
Wyr
God bless
Wyr
God bless
#4581850 - 11/22/17 12:00 PM Re: Top off ATF [Re: ECUADOR4X4]
PandaBear Offline
Loc: Silicon Valley
What is the reason it runs low? Was there a leak or did you replace the radiator? I'll be more concerned about why it runs low.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#4581907 - 11/22/17 01:11 PM Re: Top off ATF [Re: ECUADOR4X4]
Solarent Offline
Loc: Toronto ON
Do not top off with Dexron III.
The viscosity profile is completely different, as are the friction materials and additives in the formulas. Use a Dexron VI fluid.
#4582249 - 11/22/17 07:01 PM Re: Top off ATF [Re: Solarent]
Egg_Head Offline
Loc: North Carolina
Are you checking the fluid level when the tranny is at full operating temperature, engine running and on level ground? This could show a lower level if temp is not warm enough and running.
#4582977 - 11/23/17 01:50 PM Re: Top off ATF [Re: ECUADOR4X4]
MaximaGuy Offline
Loc: Austin, TX
Throw in some DexIII and call it a day
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
