White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
23 registered members (billt460, c502cid, Char Baby, DaleRider, 3 invisible), 797 guests, and 29 spiders.
Topics296,866
Posts4,960,386
Members66,982
Most Online2,688
Jan 19th, 2019
Ford EcoBoost Oil Spec #4578102
11/18/17 02:54 PM
11/18/17 02:54 PM
The Garden State
Whimsey Offline OP
Whimsey  Offline OP
The Garden State
We have a 2017 2.3 EB Explorer. The Ford oil spec is WSS-M2C-946-A. As far as I can tell the only properties needed to meet this is the oil have the API Star, The API Donut with API SN service, 5W-30 wt, energy conserving and also meet ILSAC GF-5. This encompasses just about every major brand 5W-30 oil whether conventional, synthetic blend or synthetic. It appears that synthetic 0W-30 oils meeting the above specs also meet the Ford specs. With the EcoBoost engines being DI and Turbo and "being able to go 10,000 miles" OCI's via their OLM's what makes this Ford oil spec good enough to go up to 10,000 miles using conventional or even synthetic blend oils? Personally I'm skeptical of this. This past Summer I did 7,000 miles highway driving in 2 months using Mobil 1 5W-30, I was at 30% oil life left. The wear metals were low, lots of life left in the oil, the flash point was still good but the viscosity was almost a 20 wt oil. Blackstone showed no measurable fuel in the oil. Although when I changed it there was fuel smell in the oil. It just seems that following Ford's oil requirements and using the OLM with conventional or even synthetic blend oil is not conducive to to long engine life. This is just my ramblings grin.
Whimsey
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4578104
11/18/17 03:04 PM
11/18/17 03:04 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
The Castrol Magnatec 5W30 semi-synthetic did very well in the Ford EB engine according to some great UOAs posted here. About 9,000 miles seemed to be the max distance on that oil, the iron wear was still good but the TBN was getting very low.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4578111
11/18/17 03:15 PM
11/18/17 03:15 PM
Georgia
MParr Offline
MParr  Offline
Georgia
Your Explorer came from the factory with 5W30 Motorcraft Synthetic Blend. I donít see a thing wrong with continuing with that oil or any other top shelf synthetic blend. I have chosen to run a synthetic 5W30 in my Ecoboost. I donít do extended oil changes or rely on the oil life monitor.
2013 KIA Optima EX 2.4L. Now: QSUD 5W30 & STP S2808ML
2017 Ford Escape SE 2.0T Now: Mobil 1 5W30 & NAPA Gold 1348
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4578114
11/18/17 03:16 PM
11/18/17 03:16 PM
Texas
4WD Offline
4WD  Offline
Texas
IMO Ö 7k is enough with an ecoboost Ö
Thatís all I put on the high priced M1 5w40 or better priced 0w40 Ö
Canít imagine those engines being on a 30 in other places Ö
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4578123
11/18/17 03:34 PM
11/18/17 03:34 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Yes I too have wondered about the Ford M2C-946-A spec, it seems to be the North American oil spec while the rest of the world gets the Ford WSS-M2C913-D spec for the same engines.
This Ford WSS-M2C913-D spec is based on the Euro ACEA A5/B5 spec with a few extra tests added for
- Greater TBN (>10)
- Ford Chain wear test
- Daimler Oxidation test
- ROBO test (Seq IIIGA)
- Extra seal tests.
All the oils I see with the Ford WSS-M2C913-D spec are high SAPS, high TBN and high zinc / Phos oil. Their Phos levels are so high that in North America they would not pass as SN or GF-5 and would have to be classed as API SL oils.
I think they contain a lot of ZDDP which acts as both an anti-wear agent and anti-oxidant. This probably help the oil pass the extra engine chain wear test and the extra oil oxidation resistance test. They are also typically right at the thin end of the 30 grade with their viscosity, but being A5/B5 it needs to pass a stay in grade shear stability test, which to me means they must be very well formulated to be a shear stable thin 30 grade.
