Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
15 Grand Caravan
by zrxkawboy. 12/16/18 02:18 PM
Brandon9797, Landngroove, DanielH, Cpcz9382, PPWarrior
66699 Registered Users
98 registered members (2015Corolla, 2K2AcuraTL, AdditiveOCD, Anthony, 2003f7, 14 invisible), 2,027 guests, and 42 spiders.
Topics295,166
Posts4,928,983
Members66,699
Most Online2,553
Oct 27th, 2018
which is the better beta ratio? #4576631
11/16/17 10:52 PM
11/16/17 10:52 PM
South GA
wuntun Offline OP
wuntun  Offline OP
South GA
Looking at two different filters from wix for hydro-static tractor, I find one that is cross referenced from Donaldson, and another from crossing the oem part number. They are both the same in fitment, however, the beta ratio and micron ratings are different. Which filter would be the best? .....,,,,,,,,,...,,,,,.wix 51455 http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=61853 Part Number: 51455
UPC Number: 765809514553
Style: Spin-On Hydraulic Filter
Service: Hydraulic
Type: Full Flow
Media: Microglass
Height: 6.02 (153)*
Outer Diameter Top: 3.81 (97)*
Outer Diameter Bottom: Closed:
Thread Size: 1 3/8-12
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=4/10
Burst Pressure-PSI: 1000
Max Flow Rate: 24-28 GPM
Nominal Micron Rating: 10 ................,,,,,,,,,,,,,,,,,,,,...................,,,,,,,,,,,..........................,,,,,,,,,,,..................,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,................,,,,,,,,,,,,,,,,,,,...................,,,,,,,,,,,,,,,,,................ wix 51456 http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=61987 Part Number: 51456
UPC Number: 765809514560
Service: Hydraulic
Type: Full Flow
Media: Microglass
Height: 6.02 (153)*
Beta Ratio: 2/20/75=9/23/30
Nominal Micron Rating: 9
Wuntun
Re: which is the better beta ratio? [Re: wuntun] #4576669
11/17/17 01:45 AM
11/17/17 01:45 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Top one, 51455
Beta ratios work by dividing the minus one of itself with itself.
so a Beta 2 is
1/2=.5 or 50%
Beta 20 is
19/20=.95 or 95%
So knowing this we see that 51455 is 50% at 4 micron and 95% at 10 micron. Thats pretty good.
51456 is 50%@ 9 micron and 95%@ 23 micron. Additionally it shows 98.6%@ 30 micron.
Which is ok, but 51455 is clearly better at filtering.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: which is the better beta ratio? [Re: wuntun] #4576897
11/17/17 09:34 AM
11/17/17 09:34 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I wouldn't spend a lot of time over thinking this. No way you will ever be able to see benefits of picking one over the other. Make your choice and forget it.
Re: which is the better beta ratio? [Re: wuntun] #4576969
11/17/17 10:26 AM
11/17/17 10:26 AM
South GA
wuntun Offline OP
wuntun  Offline OP
South GA
Thanks for the informative replies. The 51455 is listed as my replacement on the wix website, but my supplier o'riellys shows the cross ref to a 51456, so ??? to the info. I now understand the beta you explained, thank you. And no, i really wasn't over thinking this, it's just the fact that they are a $60+ filter, and they are used for 400 hours. Want to go with the best one, and then stick with it.
Wuntun
Re: which is the better beta ratio? [Re: wuntun] #4576977
11/17/17 10:33 AM
11/17/17 10:33 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Darn, I thought we were going to talk stocks ...
