2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
Comma X-Tech 5w30 oil, any good?
by BobGoblin. 12/17/18 11:40 AM
Modern Engine's Grenading?
by Nickdfresh. 12/17/18 11:15 AM
Magnetic Smartphone Holders
by willbur. 12/17/18 11:06 AM
1991 Caprice 5.0l hard starting in the AM
by WyrTwister. 12/17/18 10:55 AM
Question about new Peak OEM coolants
by PD001. 12/17/18 10:21 AM
Rev X
by Big_3_Only. 12/17/18 10:04 AM
Modern engines put less contaminants in the oil?
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
harvey_01, Gordon_Walter, MikeSheng, stantaur, Brandon9797
66703 Registered Users
95 registered members (aquariuscsm, Audios, AdditiveOCD, 5azzmonkey, 69GTX, 12 invisible), 2,139 guests, and 47 spiders.
Topics295,186
Posts4,929,434
Members66,703
Most Online2,553
Oct 27th, 2018
right bolts for wheel bearings? '14 Volt #4577182
11/17/17 02:42 PM
11/17/17 02:42 PM
Lima, Ohio, USA
earlyre Offline OP
earlyre  Offline OP
Lima, Ohio, USA
so my brother bought a used volt last summer, loves everything about it so far, except there is a definite vibration from somewhere, He thinks he's gotten it narrowed down to rear hub bearing, which he went ahead and bought the replacement part for. every source he's been able to find, Volt Forums, a copy of the FSM i managed to track down,etc, say the bolts that attach the bearing are one time use, to throw them away and replace with new, but there is no part number listed anywhere, no description of said bolts, and none came with the new bearings he ordered.
anyone familiar enough with this chassis(same parts for the cruze, same lack of bolts/identification.)
yes, he could remove one, and try to match it at a fastenal or similar, but, that would put the car out of commission in the mean time, and he'd like to have all the hardware on hand before starting the job.(super duh!)
anyone able to pass on some knowledge?
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
Re: right bolts for wheel bearings? '14 Volt [Re: earlyre] #4577193
11/17/17 03:05 PM
11/17/17 03:05 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
What does your local chevy dealer parts department say?
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 Maxlife Syn 5W30
06 GMC Sierra Nextgen 10W30
Re: right bolts for wheel bearings? '14 Volt [Re: earlyre] #4577208
11/17/17 03:21 PM
11/17/17 03:21 PM
Lima, Ohio, USA
earlyre Offline OP
earlyre  Offline OP
Lima, Ohio, USA
well of course he's not gotten around to actually calling anyone...
keeps reminding himself to call the Buick dealer he bought it from to see what they say, but never quite gets to it...
Mine:
Mine to Maintain:
Re: right bolts for wheel bearings? '14 Volt [Re: earlyre] #4577210
11/17/17 03:23 PM
11/17/17 03:23 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Is this the brother that had the Mustang and two Challengers from Texas? That's quite the difference in cars. smile
Re: right bolts for wheel bearings? '14 Volt [Re: SatinSilver] #4577217
11/17/17 03:30 PM
11/17/17 03:30 PM
Lima, Ohio, USA
earlyre Offline OP
earlyre  Offline OP
Lima, Ohio, USA
he never had 2 challengers concurrently....
had a 2013, sold it for an EB mustang that had a driveline vibration issue of it's own, when neither he or ford could find a reason for that vibration, he traded it in on a 2015 Chally.
Still has that Chally, 2007 Dakota, 98 Mustang, and the 2014 Volt.
almost convinced himself to let the Challenger go a couple times now(it has less than 3k mi on it still. put it in storage last winter, and it will probably be there before long for this winter)..
Mine:
Mine to Maintain:
Re: right bolts for wheel bearings? '14 Volt [Re: earlyre] #4577228
11/17/17 03:54 PM
11/17/17 03:54 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Take a bolt to Fastenal or Grainger, possibly a big Ace hardware. Get a real bolt this time. One that can be re-used.
