Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
32 registered members (c502cid, alcyon, anndel, Bailes1992, Chris B., 4 invisible), 543 guests, and 56 spiders.
Topics286,442
Posts4,908,257
Members67,622
Most Online2,967
Mar 10th, 2019
EFI car spark plugs cause a crank with no start!? #4579988
11/20/17 12:15 PM
11/20/17 12:15 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
So the Buick I have been working on is all done. Runs nice and smooth.
Did the following. Intake gasket, valve cover gaskets, hoses, water pump, new radiator, shift kit, new transmission fluid and a bunch of other small stuff.
Go to start it, crank but no start. I think "Weird" I have spark, fuel and of course air. I pull the plugs they look bad, so I decide to replace them.
Stock gap is .057 to .060. The ones I pulled were just under .080.
New plugs and started first crank. Was just weird to me. I have never had that happen on an electronically controlled car that was running when I started working on it.
I have to assume that having the correct gaskets installed and correct fuel curves made the 20 year old spark plugs just not enough.
Mike
00 Trans Am WS6 5.7 LS1
02 Silverado 2500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: EFI car spark plugs cause a crank with no start!? [Re: ls1mike] #4579994
11/20/17 12:20 PM
11/20/17 12:20 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Sometimes it's just a weird coincidence. I swear someone is messing with us on the regular sometimes though. LOL
'18 Dodge Grand Caravan GT - 26k KM - AMSOIL SS 0w20
'06 Hyundai Santa Fe - 535k KM AMSOIL SS 0w30
Re: EFI car spark plugs cause a crank with no start!? [Re: ls1mike] #4579998
11/20/17 12:23 PM
11/20/17 12:23 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
I've seen numerous cars start and run more-or-less fine on plugs worse than .02" over spec gap, but I've also noted how much quicker and cleaner a 3800 V6 started with a set of new Delco iridiums. Strange that it wouldn't start at all, though.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: EFI car spark plugs cause a crank with no start!? [Re: Alex_V] #4580004
11/20/17 12:28 PM
11/20/17 12:28 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
Yep, the plugs when pulled were wet with fuel. We put Delco Iridiums in there. Thing runs really nice now. Makes good boost. [censored] kit really helped.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: EFI car spark plugs cause a crank with no start!? [Re: ls1mike] #4580032
11/20/17 12:50 PM
11/20/17 12:50 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
You disturbed a bunch of stuff doing the intake gasket. Air flow sensors ,etc. The engine took a few seconds to figure out where it was. Mean time fuel was pumped as normal , no air, coupled with large gap.. Flooded Had you let it st overnight, it may have started normally. New plugs along with all the other stuff , means you won't be back under the hood for awhile.
Thick oil is better grin2
Re: EFI car spark plugs cause a crank with no start!? [Re: andyd] #4580037
11/20/17 12:55 PM
11/20/17 12:55 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
We let it sit over night. It was a crank and no start until the new plugs were installed. Started ran perfect. I have never seen anything like it.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: EFI car spark plugs cause a crank with no start!? [Re: ls1mike] #4580072
11/20/17 01:48 PM
11/20/17 01:48 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
If you unhooked the battery that may have been the reason why it didn't want to start right away
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: EFI car spark plugs cause a crank with no start!? [Re: ls1mike] #4580078
11/20/17 01:56 PM
11/20/17 01:56 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
Battery was not unhooked over night, it was before that, but remained hooked up after the initial cranking and not starts.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: EFI car spark plugs cause a crank with no start!? [Re: ls1mike] #4580120
11/20/17 02:51 PM
11/20/17 02:51 PM
Wisconsin
emmett442 Offline
emmett442  Offline
Wisconsin
80 thou is a pretty big gap. And, correct me if I'm wrong, but these old pigs use a waste spark system. Perhaps the resistance was just too high with the old plugs.
After removing the intake, it's certainly possible that a little coolant made its way onto the plugs as well. That wouldn't help either.
Then, after they were fuel fouled, there was no hope.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: EFI car spark plugs cause a crank with no start!? [Re: emmett442] #4580144
11/20/17 03:39 PM
11/20/17 03:39 PM
In the Garage...
ls1mike Offline OP
ls1mike  Offline OP
In the Garage...
I bet you are right. There was no way to get all the coolant out. I cleaned out what I could but I am pretty sure it there was still some in there.
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
