Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
Rural King: 20K Lumen LED Tripod Worklight $34.93
by skyactiv. 03/25/19 03:55 PM
How do I find out which Honda Engine?
by Gebo. 03/25/19 03:08 PM
Moltex increases their footprint, hiring
by OVERKILL. 03/25/19 02:53 PM
Rislone complete fuel system gas treatment
by Fitter30. 03/25/19 02:29 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
124 registered members (77GrandPrix, agpatel, Aero540T, aquariuscsm, anndel, Andya, 12 invisible), 2,066 guests, and 65 spiders.
Topics286,425
Posts4,908,062
Members67,622
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
98 lesabre, o0420 code..some cleaning ideas! #4580035
11/20/17 12:53 PM
11/20/17 12:53 PM
stamford, CT
ziggy Offline OP
ziggy  Offline OP
stamford, CT
Hi again all! I replaced my upper plenum,gasket,lower gaskets.had a code p0420. Catalyst inefficient bank 1. Cell went off. About a week later,80 miles or so,cell came back on. P0420. Got 2 new oxygen sensors,as Delco brand,try too install tomorrow. Did some googling,and came across, carb cleaner sprayed in cat, !
Liquid kilt sucked through brake booster line, cataclysm in a bottle, distilled water sprayed through intake,and lawyer thinner,a gallon too half a tank. Think any of these are worth a shot? Figured since I'm gonna have the sensors out,spray car cleaner in, some distilled water,followed by the laque r thinner thing. Scotty kilmers thing.
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580046
11/20/17 01:05 PM
11/20/17 01:05 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I've never heard of a widely accepted method to clean out a cat without gutting it - seems that once they're plugged, they're done.
With the right scanner you can watch your O2 voltage feeds to see if it's your sensors or the cat itself...
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580048
11/20/17 01:06 PM
11/20/17 01:06 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
I honestly can't comprehend a lot of what you write.
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580058
11/20/17 01:26 PM
11/20/17 01:26 PM
USA
mk378 Online content
mk378  Online Content
USA
"Cataclysm in a bottle" = malt liquor.
Not sure what "lawyer thinner" is, but I like the idea.
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580079
11/20/17 01:58 PM
11/20/17 01:58 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
Get say ahhh 3 pounds of plastic explosive, a thousand feet of detonation cord, detonation initiator, and viola... Problem solved.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580086
11/20/17 02:08 PM
11/20/17 02:08 PM
washington state
harrybosch Offline
harrybosch  Offline
washington state
I have a 1996 Toyota Tacoma with the 2.4 L engine. Bought it in 2006. After owning it for about 3 years, I got a check engine light (CEL). Read the code, it was P0420. Did some reading on the internet, found out that I could reset it by temporarily disconnecting the battery. As time went by I started to get the CEL more and more, was having to disconnect the battery twice a week. I waited until this past summer, on a day when the temperature was just right, in the mid 70's, and I replaced the catalytic converter (bought a Walker brand one from RockAuto, $103 with shipping). I was lucky, I only needed to remove 4 bolts and the cat fell out. I have 3000 miles on this cat now, no more CEL. I tried "Cataclean" in my gas tank, it did a good job of cleaning the injectors but still had the CEL come on
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: Ethan1] #4580105
11/20/17 02:41 PM
11/20/17 02:41 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I enjoy reading his posts. The "lawyer thinner" got me. LOL
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580138
11/20/17 03:29 PM
11/20/17 03:29 PM
USA
zvm77us Offline
zvm77us  Offline
USA
your cat is most likely toast, below is your solution for emissions
https://zzperformance.com/3800/o2-emulator.html
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: bbhero] #4580215
11/20/17 05:08 PM
11/20/17 05:08 PM
USA
USA
Fill up with E0 first.
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580225
11/20/17 05:18 PM
11/20/17 05:18 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Register car in MA. Emissions void after 15 yrs. You can run it rich for a 50 miles, then lean and hot for a few hours In a lower gear to keep revs up at legal speeds.
Thick oil is better grin2
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580249
11/20/17 05:50 PM
11/20/17 05:50 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I would go with the $5 fix. Use a Dorman HELP spark plug nonfouler modded for the rear O2 sensor. It backs the rear O2 out of the exhaust flow a bit, which the ECU thinks is awesome catalyst efficiency. In a day or 2 poof, out goes the light for good. But remember, that oil burning will eventually plug the cat, and the car will choke and stall. And cause other various issues due to heavy oil consumption. And if you're fogging your cats with pale oil (AKA Seafoaming) don't. Plugs the cat even worse.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: bbhero] #4580281
11/20/17 06:22 PM
11/20/17 06:22 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Thatís right Captain. Heck, throw a whole bottle of MMO in there for good measure smile
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580313
11/20/17 06:50 PM
11/20/17 06:50 PM
Lyndhurst NJ
Audios Online content
Audios  Online Content
Lyndhurst NJ
The coolant and oil that it was probably burning may still have left deposits on the cat, so after some time it may clear up on its own. You can do an O2 spacer as long as the cats not clogging. Ive also seen cat cleaner in a bottle as well. Ive had luck with a big bottle of techron, and doing the 50 miles or so in 4th gear at highway speeds, getting on it every now and then to try and get it really hot., and then immediatley going to inspection, but only bc in NJ we have to until the car is 25 years old. Not sure if you need it to pass anytime soon.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580344
11/20/17 07:35 PM
11/20/17 07:35 PM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
P0420 95% of the time means the converter is BAD, It is very confusing to me for people to spend time & money on stuff that will not fix the car.
2001 Chevy Camaro L92/4L80E
Re: 98 lesabre, o0420 code..some cleaning ideas! [Re: ziggy] #4580424
11/20/17 08:26 PM
11/20/17 08:26 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
ziggy - Do a backpressure test. You do that by unscrewing the upstream oxygen sensor and installing an exhaust backpressure gauge. Anything over 2-PSI is considered clogged. If it's not clogged, ignore the P0420 code unless you're trying to pass smog.
Page 1 of 3 1 2 3
