I have an iPhone 6, work-issued phone, not personal.
I do not live near an Apple Store, the nearest one is at least four hours away in another state.
The phone was doing something odd the last three days or so. The battery charge level never dropped below 100%. Whether plugged in and charging, or in use for two hours, it remained at 100%. Many times I knew it could not be 100% anymore because I had been using the device for a while...yet it still said 100%.
Last night I left the phone on the charger all night. I woke up today and it appeared normal and the charge read 100%. I logged in to the phone and the screen immediately went black and the center of the screen showed an icon with the battery symbol with just a tiny red line in it, presumably indicating the battery being nearly dead. I plugged it in and that made no difference. I took it off of the charger plug and immediately a symbol appeared at the bottom of the screen showing a charging cable, as if it is reminding me to plug it in and charge it. That power cord symbol appears below the battery with red line icon.
I then tried multiple charging cords and USB sockets, some new, some old, as well as plugging into a computer, and the phone just keeps showing the battery icon in the middle of a black screen. Per instructions I found online, I tried charging it for a half hour at a time with each charger setup, but to no avail.
I read more online and gave the phone's charger port a very thorough cleaning, both with nonconductive tools and compressed air. No change.
OK, so it seems there is a reset procedure or two for this phone. I wasn't sure which one to try as it seemed some people online said to hold down the home button and the side/lock button simultaneously and wait 10 seconds, while others said the "lower volume" button and the side button. I tried both, I tried holding the buttons down for 10 seconds, 30 seconds, and 1 minute, but nothing is changing. I tried it while connected to a charger and while not connected. All I see is the black display with the battery/red line icon in the middle of the screen. And if I unplug it, the cord plug type icon below that one.
I also tried heating up the phone gently on a warm plate, as several people online reported success by heating the battery, but nothing new has developed.
I had been using an aftermarket but approved charger. The phone is now sitting and attempting to charge on a co-worker's factory original charger. The display still looks the same but I am hoping that will change!
Any ideas on what else I can do?
