Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
69 registered members (69Torino, avi1777, 2015_PSD, 87sammy, 97K15004WD, ArrestMeRedZ, 6 invisible), 776 guests, and 53 spiders.
Topics286,105
Posts4,902,667
Members67,563
Most Online2,967
Mar 10th, 2019
Motul X-clean 5w/30 FE - 2017 STI - 3,900 miles #4580340
11/20/17 07:27 PM
11/20/17 07:27 PM
Florida
Tiir Offline OP
Tiir  Offline OP
Florida
There was suppose to be another column from the previous PUP 5w-30 fill (11,080 miles to 14,9xx miles) that I had sent in almost a week earlier than the Motul sample which has been sitting in the garage since the last oil change, but it got delayed in shipping for several days - both arrived at the same time; the Motul sample got done first.
Will they correct the spreadsheet once the other sample is done to reflect time and mileage in order ?
Motul X-clean 5w-30 EFE went in as the new oil.
2017 WRX STI - Sold
2017 ES300h - Sold
2016 Lexus GS F
Re: Motul X-clean 5w/30 FE - 2017 STI - 3,900 miles [Re: Tiir] #4580379
11/20/17 08:00 PM
11/20/17 08:00 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
Does this have a copper oil cooler?
Re: Motul X-clean 5w/30 FE - 2017 STI - 3,900 miles [Re: Tiir] #4580385
11/20/17 08:03 PM
11/20/17 08:03 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I used to have high copper and high silica in my samples and it was like that the life of the vehicle Terry figured it was the gasket material leeching into the sample. I did try different air filters and look for air leaks for the silica and never found any.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Motul X-clean 5w/30 FE - 2017 STI - 3,900 miles [Re: Tiir] #4580507
11/20/17 09:50 PM
11/20/17 09:50 PM
The land of USA-made Subies!
SubieRubyRoo Offline
AFAIK, all new STIs have a copper oil cooler.
Re: Motul X-clean 5w/30 FE - 2017 STI - 3,900 miles [Re: Tiir] #4581220
11/21/17 06:15 PM
11/21/17 06:15 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Send them an email or call them and they will issue a new report. I've had to have them correct reports for both cars (incorrect engine).
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: Motul X-clean 5w/30 FE - 2017 STI - 3,900 miles [Re: JustN89] #4581288
11/21/17 07:33 PM
11/21/17 07:33 PM
Florida
Tiir Offline OP
Tiir  Offline OP
Florida
Yes, it does; it's a liquid to liquid cooler which is made of a big chunk of cooper as so it appears: it's sandwiched between the engine block and oil filter that uses the engines coolant system.
I know the 2015-2017 STI's do for sure, I'm somewhat sure, but I believe the 2008-2014 did too - again, I'm not entirely 100% on that last statement.
I received the other UOA, I'll just post it here instead of making a new thread. I used a Mobil 1 container that had some oil left in it which I cleaned out with brake clean and let it dry out before using it to put the sample in since I hadn't received the sample bottles from blackstone when I did this oil change. This UOA had a 1,800 mile road trip on it - seems like this time the PUP 5w-30 didn't shear as much as the other 2 samples did.
2017 WRX STI - Sold
2017 ES300h - Sold
2016 Lexus GS F
