Fireworks Stores
by Warstud
9 minutes 39 seconds ago
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
19 minutes 5 seconds ago
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
27 minutes 58 seconds ago
How Fast to Run a ZeroTurn Mower
by Gebo
35 minutes 47 seconds ago
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
56 minutes 22 seconds ago
My FIL in hospice
by fdcg27
Today at 08:41 PM
Spraying Polyurethane
by Texican
Today at 08:37 PM
Dehumidifier icing
by Kestas
Today at 08:37 PM
Diesel lube in Petrol Engine
by Ducked
Today at 07:46 PM
New key programming cost
by 92saturnsl2
Today at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Today at 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
Today at 07:08 PM
Wheel says 50 mph max
by pda1122
Today at 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
Today at 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
Today at 06:36 PM
Old Engine SOUND
by MasterSolenoid
Today at 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
Today at 04:54 PM
go green or Dexcool?
by umungus1122
Today at 04:50 PM
Latest info on ExxonMobil synthetic base stocks
by Gokhan
Today at 04:49 PM
Pennzoil Platinum 5w30 - $3.21/qt Amazon
by SnowmanCO
Today at 04:37 PM
bcj, Ilia, nmac9, Theraven, battleman13
65279 Registered Users
108 registered (4WD, 01rangerxl, 87sammy, 97f150, 2003f7, 18 invisible), 1433 Guests and 55 Spiders online.
65279 Members
67 Forums
285679 Topics
Page 1 of 2 1 2 >
#4576485 - 11/16/17 07:51 PM mower hard starting after sitting
Oldtom Offline
Loc: Cecil County Maryland
I have 2 Briggs lawnmowers that are stored in a shed. The mowers often sit for 2 or 3 weeks between uses. I use stabilized E0 gas which is kept in Eagle safety cans. Even with all these precautions, I generally have to use a shot of starting ether to get the mower started. I have some back problems and pulling on the starter can be painful. After about 6 pulls I get frustrated and sore and reach for the ether. New spark plugs have not helped.
I wonder if the volatiles are evaporating from the gas in the carb? The mowers run perfect once they start.
Thanks in advance for any advice.
#4576498 - 11/16/17 08:00 PM Re: mower hard starting after sitting [Re: Oldtom]
FastLane Offline
Loc: MB - Manitoba
New carb diaphragm would be the next thing I would try.
2010 Silverado 4.8 4x4 Mobil 1 5W30 ACDelco PF48E
2002 Mustang GT 4.6 Mobil 1 5W30 MC FL-820S
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Merc 10W30
#4576506 - 11/16/17 08:04 PM Re: mower hard starting after sitting [Re: Oldtom]
JLawrence08648 Offline
Loc: NJ
Could be the gas, old or water in the gas, especially if it's a metal tank. Also could be the carburetor, needs cleaning, preferably a dip tank. First drain the fuel bowl, then try it. If not try different gas. If you have a carb mounted gas tank then it's the diaphragm.
#4576516 - 11/16/17 08:15 PM Re: mower hard starting after sitting [Re: Oldtom]
Merkava_4 Offline
Loc: Clovis, CA
What are the engine numbers Tom ? I could probably figure it out if I had the engine numbers.
FastLane, I'd like to know how you came to the conclusion the carb takes a diaphragm without knowing the engine numbers. You must be psychic.
#4576557 - 11/16/17 08:53 PM Re: mower hard starting after sitting [Re: Oldtom]
Oil_Flunky Online   content
Loc: Michigan
I've had that with the small engines at my cabin. One ounce per gallon of Gum Out All In One fixed it.
Oil, you need it. Oil snobbery, you don't need it.
#4576558 - 11/16/17 08:54 PM Re: mower hard starting after sitting [Re: Oldtom]
Reddy45 Offline
Loc: USA
If you can prime the carb, how much do you prime it?
On my Tecumseh GTS 6.5 I give the primer bulb about 10 presses and it starts literally the first time every time.
A replacement OEM carb for your mowers may be in order. They are only about $20 nowadays and that tends to fix most issues all at once.
#4576571 - 11/16/17 09:08 PM Re: mower hard starting after sitting [Re: Oldtom]
JohnnyJohnson Online   content
Loc: Wet side WA
Empty the tank get new fresh premium gas and give it a shot of Seafoam!
Check the plug for fouling.
