In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
Opinion needed....
by Duffyjr. 09/21/18 02:56 PM
2017 nissan sentra
by jahwarrior1423. 09/21/18 02:47 PM
Another dealership service cautionary tale
by Zee09. 09/21/18 02:29 PM
Liqui Moly
by dawgn86. 09/21/18 02:10 PM
Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
87 registered members (14Accent, 77GrandPrix, 4WD, ABomb369, 87sammy, 9 invisible), 1,376 guests, and 40 spiders.
Topics290,799
Posts4,850,595
Members66,036
Most Online3,590
Jan 24th, 2017
20w-50 and straight 50 #4579870
11/20/17 10:12 AM
11/20/17 10:12 AM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
Without getting into the why, just from a technical perspective, what happens when you mix straight mineral SAE 50 with 20w-50?
Mayne 2 qts of each? Or 3 qts SAE 50 with 1 qt 20w-50?
Re: 20w-50 and straight 50 [Re: CCI] #4579874
11/20/17 10:22 AM
11/20/17 10:22 AM
maple ridge, bc
2004tdigls Offline
2004tdigls  Offline
maple ridge, bc
Re: 20w-50 and straight 50 [Re: CCI] #4579900
11/20/17 10:52 AM
11/20/17 10:52 AM
NJ, USA
MotoTribologist Offline
NJ, USA
You'll have 4 quarts of 50 weight engine oil of a questionable winter viscosity rating. Probably either 20W or 25W.
Re: 20w-50 and straight 50 [Re: MotoTribologist] #4579925
11/20/17 11:13 AM
11/20/17 11:13 AM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
Good to see you here MT, I was hoping you'd respond.
OK, now the reason why -- this is a 40 year old motor that has an honest running compression check of 215 pounds on one cylinder and a little over 230 on the other. Stock head bolts didn't cut it, had to go to aftermarket bolts to stop blowing head gaskets and vaporizing aluminum mating surface.
It is kickstart only, it will break the back tire loose on dry pavement while already rolling without touching the clutch, and when it is hot it bleeds 20w-50 from everywhere but it only leaks about a quart every 750 to 1,000 miles on straight 60. I am OK with that, I have to be, there is no practical way to fix the problem.
But in the winter, well, kick starting that bike below about 50 degrees is just comical, below 40 degrees it's not even worth trying.
I'm going to do a little mixology and will report back.
Thanks!
Re: 20w-50 and straight 50 [Re: 2004tdigls] #4579933
11/20/17 11:19 AM
11/20/17 11:19 AM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
Cool website -- thanks!
Re: 20w-50 and straight 50 [Re: CCI] #4580648
11/21/17 02:54 AM
11/21/17 02:54 AM
European Union
Atesz792 Offline
Atesz792  Offline
European Union
How about some Amsoil SAE60? It's supposed to behave like a 20w or 25w in cold-but-worth-riding temps. Or so dealers say..
You could use the same oil all year, but I'm sure it's expensive.
2004 Suzuki GS500F
2006 Renault Mégane 1.5 dci
Re: 20w-50 and straight 50 [Re: CCI] #4581058
11/21/17 02:28 PM
11/21/17 02:28 PM
Palmyra, PA
kmrcstintn Offline
kmrcstintn  Offline
Palmyra, PA
pennzoil makes a 25w-50 racing oil...might be worth a try
walmart website lists it & it can be shipped to stores for pickup
https://www.walmart.com/ip/Pennzoil-GT-P...13=&veh=sem
'15 Jeep Patriot Sport (2.4L 4-cyl), '13 Genuine Buddy 125 (125cc air-cooled thumper), '14 Yamaha V Star 250 (250cc air cooled v-twin)
Re: 20w-50 and straight 50 [Re: kmrcstintn] #4583857
11/24/17 06:23 PM
11/24/17 06:23 PM
Central IA
Robenstein Offline
Robenstein  Offline
Central IA
That is some good stuff. We use it on our methanol injected drag car.
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
Re: 20w-50 and straight 50 [Re: CCI] #4584036
11/24/17 10:13 PM
11/24/17 10:13 PM
Taiwan
Ducked Online content
Ducked  Online Content
Taiwan
I do that with straight 40 and 15/40, but I never see sub-zero temperatures.
I can see some ways it might be better (less shear and ring gum mostly) but I can't see why it'd be better for you than 20w50 if your concern is leakage, unless you're only hoping to reduce leakage while its warming up.
Isn't the effective viscosity at operating temperature going to be the same?
Re: 20w-50 and straight 50 [Re: Ducked] #4584398
11/25/17 11:58 AM
11/25/17 11:58 AM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
I've always thought so, but it seems there must be more to the story. 20w-50 turns very thin and comes out all over at 100 degrees ambient, while the SAE 60 stays in rather well except for the bigger holes. The motor sounds awful at running temp with 20w-50, sounds good with 60.
Or 50 in colder weather.
I have no idea.
Re: 20w-50 and straight 50 [Re: CCI] #4584825
11/25/17 08:19 PM
11/25/17 08:19 PM
Taiwan
Taiwan
I have no idea.
I'm not completely clear on this but I THINK VII's can show temporary shear-induced loss of viscosity, which isn't shown by straight weight oil, so maybe that's part of the difference.
Re: 20w-50 and straight 50 [Re: CCI] #4585009
11/25/17 11:38 PM
11/25/17 11:38 PM
California
David_g Offline
David_g  Offline
California
Redline makes 20W60.
2007 BMW R1200R (Mobil 1 15W50, Red Line Shockproof Heavy, Supertech 75W90)
2016 Honda Africa Twin DCT (Motul 5100 10W40)
Re: 20w-50 and straight 50 [Re: Ducked] #4586149
11/26/17 10:23 PM
11/26/17 10:23 PM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
Just re-read your post, I don't think I gave a very good answer last time.
Three concerns:
Foremost is that I cannot kick this bike in cold weather with straight 50 or 60.
Second is the multi-viscosity oils just don't hold up. I don't know why, but it just turns thin in no time and the motor sounds terrible. You can feel the difference at over 80 degrees ambient.
The motor is old, everything that has not been rebuilt is worn out, to the point where I can't run hydraulic lifters anymore because they collapse at idle. Oil pump hasn't produced more than 12 psi hot in decades, probably about 3 psi at an idle.
Third is leakage, oddly enough the thicker oils leak worse when the motor is cold (more pressure I suppose), but once it is hot, the multi-vis oils come out faster.
So today I drained out the SAE60 that had about a thousand miles on it and looked awful and put in 2 qts 20w-50 and 2 qts SAE50. The motor sounds much better on this, we'll see what a little time and a few miles do.
As for effective viscosity at temperature, I know it's supposed to work that way, but over about 80 degrees ambient on any multi-vis oil the motor sounds like somebody threw the entire middle school marching band down the stairs. On straight 60 it sounds great. I have no idea why.
Re: 20w-50 and straight 50 [Re: CCI] #4586240
11/27/17 03:45 AM
11/27/17 03:45 AM
European Union
Atesz792 Offline
Atesz792  Offline
European Union
Maybe one of these would help?
2004 Suzuki GS500F
Re: 20w-50 and straight 50 [Re: Atesz792] #4586308
11/27/17 07:56 AM
11/27/17 07:56 AM
New Mexico USA
CCI Offline OP
CCI  Offline OP
New Mexico USA
WOW! That's amazing.
If I can find it in the USA, I'm trying it. Looks perfect.
Thank you.