Thick oil is better grin2
Re: right bolts for wheel bearings? '14 Volt [Re: earlyre] #4577250
11/17/17 04:27 PM
11/17/17 04:27 PM
MN
14Accent Offline
14Accent  Offline
MN
They're fine to re-use. Just torque to spec.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: right bolts for wheel bearings? '14 Volt [Re: earlyre] #4577285
11/17/17 05:12 PM
11/17/17 05:12 PM
ME
eljefino Offline
eljefino  Offline
ME
Looking at this image
it looks like your standard ordinary sealed wheel bearing like has been on other cars since the dawn of front wheel drive. Assuming 12mm lug studs the mounting holes should be "around" 10mm. But there are several thread pitches in that size. He should be able to take the naked part to a hardware store and test feel various bolts. Take note you want a very specific length so they don't protrude too far and catch the backside of something spinning, as well as OE or better grade.
I cannot imagine a reason for them to use torque-to-yield bolts except
1) it speeds up their assembly line by .01%
2) they can skip the loctite or
3) it's a made up rule to duck liability.
But it does hold the wheel on so I'm not telling an internet stranger it's ok to reuse without knowing the reasoning.
Re: right bolts for wheel bearings? '14 Volt [Re: earlyre] #4577288
11/17/17 05:15 PM
11/17/17 05:15 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
a car that new already needs a new wheel bearing? crzy
Re: right bolts for wheel bearings? '14 Volt [Re: earlyre] #4577314
11/17/17 05:34 PM
11/17/17 05:34 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Check for an updated axle nut torque spec when he does this job. Some GM models initially used 181 ft.lb and suffered premature hub bearing failure, they finally settled on 118 ft.lb and no more problem.
I cant say if the same is true with this model but do some research.
Re: right bolts for wheel bearings? '14 Volt [Re: Trav] #4577343
11/17/17 06:19 PM
11/17/17 06:19 PM
MN
14Accent Offline
14Accent  Offline
MN
It's a rear bearing. No axle nut to worry about.
Re: right bolts for wheel bearings? '14 Volt [Re: earlyre] #4577369
11/17/17 06:50 PM
11/17/17 06:50 PM
Santa Barbara, CA
bdcardinal Online content
bdcardinal  Online Content
Santa Barbara, CA
p/n 11588743 M10x1.5x55
Sometimes I can figure out the GM catalog. The pictures are weird for sure.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: right bolts for wheel bearings? '14 Volt [Re: 14Accent] #4577432
11/17/17 07:39 PM
11/17/17 07:39 PM
Trav Offline
Trav  Offline
I missed that but anyway something to keep in mind if the front goes.
Re: right bolts for wheel bearings? '14 Volt [Re: bdcardinal] #4577547
11/17/17 09:15 PM
11/17/17 09:15 PM
Lima, Ohio, USA
earlyre Offline OP
earlyre  Offline OP
Lima, Ohio, USA
thank you for a timely, intelligent response. some of these guys...
i don't care what the reason is, if the FSM tells me to not reuse a bolt, i'm not going to re-use it.
esp on one doing a rather critical job, keeping the wheel attached to the vehicle.....
Mine:
Mine to Maintain:
Re: right bolts for wheel bearings? '14 Volt [Re: earlyre] #4577551
11/17/17 09:19 PM
11/17/17 09:19 PM
Santa Barbara, CA
Santa Barbara, CA
I had to edit because I looked at the picture wrong and posted the p/n for the wheel studs. I have a GM catalog I can use at work, just never really use it and it is completely different from Ford and Mazda.
Pet peeve of mine when a part has required replacement hardware and you have to buy it separate. Volvo hubs came with new bolts. The rotors came with new Caliper bracket bolts and mounting bolts. With Ford you have to buy all the hardware on its own and usually in minimum quantities that the customer will never use all of.
