Fireworks Stores
by Warstud
5 minutes 30 seconds ago
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
14 minutes 56 seconds ago
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
23 minutes 49 seconds ago
How Fast to Run a ZeroTurn Mower
by Gebo
31 minutes 38 seconds ago
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
52 minutes 13 seconds ago
My FIL in hospice
by fdcg27
Today at 08:41 PM
Spraying Polyurethane
by Texican
Today at 08:37 PM
Dehumidifier icing
by Kestas
Today at 08:37 PM
Diesel lube in Petrol Engine
by Ducked
Today at 07:46 PM
New key programming cost
by 92saturnsl2
Today at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Today at 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
Today at 07:08 PM
Wheel says 50 mph max
by pda1122
Today at 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
Today at 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
Today at 06:36 PM
Old Engine SOUND
by MasterSolenoid
Today at 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
Today at 04:54 PM
go green or Dexcool?
by umungus1122
Today at 04:50 PM
Latest info on ExxonMobil synthetic base stocks
by Gokhan
Today at 04:49 PM
Pennzoil Platinum 5w30 - $3.21/qt Amazon
by SnowmanCO
Today at 04:37 PM
bcj, Ilia, nmac9, Theraven, battleman13
65279 Registered Users
109 registered (01rangerxl, 4WD, 87sammy, 97f150, 2003f7, 16 invisible), 1427 Guests and 57 Spiders online.
65279 Members
67 Forums
285679 Topics
Page 1 of 2 1 2 >
#4578220 - 11/18/17 06:19 PM Oil smell in the cabin of Acura??
thorromig Offline
Loc: BerksCounty/Pa.
My Acura in signature I noticed today with the heat on & car running while I went into a convenience store -- came out & the cabin smelt like oil smoke/burning oil? This is the first time I ever noticed this smell before & its not the first time I ran the heat or defroster this Fall neither. Car has no leaks that are visable -- wondering what & where this smell is coming from? Car uses no oil in between 7500 mile oil changes. There are no drops/drips in my garage or driveway what so ever.
00 Dodge Ram 5.2L 4x4 Edge 10W30 FU (91K)
08 Acura TL Type S 3.5L PUPP 5W20 FU (101K)
17 Jetta TSI SE 1.4L Turbo - Edge 0W40 FU (Hers) (4K)
#4578234 - 11/18/17 06:28 PM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
fdcg27 Offline
Loc: OH
This pretty well has to be an oil leak.
Check the oil filter base gasket as this is the most likely source of a sudden leak.
You can then see whether you have a valve cover leak, another solid possibility.
For your sake, I'd hope the former since swapping out the oil filter would be a whole lot easier than changing a valve cover gasket in the cold of late autumn.
17 Forester 12K MSS 0W-20
12 Accord LX 86K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
#4578269 - 11/18/17 07:02 PM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
NormanBuntz Online   content
Loc: Outer Banks, NC
Until you pinpoint the source of the leak, at least you can put the heater on recirculate to avoid the oil stink. How many miles on your TL?
2017 Honda Odyssey SE, 14K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 86K
2007 Infiniti M35, 104K
#4578282 - 11/18/17 07:19 PM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
TinyVoices Offline
Loc: Vienna, VA
Pcv valve on that motor?
I've had 2 cars pop the pcv valve out of the valve cover and it made an oil smell inside the car.
1993 Toyota MR2 Hardtop N/A - 157k miles - Valvoline Max Life 5w30
2006 Toyota Matrix XR AWD (Fiancee) - 126k miles - Valvoline Max Life 5w30
#4578283 - 11/18/17 07:20 PM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
Merkava_4 Offline
Loc: Clovis, CA
When the engine is cold again, run your finger along the bottom of the valve cover where it meets the cylinder head. Anything on your finger ? A very small oil leak might not produce smoke when it drips on something hot until the leak gets bigger.
#4578292 - 11/18/17 07:37 PM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
CR94 Offline
Loc: Western S.C. since 1996
Recent oil change? If so, oil may have been spilled where it seeps onto hot exhaust parts.
2011 Toyota Prius now at 88K
#4578340 - 11/18/17 08:28 PM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
WyrTwister Offline
Loc: Texas
I know just about nothing about an Acura . However , I can relate an oil smell experience we had on our Chevy Sonic 1.8l .
