2002 Toyota 4runner
Illinois
Hello friends,
Back again for more advice. Helping my brother chnage the oil on his vehicle soon and he has no idea what’s the correct oil to use. Luckily he has been using the correct viscosity, but buys whatever is cheapest. Can’t blame him for that. So , with that being said what oil do you guys recommend for the following application.
2002 Toyota 4 runner SR5
3.4 V6 165k miles
OCI ~ 7k. Daily driver :20 miles daily
Chicago Illinois
Thanks!!!
I don't think Toyota has a spec beyond whatever API was current, and 5w-30. I don't even think is spec's a synthetic.
So whatever is good for the goose.
I like pennzoil for purely marketing reasons.
Maybe a 0w for the cold winters? Is it 20 miles of in city driving?
Hello,
Yes sir, Its city driving. Chicago’s terrible stop and go traffic and brutally cold winters.
The 5VZ-FE is durable engine. Keep up on maintenance, and they can run for longer than most people will want to own them. Any reputable 5w30 is fine.
The biggest concern on the 3rd gen 4Runner, are the lower ball joints. They are mounted in tension, and after many years of use can fail with bad consequences. I have yet to see an aftermarket LBJ that is made is well as the OEM LBJ's. So my advice is to check them and if questionable, replace them with OEM LBJ's only. In fact, at that mileage I'd replace them regardless.
And for the other fluids follow that page...
http://www.roughtrax4x4.com/blog/land-cruiser-kzj90-kzj95-1996-2002-vehicle-specifications/
http://www.roughtrax4x4.com/toyota-4x4-parts/service-parts/fluids-oils.html
75w90.....gearbox&transfer
https://www.opieoils.co.uk/p-973-fuchs-titan-gear-syn-75w-90-semi-synthetic-driveline-oil.aspx
Quote:
Technical Information:
Colour Visual Clear amber
Kinematic Viscosity at 100ºC IP71 16.2 mm2/s
Kinematic Viscosity at 40ºC IP71 95 mm2/s
Viscosity index IP226 175
Flash point (PMCC) IP34 200ºC
Specific gravity at 15.6ºC IP160 0.889
Pour point IP15 - 40ºC
80w90.....differential
https://www.opieoils.co.uk/p-972-fuchs-titan-gear-hyp-90-hypoid-gear-oil-gl5-80w-90.aspx
Density at 15ºC DIN 51757 0.902
Colour DIN ISO 2049 3 ASTM
Flash Point CoC DIN ISO 2592 210°C
Pour Point DIN ISO 3016 -24°C
Neutralisation Number FLV-N7/DIN 51558 2.5 mgKOH/g
Foaming Tendency Seq I/II/II ASTM D 892 0/0 : 0/0 : 0/0 ml
Dynamic Viscosity at -12°C DIN 51398 23,000 mPas
Kinematic Viscosity at 100ºC DIN 51562-1 17.2 mm2/s
Kinematic Viscosity at 40ºC DIN 51562-1 185.0 mm2/s
Viscosity Index DIN ISO 2909 91
M1 5w-30
Penzoil platinum 5w-30
Castrol Magnatec 5w-30
Valvoline MaxLife in the red bottle 5w-30
Penzoil has mail in rebates right now. Mobil also runs rebates a couple times a year
That engine doesn't need anything fancy as long as the oil is changed at a reasonable interval. Use a Fram tough guard or Fram ultra oil filter.
If it was mine I'd go with M1 HM 10w-30
Concur with all the previous 5w30 suggestions. The 5VZ is neither picky about nor hard on oil. A 5w oil is more than sufficient for winters in Chicago and arguably anywhere in the continental US. A 0w is not required for what he's doing. A good friend of mine back in Detroit has a 96 4Runner with the same engine that he uses for his courier service he does 10k oil changes with a filter every other change using Super Tech 5w30, last time I was home he had over 600,000 miles on the engine. The only thing he's ever done to it is tune ups valve cover gaskets and timing components. My personal choice would be Valvoline Max Life 5w30, red bottle.
Would anyone recommend 10k OCI with 50% city/50% highway using M1 5w30 in the same engine?
how about 30% city and 70% highway?
2002 TOYOTA 4-RUNNER 3.4L 6 -cyl Engine 5VZ-FE
VISCOSITIES:
All TEMPS....5W-30
Above 0 F .10W-30
CAPACITIES: With filter 5.5 quarts After refill check oil level.
TORQUES: Oil Drain Plug...27 ft/lbs
Source: Amsoil
Mobil I 5W-30. Saw in a weekly flyer this week that our local Bomgaars is selling Mobil I 5W-30 five quart jug a dollar less than our Walmart. Enticement for Black Friday shoppers.