Edited by JohnnyJohnson (11/16/17 09:11 PM)
2004 Toyota Corolla 121682
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4576616 - 11/16/17 10:08 PM Re: mower hard starting after sitting [Re: Oldtom]
Uphill_Both_Ways Offline
Loc: Winnipeg
I discovered that my mower (Briggs & Stratton) starts on the first pull, every time, even after sitting all winter, if I press the primer bulb no less than a dozen times. (Sometimes it would start after pushing it 10 times, but sometimes it wouldn't.)
I use premium gas with stabilizer.
2008 Impala 3.5
#4576775 - 11/17/17 07:42 AM Re: mower hard starting after sitting [Re: Oldtom]
boraticus Offline
Loc: Canada
Sounds like the fuel is evaporating from the float bowl, which is hard to understand if there's fuel constantly being supplied from the tank? Unless the float needle is sticking in the closed position?
How do they start after being fired and run for a while? If OK, I'd look at the priming system. Something may have a hole or a crack in it. That happening on both at the same time seems unlikely though.
I also doubt very much that the carbs would have diaphragms. Never seen a diaphragm carb on a lawnmower.
#4576777 - 11/17/17 07:43 AM Re: mower hard starting after sitting [Re: Oldtom]
mk378 Offline
Loc: USA
Without knowing what type of carb system it has, we're just guessing, but the choke or primer system is essential for cold starting.
#4576781 - 11/17/17 07:46 AM Re: mower hard starting after sitting [Re: boraticus]
mk378 Offline
Loc: USA
The low-end models that have the carburetor mounted directly on top of a small flat gas tank use a diaphragm. Instead of a bowl, they have a little pocket that holds fuel for immediate use. If that pocket has dried up from extended storage, you will need to pull the rope several times to refill it. The primer bulb draws from the pocket, so pressing it does nothing unless the rope has already been pulled several times.
#4576886 - 11/17/17 09:23 AM Re: mower hard starting after sitting [Re: mk378]
khittner Offline
Loc: Michigan
Briggs & Stratton = hard starting. After using a Honda GCV-160, I don't know how B&S stays in business. Life is too short, Tom, to spend any of it yanking a bazillion times on a B&S small engine starter cord. Buy a Honda-powered mower for yourself for Xmas, and be happier. Will it to your children; it'll last and work like a Swiss watch for a long time with very basic maintenance.
#4576950 - 11/17/17 10:14 AM Re: mower hard starting after sitting [Re: boraticus]
FastLane Offline
Loc: MB - Manitoba
Every Briggs lawnmower for 50 years has had a diaphragm. Only the new Briggs don't.
My friend and I just rebuilt a Briggs 2.5 hp that was built in 1966. You can still buy parts for it.
Edited by FastLane (11/17/17 10:15 AM)
#4576975 - 11/17/17 10:33 AM Re: mower hard starting after sitting [Re: Oldtom]
andyd Online   content
Loc: Marshfield , MA
Switch to carb cleaner. Give it a pre-emptive spray before you even try to start it. Maybe give the gas a little MMO or B12 Chemtool. Yah since the mastectomy, I don't yank a starter so well either. Yes, using carb cleaner to start a mower shouldn't be necessary. But a little spritz will get it going faster and less painfully. I have learned to adapt my lack of strength to situations by slowing down the approach and planning out my moves. I'm slower,but I'm doing less damage to myself. grin2
Thick oil is better grin2
#4576976 - 11/17/17 10:33 AM Re: mower hard starting after sitting [Re: khittner]
69GTX Offline
Loc: Connecticut
That's just the B&S. The longer it sits the harder it will be start with just the "normal" 3-5 pumps of the primer push-button. My B&S was starting just fine first pull all summer after sitting 1 week. Yet I ran it for the last time this week after sitting for 2 weeks in cold weather. It needed 2 pulls and a second prime. And the first start each season requires a number of pulls....though I'll try the recommendation above for 10-12 pumps next time.
Use fuel stabilizers/carb cleaner on each refill (Seafoam, Techron, Startron, Gumout, MMO, etc.). They will keep the carb from gumming up, making cold starts that much harder. My worst B&S ever required 10-20 pulls every time I ran it. So I feel for the abuse on our backs. One time I did 50 pulls before I finally tore the carb down to clean it....and that mower NEVER started again...lol. Ever since using fuel treatments I've never had to do more than a few pulls to start the B&S mower up after winter. Wish I had found Bitog years earlier.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Page 1 of 2 1 2 >
