Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
83 registered members (Bud, 69Torino, bmod305, 53' Stude, BeerCan, 69GTX, 10 invisible), 1,630 guests, and 39 spiders.
Topics295,119
Posts4,928,054
Members66,688
Most Online2,553
Oct 27th, 2018
Page 1 of 4 1 2 3 4
Unwise to use X-30 where 5w-20 is specified? #4576717
11/17/17 06:30 AM
11/17/17 06:30 AM
EasTn
Sealbilly Offline OP
EasTn
Is it unwise to use 5w or 10w30 in a car that calls for 5w20 if it has high mileage like 225k? Honda element 2003 is starting to use a little oil. I have always used synthetic and changed at 5k. My other vehicles call for 5w30.
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576725
11/17/17 06:41 AM
11/17/17 06:41 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I doubt your engine would notice much change especially if synthetic.
2015 Ford F250 w/Powerstroke
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576727
11/17/17 06:41 AM
11/17/17 06:41 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I don't know if it's wise but I don't think it'll hurt in your situation.
Listen for clicking upon statrup....Winter is coming to eastern TN.
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576728
11/17/17 06:42 AM
11/17/17 06:42 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
It is wise.
In my ambients, I would've opted for an xW40.
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576730
11/17/17 06:44 AM
11/17/17 06:44 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
I don't think it will hurt a thing. 5w in your climate is more than adequate. Plus tolerances have loosened up a little over time.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram Ultra
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576742
11/17/17 07:08 AM
11/17/17 07:08 AM
New York
pbm Offline
pbm  Offline
New York
At 225K and using some oil, I'd use 5w30 in winter and 10w30 in summer. I don't see any problem doing so.
'Journalism is Dead'
Re: Unwise to use X-30 where 5w-20 is specified? [Re: ZZman] #4576745
11/17/17 07:09 AM
11/17/17 07:09 AM
EasTn
EasTn
That's what I was thinking but I wasn't sure.
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576746
11/17/17 07:10 AM
11/17/17 07:10 AM
EasTn
EasTn
Thank you gentlemen.
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576759
11/17/17 07:25 AM
11/17/17 07:25 AM
wv
krismoriah72 Offline
wv
My Honda Fit specs 0w20 but that is to hit the mpg ratings.. I have used 0w30, 5w20, 5w30 with no issue.
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576760
11/17/17 07:26 AM
11/17/17 07:26 AM
Russia
CajunNative Offline
CajunNative  Offline
Russia
I currently own a 2007 vehicle that is sped'd 5W20 oil. Back in 1997 when this engine was first produced it was spec'd 5W30. The engine was made from 1997-2008 without EVER changing tolerances or clearances.
In 1999-2000 for CAFE reasons ONLY, the manufacturer started to spec 5W20 for said engine to save gas mileage. The previous years' same engines were also back spec'd.
So, no, you don't HAVE TO use 5W20 in an engine spec'd 5W20.
BTW, I'm currently running 5W30 in my engine and sometimes 10W30.
A fox is a wolf who sends flowers!
Re: Unwise to use X-30 where 5w-20 is specified? [Re: pbm] #4576763
11/17/17 07:29 AM
11/17/17 07:29 AM
VA
Gebo Offline
Gebo  Offline
VA
I'm with him pbm....
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576779
11/17/17 07:46 AM
11/17/17 07:46 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I would have had it on 5w-30 when it went off warranty!
2004 Corolla 126813
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74478
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576782
11/17/17 07:48 AM
11/17/17 07:48 AM
NC
fenixguy Offline
fenixguy  Offline
NC
I'm currently using a 5-30 in the same engine as your Element. This is the first run of it (used 5-20 previously) and there is absolutely no difference in performance, mpg, or noise at startup. I decided to switch it and the '01 Civic to 5-30 so I only have to buy one grade. The current fill in the CR-V is Valvoline Synthetic with Maxlife Technology.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Kira] #4576797
11/17/17 07:59 AM
11/17/17 07:59 AM
Ottawa, Upper Kanuckistan
OldSparks Offline
OldSparks  Offline
I thought he was in Eastern Tunisia
Re: Unwise to use X-30 where 5w-20 is specified? [Re: Sealbilly] #4576810
11/17/17 08:14 AM
11/17/17 08:14 AM
Onondaga County
Miller88 Online content
Miller88  Online Content
Onondaga County
I'm running 5w-40 in a 220K mile 5.4 ford.
They really don't care all that much.
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Page 1 of 4 1 2 3 4
