B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
100 registered members (240_Ed, aquariuscsm, AdditiveOCD, Arob, 11 invisible), 2,327 guests, and 46 spiders.
Topics296,878
Posts4,960,710
Members66,987
Most Online2,688
Jan 19th, 2019
Is TURBO POWER All Season Anti-Freeze any good? #4576321
11/16/17 05:07 PM
11/16/17 05:07 PM
Michigan
phogstenjr Offline OP
Michigan
2004 Grand Prix
This spring I flushed all the Dexcool coolant, changed the water pump, installed a 180 degree thermostat and ran just distilled water, Redline water wetter, & Peak 14.5oz Anti Rust, Sealer And Protector for the summer and fall.
Just before the freezing temps set in I installed a 195 degree thermostat & added 2 gallons of TURBO POWER All Season Anti-Freeze & Coolant Concentrate (green in color ) to my cooling system. $7 gallon after rebate;
Part #: 86-244PRO|
SKU: 457523
All Season Antifreeze/Coolant is a superior quality ethylene glycol based engine coolant with a low silicate corrosion inhibitor package. This product protects coolant system metals, including heat-rejecting aluminum, against pitting caused by cavitation and corrosion. It provides exceptional cooling in summer and excellent protection against freezing in the winter. It is recommended for use in older model domestic and foreign cars and light duty trucks and will provide up to 50,000 miles or 2 years service life when installed as initial fill, or after a complete flush and cleaning of a cooling system in reasonable condition. It is compatible with supplemental coolant additives (SCA) and coolant filters and thus can be used in heavy duty diesel coolant systems when pre-charged with SCA.◦Protects against winter freezing and summer boil over
◦Prevents pitting caused by cavitation and corrosion of brass, copper, solder, steel, cast iron and aluminum
◦Low silicate
◦Aluminum compatible
Re: Is TURBO POWER All Season Anti-Freeze any good? [Re: phogstenjr] #4576346
11/16/17 05:26 PM
11/16/17 05:26 PM
Reno, NV
redbone3 Offline
redbone3  Offline
Reno, NV
Old school coolant. Works fine.
2014 Passat Wolfsburg, 1995 Miata.
Re: Is TURBO POWER All Season Anti-Freeze any good? [Re: phogstenjr] #4576447
11/16/17 07:28 PM
11/16/17 07:28 PM
Albany NY
ted s Offline
ted s  Offline
Albany NY
WHAT WAS POINT OF RUNNING JUST WATER
Re: Is TURBO POWER All Season Anti-Freeze any good? [Re: phogstenjr] #4576884
11/17/17 09:23 AM
11/17/17 09:23 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
probably fine. Wouldn't sweat it on an older vehicle as long as the dex was very well flushed out. Why run the water wetter and other junk? Besides MAYBE the bars leaks crushed walnut tabs I would stick with what it is supposed to have.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
