Digital Torque wrenches
Ndx
IL
Hi Guys,
Any recommendation on Digital Torquewrench?
3/8
Something that will be accurate at
37ft lb
19 ft lb
So 15-40 ftlb great accuracy ...
Thank you
There's no point in getting a digital torque wrench unless you need to set angles for Torque-To-Yield fasteners. And if that's the case, the only digital torque wrench I'd recommend is $nap-on.
cdi...who make a good chunk of all snap on wrenches.
i will say i like split beam the best...digital is not needed.
Originally Posted By: Ndx
Hi Guys,
So 15-40 ftlb great accuracy ...Thank you
I don't think that an electronic digital torque wrench exists in that range. 1/4" wrenches only go up to about 24 ft. lbs. max. and 3/8" wrenches all seem to go up to 100 ft. lbs., making them inaccurate below 20 ft. lbs. (20% of scale).
You will have to buy two digital wrenches to cover that range.
A 75-80 ft. lb. micrometer torque wrench would fit your criteria. Here's an example of a good one: https://www.amazon.com/CDI-752MFRMH-Torque-8-Inch-Micro-Adjustable/dp/B002L9Z27E or https://www.protorquetools.com/cdi-3-8-d...nch-dual-scale/
Chinese and Taiwan models are available also. Hope this helps.
Thx guys ...
Accuracy for piece of mind...
One more question beam style vs clicker
Any opinions on this
https://www.cpooutlets.com/platinum-tools-c2fr100f-3-8-in--drive-100-ft-lbs--split-beam-click-type-torque-wrench/prenc2fr100f,default,pd.html?cgid=automotive-hand-tools-torque-wrenches
NDX,
When talking about torque accuracy, remember that the torque process can easily be off by +/- 25% due to many variables. So, the accuracy difference of a torque wrench of 2% vs. 4% is a moot point.
The Precision Instruments torque wrench you link to is very highly regarded as an excellent U.S. made torque wrench. Check out reviews at the Garage Journal forum. It doesn't work in the reverse direction, but that is a very rare need. This wrench used to be supplied to Snap-On, with the only difference being a Snap-on ratchet head.
Thank you sir ...
How to understand the 20% rule ?
So lowest is 20 ft lb .... so it will be accurate from 24 ft lb ?
20 + 20% = 24 ?
Thank you
Originally Posted By: doitmyself
Originally Posted By: redbone3
The 20 to 100% rule doesn't apply to digital torque wrenches.
It does on the good ones: http://public.snapon.com/a_prodannouncements_us/ATECH1FR240B_NPA.pdf
Seems like it applies to the lesser ones also: http://www.gearwrench.com/gearwrench-85076-3-8-electronic-torque-wrench-7-1-99-6-ft-lbs.html
Most of the digital ones have a derated accuracy from 10 to 20% of range: http://www.cditorque.com/manuals2010/CDI_Manual_Computorq3.pdf
I just used the Snap On digital torque wrench today. Loved it. However, I will say that an old school dial torque wrench is, quite possibly, slightly easier to use quickly. As pre setting the torque number takes time. When one has to step up torque multiple times, on multiple sized fasteners, stopping to reset takes time.
Here's Precision Instruments accuracy statement: "Accurate within 4% of reading from 20% of full scale to full scale." On a 100 ft. lb. wrench, P.I.'s 4% accuracy would apply between 20 ft. lbs. and 100 ft. lbs.. A 250 ft. lb. wrench should have the stated accuracy down to the 50 ft. lb. range (20% of 250). Using a torque wrench below the 20% of full scale might be inaccurate, even if the wrench has a scale that goes down to zero. This is a basic guideline for purchasing and using the correctly ranged wrench.
redbone3 educated us that electronic digital wrenches give accuracy ratings down to 10% of full scale, with only a slight loss of accuracy in that range (10-20%).
Also, FYI, if you are intent on a digital model, I was in Home Depot yesterday and noticed that their Husky 3/8 model is an 80 ft. lb. wrench, meeting your original criteria. Lifetime warranty, which is very unusual for torque wrenches. https://www.homedepot.com/p/Husky-5-80-f...TWDIG/206096361
I have a Snap On 3/8 drive digital, I would never buy another. They drain the batteries when they're turned off. It wasn't just mine, we have several at work and they all do the same thing, you need to install the batteries before you use the thing and remove them when you're done. Also, you need to be careful with chemicals near the plastic display lens and handle. I do like that you can switch between ft lbs, inch lbs and newton meters, that you can see the torque as you come up on it, that they vibrate and beep when you reach the set torque and hold the actual torque you reached on the display momementarily.
Split beam is all I use, the accuracy remains spot on for a long time so while initially it may be a % higher than some of the others in a short time it does a more accurate job because it remains stable. the nice thing is you don't have (or need) to set it to 0 when finished, the tool has no spring load.
You cant go wrong with that tool!
Thx guys ...
So this and this would have me covered ?
10-50 Split Beam
https://www.cpooutlets.com/platinum-tools-c2fr50f-3-8-in--drive-10---50-lbs-ft--split-beam-click-wrenches/prenc2fr50f,default,pd.html#xsell=prenc2fr50f--2
and 20-100 Split Beam
https://www.cpooutlets.com/platinum-tools-c2fr100f-3-8-in--drive-100-ft-lbs--split-beam-click-type-torque-wrench/prenc2fr100f,default,pd.html#xsell=prenc2fr100f--0
Strange enough factory Manuals like Porsche or BMW call for Digital Torque Wrenches but I guess those will do ... I have to re do timing chain, guides etc on my X1
those are an excellent pair of wrenches...for the above stated reasons, the split beam is simple and the digital garbage is totally redundant.
Thx guys ...
10-50 Split Beam
Their manuals are designed to scare off DIY and portray the illusion of perfection. Many of the digital are 3-4%, there is no bolt on any car engine that needs better than that.
Every fastener has a between x-y value they just spec the middle. What is more important than the unobtainable absolute 0% accuracy is the condition of the threads and what thread lube is used if one is scec'd or not.
Those tools are more than good enough, in fact most German shops and dealers that work on the cars you mention use that type. Wonder what they did before the digitals came out?
Thx guys ...
10-50 Split Beam
What he said.
