Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
94 registered members (ArrestMeRedZ, alarmguy, Ag76, 2006dodge2500, avi1777, 14 invisible), 1,797 guests, and 57 spiders.
Topics286,387
Posts4,907,368
Members67,614
Most Online2,967
Mar 10th, 2019
Balance Beads for my new tires #4581245
11/21/17 06:42 PM
11/21/17 06:42 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
I apologize in advance if this topic has been discussed already, but does anyone use balancing beads in their tires? The reason I asked is I just bought 2 new tires for my car and instead of putting weights on them I asked for plastic beads instead. I did some reading on them and thought it was a great idea, as in the future I will be mounting my own tires and this seems to be a great way to balance them. So far the tires run true, balanced and can't tell the difference from wheel weights. Decided to share this with you guys and ask what your thoughts are on the topic?
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Balance Beads for my new tires [Re: A310] #4581263
11/21/17 07:03 PM
11/21/17 07:03 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I thought they only work for larger tires as on a semi or maybe a pick up or SUV with a large diameter wheel assembly?
Me: 13' VW GTI 3 door 6 speed manual
Re: Balance Beads for my new tires [Re: skyactiv] #4581268
11/21/17 07:09 PM
11/21/17 07:09 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
They are sold and used for motorcycle tires so I don't think there are any limits.
However, it seems like the right amount of beads should be used for a given application.
I tried them on my Suzuki bike a while back but it didn't seem to work. Maybe I didn't use enough? They were an absolute pain to try to remove. Went back to clip on lead weights.
Re: Balance Beads for my new tires [Re: A310] #4581358
11/21/17 08:45 PM
11/21/17 08:45 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
From what I can find even makers of balancing beads say to not use them in smaller tires.
https://checkeredflagtirebalancebeads.com/questions-and-answers/
1. Will beads work with all tires?
Not with Sidewall ratios of 65 or less…..This type of tire often have a left to right dynamic balance issues only correctable by spin balancing.
yup
Re: Balance Beads for my new tires [Re: A310] #4581381
11/21/17 09:01 PM
11/21/17 09:01 PM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
I have beads in my Toyota pickup tires. They don't vibrate horribly but they just aren't quite right and don't compare with conventionally balanced tires. It could be that I don't have the right amount but I carefully followed the directions.
They aren't bad enough that I want to remove the beads but I don't think I'll use beads again.
Re: Balance Beads for my new tires [Re: A310] #4581390
11/21/17 09:07 PM
11/21/17 09:07 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I tried using them in my 4Runner with a previous set of wheels which had a tiny lip and loved to throw wheel weights. I wasn't ever pleased with their performance. I used Dynabeads and messed around with them for about 15,000 miles before I finally gave up on them, had to break the tires down to remove them and eventually go back to standard weights. Hopefully you have better luck but I won't bother again in the future.
Luke
Re: Balance Beads for my new tires [Re: A310] #4581409
11/21/17 09:32 PM
11/21/17 09:32 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I've never personally used them, but have seen read of decent results on motorcycles. Another option is Ride-On (I also have never used it), which has a bonus benefit of sealing small punctures as well.
http://www.ride-on.com/
Re: Balance Beads for my new tires [Re: EdwardC] #4581453
11/21/17 10:31 PM
11/21/17 10:31 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I've seen a description of a homebrewed version using latex and "twinkle" flakes. Only described as a sealant, but I'd guess it might balance as well.
Re: Balance Beads for my new tires [Re: A310] #4581466
11/21/17 10:50 PM
11/21/17 10:50 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Does anyone have any experience with Ride-on? It kind of sounds too good to be true.
Re: Balance Beads for my new tires [Re: A310] #4581470
11/21/17 10:56 PM
11/21/17 10:56 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Saw a split sac of plastic beads on the campus dump, (I think probably for injection moulding) but couldn't think what I could use them for. Might go and scoop some up.
There's also a local park where they do airsoft shoot outs so there are a lot of beads lying around, but I THINK they are ceramic, which might not be suitable.
Re: Balance Beads for my new tires [Re: A310] #4581518
11/22/17 12:31 AM
11/22/17 12:31 AM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
I've used them in wheels 16 inch and up (to 22.5" semi wheels) and they work..but work better in larger tires. I use the Counterract brand and they have a different bead for motorcycle wheels..may try them in the next set of 16"'s I do..because I'm not sold on them in that small a wheel.
HDEO in Diesel Engines. No spark plugs here.
Re: Balance Beads for my new tires [Re: A310] #4581541
11/22/17 01:36 AM
11/22/17 01:36 AM
Georgia
AVB Offline
AVB  Offline
Georgia
I have steel bb's in my rear tires on my truck. They seem to balance ok, but make a heck of a racket when you go slow.
Re: Balance Beads for my new tires [Re: OneEyeJack] #4581547
11/22/17 02:07 AM
11/22/17 02:07 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Why so?
If beads distribute under centrifugal force, a liquid should also.
Just has so be something that won't set, doesn't evaporate, and doesn't attack rubber.
Hmm... that is actually a bit tricky. I THINK latex would set eventually. Molasses would attract ants.
That silicon putty stuff might work but it goes hard under shock loads. Perhaps you could use that behaviour to let you down gently after a blowout?
Rats! Another patent idea gone forever.
Re: Balance Beads for my new tires [Re: A310] #4581709
11/22/17 09:56 AM
11/22/17 09:56 AM
Ontario, Canada
AdamZ Offline
AdamZ  Offline
Ontario, Canada
I used them on my 33" BFGoodrich km2. They work great, and now if I have a little mud in the wheel it doesn't really throw the balance off for the 6 hour drive home from a camping trip.
94 Nissan Pathfinder 493k km R.I.P.
95 Nissan Pathfinder 200k km
02 Nissan Xterra SC 170k km
04 VW Golf 2.0 245k km
Re: Balance Beads for my new tires [Re: Jimzz] #4581826
11/22/17 12:41 PM
11/22/17 12:41 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Ah, so they only do static balance. Would not recommend at all then.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
