RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
113 registered members (1978elcamino, 2015_PSD, aquariuscsm, 77GrandPrix, Audios, Alfred_B, 8 invisible), 2,103 guests, and 59 spiders.
Topics286,237
Posts4,904,952
Members67,582
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V #4580528
11/20/17 10:06 PM
11/20/17 10:06 PM
GTA, Canada / NYC
Emperors6 Offline OP
GTA, Canada / NYC
All mileage is in kilometres. OLM was at 21%.
Notes from oil slip: RL 15W50 for summer due to track (ab)use, top-up oil: 1qt of RL 15W50. Will switch to 5W30 for winter. 18hrs of track use on oil.
Previous fill was also RL 15W50.
2013 Cadillac CTS-V
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580565
11/20/17 10:41 PM
11/20/17 10:41 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Is 15W50 the factory recommended viscosity ?
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580571
11/20/17 10:42 PM
11/20/17 10:42 PM
GTA, Canada / NYC
GTA, Canada / NYC
Nope, but similar engines do recommend 15W50 for track use.
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580572
11/20/17 10:45 PM
11/20/17 10:45 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I can tell you right now that 15W50 is not working. Too much iron and too much aluminum.
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580578
11/20/17 10:50 PM
11/20/17 10:50 PM
GTA, Canada / NYC
GTA, Canada / NYC
Check my history. I got same iron wear numbers in 11/7/2016 and I was running RL 5W30 then. As for the aluminum that's new. I'll see how it develops. Then, what do you recommend doing about the elevated oil temperatures I am seeing on the track? It goes up to 265F. 5W30 would be too thin for that.
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580594
11/20/17 11:13 PM
11/20/17 11:13 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Seems like you gotta switch brands to see if the problems are only brand-specific
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580621
11/21/17 12:58 AM
11/21/17 12:58 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I would fit an oil cooler on a thermostat. Maybe same for the transmission if you race it, Does this engine have short piston skirts?
Thick oil is better grin2
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580628
11/21/17 01:14 AM
11/21/17 01:14 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
It's not likely to be brand related. I suspect too much "oil friction" in the bearings leading to the elevated temps. I'd drop back to a 0W-40 and see what the numbers do ... RL would be good as you'll still track the car I'm betting laugh
The aluminum is almost certainly piston skirt material. I suspect that the timing could loose 1 or 2 degrees and save you some piston skirt wear smile
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580638
11/21/17 02:12 AM
11/21/17 02:12 AM
Brittany / Canada
Popsy Offline
Popsy  Offline
Brittany / Canada
+1 Iíll try a xxW40.
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 AFE 0W20 | Colt Ralliart, 300V 0W40
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580640
11/21/17 02:28 AM
11/21/17 02:28 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You said 2013 correct ?
Factory says:
2013 CADILLAC CTS 6.2L 8 -cyl Engine [P] LSA
VISCOSITIES:
All TEMPS....5W-30
Below -20 F .0W-30
CAPACITIES: With filter 6 quarts After refill check oil level.
TORQUES: Oil Drain Plug...18 ft/lbs
NOTES: (1) This specification has been updated from Dexos 1 (Dexos:2010) to Dexos1 Gen 2 (Dexos:2015)
^Amsoil
Try some 5W-30 Castrol Magnatec!
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580659
11/21/17 03:49 AM
11/21/17 03:49 AM
BC, Canada
userfriendly Offline
BC, Canada
Aluminum block, aluminum heads & aluminum in the used oil. Prove that the aluminum in the oil is a wear metal.
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: userfriendly] #4580675
11/21/17 04:55 AM
11/21/17 04:55 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
It's the other wear metals being elevated that point to the aluminum as being a wear metal. If the copper and iron were both near zero, then you could say the aluminum is from the engine getting dissolved by the oil.
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4580762
11/21/17 08:35 AM
11/21/17 08:35 AM
GTA, Canada / NYC
GTA, Canada / NYC
The other wear metals do not look elevated. Check my posting history. If you go back far enough you'll see I was using a different oil in early 2016. The only one of concern is the aluminum. Even the iron last time is not out of the question due to the track use and it's reached that level before.
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4581024
11/21/17 01:53 PM
11/21/17 01:53 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Have you done a test with 5w-30 ? I think 5W-30 would be good to establish a base line for comparing the test results of other viscosities to.
Re: Red Line 15W50, 6k mi OCI, 75k mi, Cadillac CTS-V [Re: Emperors6] #4581025
11/21/17 01:56 PM
11/21/17 01:56 PM
GTA, Canada / NYC
GTA, Canada / NYC
Yes, I've used 5w30 except for the last two UOAs. You can check the titles of my started threads here: https://bobistheoilguy.com/forums/ubbthreads.php/ubb/userposts/view/started/id/55846
Page 1 of 4 1 2 3 4