I think Ford WSS-M2C913-D spec is the oil to use if not bound by ILSAC Phos limits.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4543378/
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4578125
11/18/17 03:47 PM
11/18/17 03:47 PM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
I too am concerned about fuel dilution in these EB motors, but I canít think of one UOA on the forum that Iíve read the past year that shows elevated wear metals. And most of the UOAís showed th oil thinned down into the 20w spec.
I honestly think Fordís OLM is pretty accurate. It does max out at 10,000 miles if you drive it easy. Mine was showing 10kmiles this summer when I was doing a lot of easy freeeway commutes. But in the winter months, it drops to around 6,500 with all my city driving and idling.
If you are worried, change the oil early. But with your low wear metals, I see no reason to go longer if you want to.
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: Ford EcoBoost Oil Spec [Re: MParr] #4578225
11/18/17 06:21 PM
11/18/17 06:21 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
18 Sportage 2.4L AWD:
Now: M1AP 5/20 + M1
Next: QSUD 5/30
13 Santa Fe Sport 2.0T:
Now: PPEuroL 5/30 + OEM
Next: EDGE 5/40
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4578230
11/18/17 06:26 PM
11/18/17 06:26 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
I have seen plenty of ecoboost drivers use valvoline conventional and go 10k miles between service (only using the oil life %). The cars are still on the road and they don't turn into horrible oil burners.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4578326
11/18/17 08:11 PM
11/18/17 08:11 PM
USA
slacktide_bitog Offline
USA
7k in two months usually means lots of highway miles, which are easier on oil. Now, if it took you a whole year to rack up 7k, that would be a different story smile
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4578329
11/18/17 08:14 PM
11/18/17 08:14 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Mind sharing the link ?
A mineral 5W30 Ford 946A with TBN 9.5-10 ish (thus carrying some ACEA AxBx specs) may be able to do >10,000 miles , not sure if one such oil is available though. blush
Re: Ford EcoBoost Oil Spec [Re: SR5] #4578335
11/18/17 08:19 PM
11/18/17 08:19 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
This semisyn is SN GF5 rated but not A3B4/A5B5 right ?
Any indication on its virgin/paper TBN as 9 and below ?
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4578414
11/18/17 09:30 PM
11/18/17 09:30 PM
Ohio
hallstevenson Offline
Ohio
How many miles did Blackstone say you could go next time ? You get an analysis, it shows good results, yet you question what Ford says while your results show that Ford probably knows what they're talking about....
Me thinks you wanted to smell fuel even when there was none....
Re: Ford EcoBoost Oil Spec [Re: zeng] #4578600
11/19/17 06:25 AM
11/19/17 06:25 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
It was the North American API SN & ILSAC GF-5 & Dexos1 (Gen1) stuff, Not the Australian A3/B4 stuff.
Here is a typical UOA for the iLSAC-Dexos Magnatec 5W30 semi-synthetic in a F150 Ecoboost:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3940342/
It's a very impressive UOA.
The oil is regular ILSAC-Dexos stuff, think TBN 7 to 8, Zinc 700 to 800 and Sulphated Ash at about 0.8%. As a rough guess of typical starting values.
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4579103
11/19/17 03:22 PM
11/19/17 03:22 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I would run a non-ilsac 10w-30. But that's just me. They seem to do well with just about any 5w-30
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Ford EcoBoost Oil Spec [Re: Whimsey] #4591012
12/01/17 12:57 PM
12/01/17 12:57 PM
FL
BeerCan Offline
BeerCan  Offline
FL
I think the dilution issue in the EB engines is overblown personally. I have had 3 of them (2 now) and all of them show fuel dilution but never have elevated wear metals.
I routinely go close to 10k miles on my fills with little issues. Both my 3.5's have UOA on this forum, I guess I should post some of my 2.3's results.
I will add that I personally don't trust Blackstone dilution numbers. I think Polaris is much more accurate.
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2015 Hyundai Genesis 5.0
2012 Hyundai Genesis 3.8
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1987 Porsche 944 Turbo
1967 Plymouth GTX 440
