mower hard starting after sitting
Ceciltucky
I have 2 Briggs lawnmowers that are stored in a shed. The mowers often sit for 2 or 3 weeks between uses. I use stabilized E0 gas which is kept in Eagle safety cans. Even with all these precautions, I generally have to use a shot of starting ether to get the mower started. I have some back problems and pulling on the starter can be painful. After about 6 pulls I get frustrated and sore and reach for the ether. New spark plugs have not helped.
I wonder if the volatiles are evaporating from the gas in the carb? The mowers run perfect once they start.
Thanks in advance for any advice.
Could be the gas, old or water in the gas, especially if it's a metal tank. Also could be the carburetor, needs cleaning, preferably a dip tank. First drain the fuel bowl, then try it. If not try different gas. If you have a carb mounted gas tank then it's the diaphragm.
What are the engine numbers Tom ? I could probably figure it out if I had the engine numbers.
FastLane, I'd like to know how you came to the conclusion the carb takes a diaphragm without knowing the engine numbers. You must be psychic.
If you can prime the carb, how much do you prime it?
On my Tecumseh GTS 6.5 I give the primer bulb about 10 presses and it starts literally the first time every time.
A replacement OEM carb for your mowers may be in order. They are only about $20 nowadays and that tends to fix most issues all at once.
I discovered that my mower (Briggs & Stratton) starts on the first pull, every time, even after sitting all winter, if I press the primer bulb no less than a dozen times. (Sometimes it would start after pushing it 10 times, but sometimes it wouldn't.)
I use premium gas with stabilizer.
Sounds like the fuel is evaporating from the float bowl, which is hard to understand if there's fuel constantly being supplied from the tank? Unless the float needle is sticking in the closed position?
How do they start after being fired and run for a while? If OK, I'd look at the priming system. Something may have a hole or a crack in it. That happening on both at the same time seems unlikely though.
I also doubt very much that the carbs would have diaphragms. Never seen a diaphragm carb on a lawnmower.
Without knowing what type of carb system it has, we're just guessing, but the choke or primer system is essential for cold starting.
The low-end models that have the carburetor mounted directly on top of a small flat gas tank use a diaphragm. Instead of a bowl, they have a little pocket that holds fuel for immediate use. If that pocket has dried up from extended storage, you will need to pull the rope several times to refill it. The primer bulb draws from the pocket, so pressing it does nothing unless the rope has already been pulled several times.
Briggs & Stratton = hard starting. After using a Honda GCV-160, I don't know how B&S stays in business. Life is too short, Tom, to spend any of it yanking a bazillion times on a B&S small engine starter cord. Buy a Honda-powered mower for yourself for Xmas, and be happier. Will it to your children; it'll last and work like a Swiss watch for a long time with very basic maintenance.
Every Briggs lawnmower for 50 years has had a diaphragm. Only the new Briggs don't.
My friend and I just rebuilt a Briggs 2.5 hp that was built in 1966. You can still buy parts for it.
Switch to carb cleaner. Give it a pre-emptive spray before you even try to start it. Maybe give the gas a little MMO or B12 Chemtool. Yah since the mastectomy, I don't yank a starter so well either. Yes, using carb cleaner to start a mower shouldn't be necessary. But a little spritz will get it going faster and less painfully. I have learned to adapt my lack of strength to situations by slowing down the approach and planning out my moves. I'm slower,but I'm doing less damage to myself.
That's just the B&S. The longer it sits the harder it will be start with just the "normal" 3-5 pumps of the primer push-button. My B&S was starting just fine first pull all summer after sitting 1 week. Yet I ran it for the last time this week after sitting for 2 weeks in cold weather. It needed 2 pulls and a second prime. And the first start each season requires a number of pulls....though I'll try the recommendation above for 10-12 pumps next time.
Use fuel stabilizers/carb cleaner on each refill (Seafoam, Techron, Startron, Gumout, MMO, etc.). They will keep the carb from gumming up, making cold starts that much harder. My worst B&S ever required 10-20 pulls every time I ran it. So I feel for the abuse on our backs. One time I did 50 pulls before I finally tore the carb down to clean it....and that mower NEVER started again...lol. Ever since using fuel treatments I've never had to do more than a few pulls to start the B&S mower up after winter. Wish I had found Bitog years earlier.
