Fireworks Stores
by Warstud
9 minutes 39 seconds ago
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
19 minutes 5 seconds ago
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
27 minutes 58 seconds ago
How Fast to Run a ZeroTurn Mower
by Gebo
35 minutes 47 seconds ago
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
56 minutes 22 seconds ago
My FIL in hospice
by fdcg27
Today at 08:41 PM
Spraying Polyurethane
by Texican
Today at 08:37 PM
Dehumidifier icing
by Kestas
Today at 08:37 PM
Diesel lube in Petrol Engine
by Ducked
Today at 07:46 PM
New key programming cost
by 92saturnsl2
Today at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Today at 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
Today at 07:08 PM
Wheel says 50 mph max
by pda1122
Today at 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
Today at 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
Today at 06:36 PM
Old Engine SOUND
by MasterSolenoid
Today at 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
Today at 04:54 PM
go green or Dexcool?
by umungus1122
Today at 04:50 PM
Latest info on ExxonMobil synthetic base stocks
by Gokhan
Today at 04:49 PM
Pennzoil Platinum 5w30 - $3.21/qt Amazon
by SnowmanCO
Today at 04:37 PM
bcj, Ilia, nmac9, Theraven, battleman13
65279 Registered Users
108 registered (4WD, 01rangerxl, 87sammy, 97f150, 2003f7, 18 invisible), 1433 Guests and 55 Spiders online.
65279 Members
67 Forums
285679 Topics
#4579158 - 11/19/17 04:00 PM Fluid Film safe on rubber bushings,boots,mounts?
Kabanstva Offline
Loc: Illinois
On the Fluid Film website, it says Fluid Film may cause swelling on "natural rubber".
I don't know what that means. I also don't know what kind of rubber is used on your typical Toyota vehicle on rubber mounts,bushings,boots, etc.
Has anyone had any issues with Fluid film damaging these areas of the undercarriage on a vehicle?
#4579171 - 11/19/17 04:13 PM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: Kabanstva]
DallasTexas Offline
Loc: Texas
I have always used Wurth HHS spray with outstanding results.
06 E320 CDI 98k miles
14 Sienna 33k miles
96 E300 297k miles Donated
#4579195 - 11/19/17 04:27 PM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: Kabanstva]
Donald Offline
Loc: Upstate NY
Try CarWell instead.
2015 Ford F250 w/Powerstroke
#4579220 - 11/19/17 04:40 PM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: Kabanstva]
Kabanstva Offline
Loc: Illinois
Please respond if you have experience with Fluid Film.
#4579242 - 11/19/17 04:59 PM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: Kabanstva]
doitmyself Offline
Loc: MI
Sorry, no experience myself. Their website leaves one wondering.
At the last 20 seconds of this following video, this guy claims he got about 15% swelling after 2 years use. Hope this helps: https://www.youtube.com/watch?v=4npPOrVtjyc
#4579291 - 11/19/17 05:47 PM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: Kabanstva]
JC1 Offline
Loc: Oshawa, Ontario Canada
I haven't experienced any swelling with fluid film. I've been using it for the past three years.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4579368 - 11/19/17 06:50 PM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: Kabanstva]
emmett442 Offline
Loc: Wisconsin
No problems so far on 3 vehicles over 5 years of use
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
#4579382 - 11/19/17 07:00 PM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: DallasTexas]
leje0306 Offline
Loc: Minnesota
Did you completely ignore the original post, or do you just not understand it?
I accidentally get fluid film on this components and have not had issues. Perhaps they are a synthetic rubber?
Edited by leje0306 (11/19/17 07:01 PM)
#4579415 - 11/19/17 07:30 PM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: Kabanstva]
eljefino Offline
Loc: ME
Used it on "todays" (well, 15 years old) "rubber" without problems. I just hit stuff once a year in the fall, and don't deliberately aim for bushings... b/c FF's expensive. laugh
#4580799 - 11/21/17 08:26 AM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: emmett442]
penguin Offline
Loc: Idaho, USA
I use a front end loader for snow removal. I spray it every fall with Fluid Film. The fluid film has softened the rubber and made wrinkly the rubber strips used as cushioning and seals around the battery boxes. I still use the fluid film though. I can easily replace the press-on rubber molding if need be. I would advise to avoid spraying it onto rubber.
#4582332 - 11/22/17 08:04 PM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: Kabanstva]
A310 Offline
Loc: Kelowna, BC, Canada
I sprayed my neighbors car and got Fluid Film on his lower door seals. This caused them to swell up and I ended up having to replace them. All the other rubber on the car was fine and shows no sign of swelling. Just my findings.:)
#4583682 - 11/24/17 01:08 PM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: A310]
Kabanstva Offline
Loc: Illinois
I emailed FF and they said hte same thing. To just watch out for weatherstripping, but everything else underneath and in the engine bay should be fine.
#4612690 - 12/24/17 05:16 AM Re: Fluid Film safe on rubber bushings,boots,mounts? [Re: Kabanstva]
xtell Offline
Loc: ohio
I use it on my plow trucks. Never had an issue with any rubber going soft. When I spread it around, I invariably get it on radiator hoses, rubber suspension bushings,etc. Never a problem. Someone also mentioned on another post from last year if Fluid Film harmed paint, no issues with paint on my trucks either.
