130,000 miles and its changed every 20k. Going back to Wyoming,should I swap to Amsoil CVT / Redline. OEM is HCF2. Would like all the help from the car gods please.
Originally Posted By: JTK
If you've changed CVT fluid 6x at this point (every 20K miles), I'd think you're good as-is. 6x better than most.
I agree. Contaminates and wear metals drain out with the old fluid. Using fresh fluid is always a plus. I am not sure straying too far from the OEM fluid spec is required or helpful. Nor do I believe there will be much difference between brands that make compatible fluids. I think it would simply be a guess at this point. CVT's have some very interesting operational conditions. Honda's CVT is different than Nissan's and has a different fluid requirement. I don't think Redline's fluid is the right choice.
Originally Posted By: michaelluscher
Originally Posted By: Vlad_the_Russian
So... Let me get that straight... You got all those performance upgrades from your signature..on a CVT?...
I've done many similar mods on a 12 year old automatic Camry...
Beauty is in the eye of the beholder
Plus your wife can drive it since it doesn't have a manual transmission.
