AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
62 registered members (2003f7, Aero540T, 2010Civic, agpatel, alphadog, Aichiguy, 3 invisible), 1,280 guests, and 60 spiders.
Topics286,439
Posts4,908,174
Members67,622
Most Online2,967
Mar 10th, 2019
Wet dry vacuum recommendations #4579603
11/19/17 11:43 PM
11/19/17 11:43 PM
USA
97prizm Offline OP
97prizm  Offline OP
USA
My parents had one years ago, noisy and plastic which gets brittle with age. My big question is brand differences and canister materials, metal vs polycarbonate plastic? Ryobi, vs shop-vac vs craftsman etc. It has to have the suck, and pump feature i saw years ago as my roof is flat. It let you suck up liquid then simultaneously pump it out the back. All recommendations and suggestions are appreciated.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm
1984 Mazda RX-7 Spec 7
Re: Wet dry vacuum recommendations [Re: 97prizm] #4579619
11/19/17 11:56 PM
11/19/17 11:56 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
The Rigid I bought at Home Depot 20 yrs ago is still handling anything too gross for the indoor vacuum. What ever you get, get a spare filter or 2.
Thick oil is better grin2
Re: Wet dry vacuum recommendations [Re: 97prizm] #4579622
11/20/17 12:06 AM
11/20/17 12:06 AM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
I too have a Ridgid, it does a good job and I abuse the heck out of it. I've washed the entire motor with a pressure washer after vacuuming drywall dust and it keeps soldiering on.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Wet dry vacuum recommendations [Re: 97prizm] #4579624
11/20/17 12:08 AM
11/20/17 12:08 AM
SD
zrxkawboy Offline
zrxkawboy  Offline
SD
I've always preferred Craftsman, but haven't bought a new one in the past several years.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Wet dry vacuum recommendations [Re: zrxkawboy] #4579628
11/20/17 12:11 AM
11/20/17 12:11 AM
Texas
4WD Offline
4WD  Offline
Texas
Same my camp flooded during Harvey and that Craftsman shop vacuum worked some serious overtime
Re: Wet dry vacuum recommendations [Re: 97prizm] #4579630
11/20/17 12:12 AM
11/20/17 12:12 AM
Iowa
Iowegian Offline
Iowegian  Offline
Iowa
Vacmaster 12 gal.
I've had this for 6 years.
Detach the top and it turns into a blower.
https://www.homedepot.com/p/Vacmaster-12-gal-Wet-Dry-Vacuum-with-Detachable-Blower-VBV1210/202770739?cm_mmc=Shopping%7cTHD%7cG%7c0%7cG-BASE-PLA-D25T-WetDryVacs%7c&gclid=EAIaIQobChMIgpKK2bDM1wIVFtlkCh2XxAL1EAQYASABEgKA7_D_BwE&gclsrc=aw.ds&dclid=CPzZg-awzNcCFQatTwodgLcDRA
2011 Equinox, 2.4l
2009 Sienna, 3.5l
Re: Wet dry vacuum recommendations [Re: 97prizm] #4579743
11/20/17 07:06 AM
11/20/17 07:06 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
I have a rigid too. Only thing that needed replacement was the switch.
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Wet dry vacuum recommendations [Re: 97prizm] #4579794
11/20/17 08:23 AM
11/20/17 08:23 AM
WI
HoosierJeeper Offline
WI
I've had a Shop Vac Deluxe for probably 7 or 8 years now and it's been flawless. Had another before that, it was easily 15+ years old.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Wet dry vacuum recommendations [Re: 97prizm] #4579803
11/20/17 08:33 AM
11/20/17 08:33 AM
Ceciltucky Maryland
Oldtom Offline
Oldtom  Offline
Ceciltucky Maryland
I have had good luck with Craftsman. Not sure if they are still available with Sears heading to bankruptcy. i think every shop vac should have a Clean Stream Filter installed. The filter is made of some kind of porous teflon material and is reusable FOREVER. Mine has sucked up pounds of drywall dust and nasty liquids when you use a shop vac to unclog a toilet. To clean, just gently tap the filter while holding it over a trash can. The crud just falls away. You can also use a gentle stream of water from a hose. I did ruin one by getting inpatient and using high pressure air, I blew a hole in it mad
Bottom line, I like these filters so much that I would buy a shop vac that they make Clean Stream Filters for. Get 2 filters in case they quit making them. Cost about 30 dollars each and worth every penney.
Re: Wet dry vacuum recommendations [Re: 97prizm] #4579820
11/20/17 09:00 AM
11/20/17 09:00 AM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
I was gifted a 12 gallon stainless canister Shop-Vac [brand] and would not recommend it. Its very loud (the pitch is annoying), the clasps for the motor/canister come undone spontaneously (lift the motor/handle and the canister nearly takes a dump) and the power switch has been sticking since new (drives me wild, they even replaced the whole motor assembly containing the switches).
I only occasionally use it, but the Ridgid WD1450 has replaced it. It has none of the Shop-Vac negatives, very powerful and its the quietest shop vac I've used. Probably the only negative would be its size.
Re: Wet dry vacuum recommendations [Re: 97prizm] #4579853
11/20/17 09:48 AM
11/20/17 09:48 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Ok 97P, Ill jump. Why are you wet vacuuming your flat roof?
I have a EPDM flat roof and I broom it periodically - the stuiff the wind doesn't easily blow off.
You should have perforations with drains if its large with no pitch.
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Wet dry vacuum recommendations [Re: 97prizm] #4580152
11/20/17 03:45 PM
11/20/17 03:45 PM
USA
97prizm Offline OP
97prizm  Offline OP
USA
My parents are getting the roof replaced in the spring, we have a section that ponds water really bad with any heavy rain and snow.
1997 Geo Prizm
Re: Wet dry vacuum recommendations [Re: 97prizm] #4580529
11/20/17 10:08 PM
11/20/17 10:08 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
I picked up the $100 Rigid model at a garage sale for $15. Soon after my 15yr old [censored] went tango uniform. Couldn't believe my timing. Went to HD & bought a drain plug + a clearstream (gore tex) filter. It also accepts my 2-1/2" dust collection hose from Woodcraft. The larger ID allows for MUCH better airflow vs. the stock hose, plus WC sells 2-1/2" hose accesories much cheaper than HD. Rockler sells similar. If you need a longer hose, just add a coupler to connect two together.
Fortunately, it's not too loud. It also allows you to connect the hose to the output to BLOW AIR. Very useful.
2cents
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Wet dry vacuum recommendations [Re: 97prizm] #4580632
11/21/17 01:22 AM
11/21/17 01:22 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I've probably been through 4-5 ShopVac brand wet/dry vacuums in 25yrs. ~5yrs on average before the motor exhales it's smoke.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Wet dry vacuum recommendations [Re: 97prizm] #4580942
11/21/17 12:17 PM
11/21/17 12:17 PM
N.H, U.S.A.
N.H, U.S.A.
Ahhh ... saggy Deck. Been there.
Take care up there.