This engine has a " paper " cartridge oil filter with a black plastic oil filter cover & o-ring .
http://www.rockauto.com/info/690/PG5839__ra_p.jpg
http://www.rockauto.com/info/342/55593189_Alternate1__ra_p.jpg
Previous oil / filter change , I was in a hurry / lazy & did not change the o-ring . Shortly after that oil / filter change , we started to smell hot oil in the cabin . Oil was seeping from the filter cover , down onto the exhaust system .
Never dripped on the drive , that part of the oil system seems to only be under pressure while the engine is running .
Changed the filter / o-ring ( new o-ring comes with every filter ) . Sprayed the area down with cleaner . Replaced the rubber gasket on the oil drain plug when I drained it . Filled the engine with new Dexos spec synthetic oil , sprayed the oil pan and exhaust area with cleaner . Maybe , that took care of it .
So , in conclusion , I would start looking for a leal in the oil system . Did this start shortly after an oil / filter change ?
Best of luck to you all , :-)
Wyr
God bless
#4578364 - 11/18/17 08:42 PM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
dishdude Offline
Loc: Phoenix
Check all the PCV hoses.
2018 Challenger SRT
#4578513 - 11/18/17 11:35 PM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
JTK Online   content
Loc: Buffalo, NY
Sparkplug tube seals would be my guess if there's no visible oil leakage. Pretty common with higher mileage and rarely harmful.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
#4578529 - 11/19/17 12:05 AM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
ctechbob Online   content
Loc: Athens, GA
Don't forget to check the power steering hose that runs over the rear valve cover. There's a recall on them and it should have been replaced by now, but if not it will leak right over the rear header and potentially catch fire. You won't see any drips under the car also.
You'll know if it is the upgraded hose if there is a heat shield wire tied to the hose right near the clamp closest the firewall.
Edited by ctechbob (11/19/17 12:07 AM)
2008 Acura TL Type S - 140k
2003 Honda Accord V6 - 220k
2000 Honda Accord I4 - 300k
Current Oil - Milesyn SXR5W20/5W30
Current Filter - Partsmaster 61334
#4584385 - 11/25/17 10:47 AM Re: Oil smell in the cabin of Acura?? [Re: NormanBuntz]
thorromig Offline
The Acura currently has 101,326 miles on odometer. Its a beautiful sunny day here in my parts. Gonna put it up on the Rhino ramps & do a good inspection to clarify where the leak is coming from. Nothing to be seen from above.
Edited by thorromig (11/25/17 10:47 AM)
#4584391 - 11/25/17 10:51 AM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
gofast182 Offline
Loc: NJ
Our '11 MDX gets a burnt oil smell in the cabin on high(er) RPM acceleration, like merging onto a highway. It's most predominant after the car has been sitting or wasn't taken to above approx. 3.5K RPM in a while. If we're on a long trip, after several merges, it won't happen. PCV?
Edited by gofast182 (11/25/17 10:57 AM)
2006 S2000 - Berlina Black - PU 10w30, PCX-004
2017 340i xDrive - Black Sapphire - Dlr Fill, 114...898
2011 MDX Tech - Aspen White - Dlr Fill, PLM-A01
#4584411 - 11/25/17 11:25 AM Re: Oil smell in the cabin of Acura?? [Re: gofast182]
eyeofthetiger Offline
Loc: South Carolina
I'll take Valve Covers for $200, Alex. confused
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
#4584412 - 11/25/17 11:27 AM Re: Oil smell in the cabin of Acura?? [Re: gofast182]
JTK Online   content
Loc: Buffalo, NY
^ I wouldn't think PCV, given one of the purposes of that system is to prevent gasses from going straight to the atmosphere. I'd again guess at plug tube seals. Something else to consider could be drippage from a recent oil change or a little rear main seal seepage. I know our 2008 Honda Odyssey always had a little oil dampness at the bottom of the bell housing due to RMS seepage. The area was close to exhaust piping, so that's a possible cause of burning oil smell if things get really hot under there.
#4586786 - 11/27/17 04:19 PM Re: Oil smell in the cabin of Acura?? [Re: thorromig]
Tosh Offline
Loc: Silicon Valley
Prob something's weeping and getting burned on the exhaust. ATF?
Page 1 of 2 1 2 >
