Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
26 registered members (csandste, Bailes1992, carlprop, 10ecfarmer, Brigadier, 2 invisible), 916 guests, and 39 spiders.
Topics290,866
Posts4,851,552
Members66,044
Most Online3,590
Jan 24th, 2017
faulty fuel filter #4579528
11/19/17 10:21 PM
11/19/17 10:21 PM
South GA
wuntun Offline OP
wuntun  Offline OP
South GA
I was changing out the fuel filter in my tractor, and this filter only has about 60 hours on it. I discovered this hole in the bottom of the filter, it is not a corrosion hole, it is too perfectly round. It is a napa or wix brand
http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=111118 and a very standard type fuel filter. Could one surmise that there was a plug over it at time of installation, and it fell out? (I dumped the fuel out of the bowl without looking at it closely, into an oil drain pan) so not sure if it (the 'plug') was in there. I just hope that most of the fuel was filtered before going into the injector pump, but obviously some had to go through the hole. Has anyone seen a hole in a filter end cap before?
Wuntun
Re: faulty fuel filter [Re: wuntun] #4579652
11/20/17 01:20 AM
11/20/17 01:20 AM
BC Canada
Farmer Offline
Farmer  Offline
BC Canada
Why are both the end caps missing?
Re: faulty fuel filter [Re: Farmer] #4579658
11/20/17 01:53 AM
11/20/17 01:53 AM
South GA
wuntun Offline OP
wuntun  Offline OP
South GA
The end caps are there, just discolored. The opposite end is open in the middle with rubber gasket. Not shown in my pics, but the wix link has pics of both ends if one wants to see that.
Wuntun
Re: faulty fuel filter [Re: wuntun] #4580536
11/20/17 10:12 PM
11/20/17 10:12 PM
South GA
wuntun Offline OP
wuntun  Offline OP
South GA
Farmer, my apologies, you have good eyes, you were partially correct. I cannot see very well without glasses, which i did not have on at removal of filter, or taking the pics. Today I used a magnifying glass to see if i could retrieve a part number if there was one, and realized that what i though was a discolored end cap from varnish was in fact missing. What i was perceiving with my bad vision was the cardboard type end cap glued to the filter pleats, and after looking at a new one seen how the metal end cap is same size shape of the cardboard end. Apparently my son has/had removed the bowl to remove the water that accumulates and threw out the cap not noticing it, since he threw the fuel water mix onto tree stump suckers to kill them. That is our best assumption anyway. The other end cap is still intact, as that is what holds it onto the filter body/housing. I also found out the last filter my son put on is one he found in his father in laws shop, which is an inferior brand obviously (he said it was in a red white and blue box) whatever that brand is. lol But definitely not the wix i normally keep in my shop for our john deeres. I looked inside those and they do not have a hole in the cardboard, so even if the metal cap comes off, it wouldn't draw unfiltered fuel.As i said before, i just hope the life of the injection pump will not be compromised. Thank for the catch, my mind is relived of the 'why'.
Wuntun
