Have a Yard Machine that I posted about previously and fixed thanks to lots of feedback
Briggs Engine Code: 12h802-1777-d1 02092557
Yesterday, while running, I heard a noise and shut it down
I don’t know what the part is called but:
*. The carb screws onto a plate - 2 screws
*. The plate is bolted into the engine - 2 screws
One of the bolts which fastens the plate to the engine sheared off.
I tried extracting the remainder of bolt but failed... drilled more meat out and I tried to tap a new 1/4-20 but did a [censored] job of it and am now waiting for the lock tight to cure
Questions:
1. The engine piece onto which this plate attaches is called...what? Ideally, this piece gets replaced if possible. It has the cooling fins on it
2. Alternative I’ve been considering is simply replacing the engine with something from Harbor Freight... I wouldn’t even know where to start: I’m guessing this vacuum, like a lawn mower, is a vertical shaft? And there’s all sorts of measurements on harbor freight web site... what would these refer to?
Sorry for such cryptic info... spent hours and accomplished absolutely nothing so a little burnt out and crabby
Thank you
Questions:
Thank you
