Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
3.5EB Gen II: Oil & Interval
by Gene K. 09/19/18 06:09 PM
Are there any cable techs here?
by Reddy45. 09/19/18 06:02 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
59 registered members (AlaskaMike, Ag76, advocate, ABomb369, Bailes1992, Auae85, 3 invisible), 1,204 guests, and 35 spiders.
Topics290,696
Posts4,848,404
Members66,021
Most Online3,590
Jan 24th, 2017
Cornering lights installed #4579567
11/19/17 10:55 PM
11/19/17 10:55 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
I drive a lot on dark,desolate rural roads and trying to figure out where the road is on a turn can be an issue. If no one is around, I often use my spotlight to throw light to the left or right so I can see. But it would blind people if I hit someone with it so its of limited use.
I wanted something that wouldn't bother people so I purchased a pair of 10W LED "spot lights" off ebay. I mounted them low on the side of my push bumper and aimed them towards the oncoming corner. I ended up liking the right one at a much shallower angle than the left one, which makes sense. You can see the difference in the video.
Wiring is where I got lucky. I dont know if they thought about using it, or if it fell through the cracks but all 03-04 Crown Vics are wired for cornering lights all the way out to a 4 pin connector behind the side marker. The side marker then has a pigtail with only 2 wires that plugs into that connector. All I had to do was cut the cornering lamp wire at the connector, splice the ground, and run about 2 ft of my own wire to the light. Easy easy.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: Cornering lights installed [Re: Colt45ws] #4579595
11/19/17 11:32 PM
11/19/17 11:32 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
That's sweet
Re: Cornering lights installed [Re: Colt45ws] #4579606
11/19/17 11:44 PM
11/19/17 11:44 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
Cornering lights are the bomb. I wish manufacturers still installed them.
2018 Challenger SRT
Re: Cornering lights installed [Re: Colt45ws] #4579609
11/19/17 11:46 PM
11/19/17 11:46 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Colt, Town Cars had cornering lights. That wiring probably came across the platform.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Cornering lights installed [Re: Garak] #4579617
11/19/17 11:53 PM
11/19/17 11:53 PM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
Yes, Grand Marquis and Marauder also used them. Thing is, pretty much every body harness in the car is police specific, as they have a TON of extra power leads coming from the battery fuse box that are left open for police accessories. I think this wiring was overlooked when they designed the individual harnesses and got put into all of them.
-Colton
Re: Cornering lights installed [Re: Colt45ws] #4579642
11/20/17 12:36 AM
11/20/17 12:36 AM
Garak Offline
Garak  Offline
Yes, that's probably what it is. A buddy had a Marauder, but never noticed whether it had cornering lights or not, and Grand Marquis was often too nice for taxis. wink
Re: Cornering lights installed [Re: Colt45ws] #4579666
11/20/17 03:03 AM
11/20/17 03:03 AM
MA
Wolf359 Offline
Wolf359  Offline
MA
They're on my Mercedes. Basically it has active curve illumination so when you turn the steering wheel, the fog light on the right or left comes on and then shuts off when you're done. The bixenons also swivel about 12 degrees. Helpful on curves, you end up illuminating the road, not the guard rail. Auto high beams are also pretty cool, I just leave it on all the time and it seems to know when to have them on or not. Goes from low to high slowly so sometimes you don't even notice that the high beams are on until you realize that it's a little brighter than normal.
Re: Cornering lights installed [Re: Wolf359] #4581366
11/21/17 08:47 PM
11/21/17 08:47 PM
Garak Offline
Garak  Offline
Town Cars did them cheaply, but effectively. You turn on your left signal, the left cornering light turns on. Signal off, cornering light off.
Re: Cornering lights installed [Re: Colt45ws] #4583343
11/24/17 03:28 AM
11/24/17 03:28 AM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
After running around for a week, I can safely say this was the best $20 modding money Ive spent on the car.
Ive also thought about how to put them on another Vic, like my '02 or if I end up in a later car; neither of which have this weird wiring happenstance.
Ive been dabbling in electronics as of late, going as far as to make a few 555 timer circuits. So my mind went there. So what if I triggered a 555 on the high pulse of the turn signal, making it time out only to retrigger on the next.
Was thinking through some of the problems I might have when I came up with something even simpler that should work.
Bring the turn signal feed in through a diode, charging a capacitor, which discharges through a resistor into the base of a transistor. Each high pulse of the turn signal will charge up the cap, the diode will prevent the charge from backflowing into the turn circuit so it has to drain through the resistor and turn on the transistor. The values of the resistor and capacitor will take some playing with but I think it would be easy to do and very simple. Then the tranny would be turning on a relay. I have some circuit board mounted relays I can run with the 2N2222 NPN trans I have in stock. They are rated [email protected], so not much but should be enough for these 10W leds, or will easily run a common Bosch style relay if you wanted something heavier.
I might work on this at some point if I get bored.
-Colton
Re: Cornering lights installed [Re: Colt45ws] #4583458
11/24/17 09:54 AM
11/24/17 09:54 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I put some clear sidemarker lights in my '97 Taurus. Then there was some simple wring mod to do to make them come constant on with the turn signal. I also wired them into the reverse light. This was nice in dark parking spaces.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Cornering lights installed [Re: Garak] #4585081
11/26/17 01:19 AM
11/26/17 01:19 AM
MA
Wolf359 Offline
Wolf359  Offline
MA
Mercedes does it both ways. Either the turn signal or the steering wheel will turn them on/off. They do a nice fade on/off too so they don't really snap on or off. Very noticeable on a dark but not so much in the city.
Re: Cornering lights installed [Re: Wolf359] #4585098
11/26/17 02:21 AM
11/26/17 02:21 AM
Garak Offline
Garak  Offline
No fade on the Town Cars, of course. The signal cancelled, the cornering light would at the same time. It wasn't obtrusive in the city, either, but helpful on a dark, secluded road.
Re: Cornering lights installed [Re: Colt45ws] #4587095
11/27/17 11:15 PM
11/27/17 11:15 PM
Minneapolis
antonmnster Offline
antonmnster  Offline
Minneapolis
My Saab 900s won the day. Not only did they have cornering lights, but right behind the front cornering lights were a pair of REVERSE lights. They would shine light down the side of the car while backing. Super handy.
Re: Cornering lights installed [Re: Colt45ws] #4587129
11/28/17 12:45 AM
11/28/17 12:45 AM
Central Washington
Colt45ws Offline OP
Colt45ws  Offline OP
Central Washington
Hmm. Was trying to think what that would be useful for, but probably seeing out your side mirrors. I usually have my whole body spun around or Im using my rearview mirror. My Side mirrors are set too wide to be useful in backing unless I lean way over to one side or the other.
Neat idea anyway!
-Colton
