Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
26 registered members (BLND1, 4WD, anndel, bbhero, ABCarr, 4 invisible), 849 guests, and 40 spiders.
Topics295,047
Posts4,926,745
Members66,672
Most Online2,553
Oct 27th, 2018
VW dealer oil filter install #4578332
11/18/17 08:16 PM
11/18/17 08:16 PM
virginia
sparky123 Offline OP
virginia
Yesterday I had to remove the plastic shield under my Golf because I needed to access my transmission pan and drain bolt. I decided I was going to do an oil/filter change. I've never personally changed out the filter myself on this car. I've always had the dealer change out the filter yearly when they did yearly state inspection. They would add the oil I brought it. (Then 6 mo. later I would change the oil myself but not change the oil filter.) Well...no longer! The oil filter canister was on so tight it was ridiculous. I thought for sure was cracked or would crack. It turned out the top o-ring was not installed! I would have thought this would be properly done! I'll be doing my own filter/oil changes from now on.
2012 VW Golf 2.5L Auto Pennzoil Euro 5w-40
2005 Ford ZX5 2.0L Auto
1999 Mazda Protege 1.6L Auto
Re: VW dealer oil filter install [Re: sparky123] #4578337
11/18/17 08:22 PM
11/18/17 08:22 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Dealer, independent shop, quick lane - it doesn't matter who it is, I'm checking everything soon after someone else has changed my oil.
But the last time that happened was 4 years ago, with the single free OC I got from the dealer where I bought my Cruze, so it kinda doesn't apply in the first place.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: VW dealer oil filter install [Re: sparky123] #4578348
11/18/17 08:36 PM
11/18/17 08:36 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I am thinking of purchasing the plastic oil filter cover , for our 1.8l Chevy Sonic , as a precaution . In case I mess it up .
And I can tell you the Sonic seeps oil down on the exhaust system if you are in a hurry or lazy about replacing the o-ring on the filter cover .
Maybe , not the first time , but it can happen . Sooner or later . They include a new o-ring with each new filter , for a reason .
Best of luck to you , :-)
Wyr
God bless
Re: VW dealer oil filter install [Re: sparky123] #4578456
11/18/17 10:30 PM
11/18/17 10:30 PM
PimTac Offline
PimTac  Offline
“If you want the job done right, do it yourself.”
Old adage that holds true today. It seems so many people have no pride in their work today. So much is done half-arsed or “that’s good enough.” “I wonder what this little black rubber ring is for?
Cannot see signatures any longer so it doesn’t matter.
Re: VW dealer oil filter install [Re: sparky123] #4578508
11/18/17 11:29 PM
11/18/17 11:29 PM
KS
FordBroncoVWJeta Offline
KS
I can't believe how stupid some people are in the auto industry. Ive worked on FCAs,GMs,KIAs, VWs, Volvos. Pretty much anything that ever came with a cartridge filter, and have NEVER forgot to put on the O ring. I'm 18, work at Walmart, and if I can do it, they can do it. WORK ON YOUR OWN STUFF PEOPLE.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2001 Pontiac Sunfire 2.2
Re: VW dealer oil filter install [Re: sparky123] #4578522
11/18/17 11:50 PM
11/18/17 11:50 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Sadly , I have made mistakes , working on my own stuff . :-(
Wyr
God bless
Re: VW dealer oil filter install [Re: sparky123] #4578607
11/19/17 06:37 AM
11/19/17 06:37 AM
South Central PA
Delta Offline
Delta  Offline
South Central PA
Top O-ring? The 2.5 only had one on the housing itself. People do tend to install them way too tight. I always used a torque wrench on mine and had the appropriate Hazet 2169 oil filter tool.
'17 VW GTI 2.0T - 6MT - 11K - Edge 0w40
'15 Camry SE - 2.5 - 22K - PP 0w20
'99 S10 - 2.2 5MT - 157K - PP 10w30
Re: VW dealer oil filter install [Re: sparky123] #4578612
11/19/17 06:54 AM
11/19/17 06:54 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Your 2.5 should only have the one big o-ring seal
I've also noticed that the housings come off and go on way differently too.
I torque mine, but sometimes coming off there's still that delicate moment where you think it's about to break.
"Zed's dead baby, Zed's dead."
Re: VW dealer oil filter install [Re: PimTac] #4578632
11/19/17 07:22 AM
11/19/17 07:22 AM
Orlando, FL
Mr Nice Offline
Mr Nice  Offline
Orlando, FL
Yep
Re: VW dealer oil filter install [Re: sparky123] #4578674
11/19/17 08:17 AM
11/19/17 08:17 AM
virginia
virginia
Sorry if my terminology is not correct. There's a seal inside the canister which you replace each time. (O.K that was there.) The oil filter comes w/two seals/rings/o-rings, whatever the're called. Then there's the seal/o-ring which goes on the threads on the oil filter housing. This is what was missing. So plastic to plastic contact on the top. There should been that seal on top.
Re: VW dealer oil filter install [Re: sparky123] #4578726
11/19/17 09:10 AM
11/19/17 09:10 AM
virginia
virginia
Oh boy....I may be wrong. There may only be the o-ring used inside the canister? But, the oil filter includes two o-rings. I assumed the other one goes the threads of the housing where the oil filter gets screwed into. Why would they included 2 large o-rings? Different applications perhaps. I put the second o-ring on the housing. Now there's plastic to gasket connect on top (Besides the contact inside.) Never done this before and there were no instructions. If I did this wrong please let me know. It just seems logical two seals would be better.
Re: VW dealer oil filter install [Re: sparky123] #4578736
11/19/17 09:16 AM
11/19/17 09:16 AM
South Central PA
Delta Offline
Delta  Offline
South Central PA
Only one o-ring in the canister as shown in this picture (found on Google, not my picture):
http://i48.tinypic.com/29pbwjd.jpg
Re: VW dealer oil filter install [Re: sparky123] #4578740
11/19/17 09:18 AM
11/19/17 09:18 AM
North Carolina
North Carolina
A picture would help. Probably too late now.
Normally if more than one large gasket is included with a cartridge it is for another, different application. If memory serves there is only one large gasket that goes into the plastic cap on the 2.5.
In any case, if it isn't leaking it's fine.
Re: VW dealer oil filter install [Re: sparky123] #4578743
11/19/17 09:20 AM
11/19/17 09:20 AM
virginia
virginia
Thank-you for the picture. I just assumed the another o-ring would housing threads so there would be canister/o-ring/housing contact on top. Just seemed logical. I'm learning. Thanks for all.
Re: VW dealer oil filter install [Re: sparky123] #4578750
11/19/17 09:27 AM
11/19/17 09:27 AM
virginia
virginia
I will definitely keep an eye out for any leaks. My apologies to VW if only one gasket is used but it was torqued WAY too tightly. I just barely got it off!
