Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
116 registered members (AandPDan, 1978elcamino, ABerns, 2015_PSD, 18 invisible), 2,369 guests, and 64 spiders.
Topics286,019
Posts4,900,954
Members67,548
Most Online2,967
Mar 10th, 2019
Getting a used 2013 Ford Edge (3.5), need help! #4578295
11/18/17 08:39 PM
11/18/17 08:39 PM
NJ
AntDeek Offline OP
AntDeek  Offline OP
NJ
Hey guys,
So next month I am receiving my dads 2013 Edge with the 3.5 Duratec with twin VCT. The car has 50,000 miles on it, and for its whole life, it has had a conventional oil and filter change whenever the oil life monitor said so. I know with the tiny oil passages in the VCT parts, its better to keep it clean and use a good oil to prevent buildup. In my garage I have some Motor Medic Synthetic engine flush. (Says safe for all engines, diesel or gas, turbo or NA) Its a 5 minute idle flush before a drain. Is this a good idea to clean up the motor before I switch over to a full syn oil?
I have 6 quarts of Castrol Edge Extended Performance 5w-20, and a purolator BOSS filter for this car. What is the general consensus about this engine oil and the boss filters?
Thanks a ton!
2013 Ford Edge - 3.5L V6 Ti-VCT
Mobil 1 Extended 5W-20 + Motorcraft FL-500S.
The best oil filter is a good air filter!
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578309
11/18/17 08:50 PM
11/18/17 08:50 PM
Vancouver, Canada
jaj Offline
jaj  Offline
Vancouver, Canada
I've got a 2015 Explorer with the 3.5 TiVCT engine like yours. I run it on Chevron Supreme 5w20 and it works great. It's not a highly stressed engine and it has a 6 quart sump, and that gives it plenty of capacity to go the full distance on the OLM.
The most important part of this engine to protect with regular oil changes is actually the timing chain. It's long and it runs the enclosed water pump, so staying with the recommended oil and change interval is important. That said, it won't need to be over-serviced either. You Castrol will work fine. The filter I'm not familiar with - I use Motorcraft filters from the dealer.
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578313
11/18/17 08:54 PM
11/18/17 08:54 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Did the oil and filter your Dad use , pass the Ford spec for this car ? If so , I would just switch to which ever quality oil & filter you prefer .
Our little Chevy Sonic is spec Dexos . I have always used Dexos spec synthetic and good filter , at 55% and 5% Oil Life Indicator .
So being old school , I change oil twice as often as GM is indicating . So , I would encourage frequent OCI . Purchase your oil & filters on sale . Cheap insurance .
Best of all to you , :-)
Wyr
God bless
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578316
11/18/17 08:56 PM
11/18/17 08:56 PM
PimTac Offline
PimTac  Offline
I would stay away from the flush. You could loosen up deposits that might cause trouble down the line. A better idea would be to run your Castrol Gold bottle right off and change it on a regular schedule. ( 5k or 7k) depending on your driving scenario. If more city than highway then go 5k. If mostly highway then 7k.
Cannot see signatures any longer so it doesn’t matter.
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578323
11/18/17 09:08 PM
11/18/17 09:08 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
The general consensus of Purolator Boss filters is that taking into account all their manufacturing defects, they are a risk to the vitality of your engine at worse and grossly overpriced at best.
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578328
11/18/17 09:13 PM
11/18/17 09:13 PM
NJ
AntDeek Offline OP
AntDeek  Offline OP
NJ
I work at an auto parts store so I can buy another filter. What filter would you recommend for it? Is the FL-500S good enough for full syn oils? And how do they compare filtration wise to the BOSS?
So no on the motor flush? I was under the assumption its "safe for every oil change" like it says on the bottle.
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578381
11/18/17 09:49 PM
11/18/17 09:49 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
"safe for every oil change" ?
Is that kind of like , " I will respect you in the morning " ?
Oil / filters are cheap , engines are expensive .
Best to you , :-)
Wyr
God bless
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578412
11/18/17 10:28 PM
11/18/17 10:28 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
If the engine is performing normally then I wouldn't use the flush. If you want to do anything do a couple of short changes with a quality synthetic and let it do a clean-up job of anything in the engine from the conventional.
Although with that engine it shouldn't need it.
grin2
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578450
11/18/17 11:25 PM
11/18/17 11:25 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Filter - Fram Ultra, Baldwin or WIX/Napa Gold smile
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578474
11/18/17 11:56 PM
11/18/17 11:56 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Follow these directions, carefully.
1. Drive the car for 14 miles, 50/50 city highway driving
2. During this drive do not let the RPMs rise above 3,700 RPMs
3. Upon returning, pull the car up on Rhino Ramps
4. Pop the hood and drain the oil into a drain pan, discard the filter
5. Replace with the recommended owner's manual viscosity oil and a new filter
6. Go get that bottle of engine flush
7. Take it and toss it in the trash
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578505
11/19/17 12:26 AM
11/19/17 12:26 AM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
Just the fact that you know the history of the vehicle puts you light years ahead of anyone that buys a used vehicle. The engine is still fairly young and Ford’s OLM is pretty good. Just put a good oil and filter on it and be happy.
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578584
11/19/17 06:20 AM
11/19/17 06:20 AM
Chadds Ford
Toros Offline
Toros  Offline
Chadds Ford
Originally Posted By: AntDeek
Hey guys,
Thanks a ton!
I have a 2009 Linclon MKX. I believe it has the same engine. Mine uses the same filter too. I have been finding Groupon from local service shops and dealerships for $25 oil changes. But will also do my own in warmer months. Any decent 5W-20 synthetic or synthetic blend, or even a quality conventional oil like Mobil or Chevron along with a Ford or NAPA or Wix filter and you are good to go for 5000 OCI. Mine is at 62K just now. I'm going to do a transmission drain and fill with Super Tech Mercon V and a cooling system flush in the next month.
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578622
11/19/17 08:11 AM
11/19/17 08:11 AM
Houston, TX
2015_PSD Online content
2015_PSD  Online Content
Houston, TX
I have the same engine in my 2014 Explorer. I run M1 AFE 0W-20 and FRAM Ultra XG10575 filters for 10K miles with zero issues. The iOLM is usually in the 6-10% range at that point.
Regarding the engine flush, I would ask if you know the engine is dirty or is this a preventative maintenance thing? I would skip the flush, switch to any synthetic and listen to the iOLM.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: AntDeek] #4578652
11/19/17 08:52 AM
11/19/17 08:52 AM
Texas
2009Edge Offline
2009Edge  Offline
Texas
I'm in the process of trading in my 2009 edge with 158,700 on the clock. I have used Amsoil 0W-20 since I got it with 5500 miles on it in 2009. It also has a bypass filtration system on it,which will come off before I trade it. Replacing it with a used 2017 Edge with 16'000 dealer certified. I will use Amsoil in it for the rest of its life. It amazes me that some people will spend a lot of money buying a car and then look for the cheapest oil they can find to use in it.
Re: Getting a used 2013 Ford Edge (3.5), need help! [Re: 2009Edge] #4578659
11/19/17 08:59 AM
11/19/17 08:59 AM
Chadds Ford
Toros Offline
Toros  Offline
Chadds Ford
Fact is you could use Walmart Super Tech conventional and you would be fine. You want to spend your money on more expensive oil when its not called for or needed...go for it.
