European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
30 registered members (Black_Thunder, 2015Corolla, avi1777, Bjornviken, ctechbob, craigq, 5 invisible), 402 guests, and 35 spiders.
Topics290,967
Posts4,853,503
Members66,063
Most Online3,590
Jan 24th, 2017
Run engine without filter ? #4575660
11/16/17 03:11 AM
11/16/17 03:11 AM
Clovis, CA
Merkava_4 Offline OP
Clovis, CA
Say if a guy has an engine with a cartridge filter and he's complaining about ticking on a cold startup, can he pull the filter and run the engine without it momentarily to see if the filter is causing the ticking ?
Re: Run engine without filter ? [Re: Merkava_4] #4575661
11/16/17 03:15 AM
11/16/17 03:15 AM
USA
oldhp Offline
oldhp  Offline
USA
I would say only if the filter does not have the round thing sticking out. That pushes on (I think) a check valve for oil flow. Now you could take a used filter and cut off the media and insert the left over cage and try it. cheers
Re: Run engine without filter ? [Re: oldhp] #4575699
11/16/17 06:33 AM
11/16/17 06:33 AM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Wouldn't that cause a big mess?
I wouldn't try this on my own vehicle.
2015 Grand Caravan SXT Plus 5w-20 PPPP/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Run engine without filter ? [Re: JC1] #4575725
11/16/17 07:30 AM
11/16/17 07:30 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
Cartridge filters have a housing the cartridge goes in so it wouldn't cause a mess because it seals with or without a filter in there. thumbsup
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Run engine without filter ? [Re: Merkava_4] #4575742
11/16/17 08:15 AM
11/16/17 08:15 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Remember that any contaminants in the bottom of the housing will not get filtered out. I am sure some fast lube has left a filter out.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Run engine without filter ? [Re: Chris142] #4575776
11/16/17 09:03 AM
11/16/17 09:03 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
More likely it doesnít get changed because they canít find the thing under the engine.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Run engine without filter ? [Re: Merkava_4] #4575812
11/16/17 09:43 AM
11/16/17 09:43 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
That's a moot point as you will need a filter.
Just try another brand.
I like the reasoning to an extent though.
No high efficiency media and you should be OK.
Maybe you have engine assy form-a-gasket permatex clogging up the pickup screen?
If that's far fetched, You could try QSUD 10w30 non dexos. Smoothest stuff on the planet other than the old QS HM redbottle if your ride is a 30 grader.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Run engine without filter ? [Re: Merkava_4] #4575853
11/16/17 10:21 AM
11/16/17 10:21 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Just think of all the purolators.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 100K Napa 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 20K VR1 20w50, NG1515
14 RX450h 33k PP MIX, NG7047
Re: Run engine without filter ? [Re: JC1] #4575912
11/16/17 11:25 AM
11/16/17 11:25 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
At least not in your own driveway or garage.
2004 Corolla 124831
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Run engine without filter ? [Re: Dyusik] #4576002
11/16/17 12:49 PM
11/16/17 12:49 PM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
LOL Here we go...
Re: Run engine without filter ? [Re: Dyusik] #4576040
11/16/17 01:39 PM
11/16/17 01:39 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Even with a small tear,
they are still filtering well over 90% of the rest of the oil flow.
Re: Run engine without filter ? [Re: Merkava_4] #4576046
11/16/17 01:48 PM
11/16/17 01:48 PM
Tennessee
FlyingVan Offline
FlyingVan  Offline
Tennessee
I personally would not do it. A friend of mine has a VW Passat with I believe a 1.8 or 2.0 turbo engine. His turbo failed. He replaced the turbo and did an oil change and found that there was no oil filter. Someone changed the oil and didn't put a filter in. I would have at least put the old filter in instead of no filter. Coincidence? I don't think so. While a tear of the filter here and there wont do too much damage, no filter at all is no good in my book.
2017 Volkswagen Jetta 1.4TSI, 30k
2016 Volkswagen Jetta 1.4TSI, 30k
2011 Volkswagen Jetta Sportwagen TDI, 90k
2004 Dodge Sprinter 2.7 5cyl diesel,774k
Re: Run engine without filter ? [Re: Merkava_4] #4576106
11/16/17 02:42 PM
11/16/17 02:42 PM
Margate England
Claud Offline
Claud  Offline
Margate England
Air cooled Volkswagens and Fiat twin cylinder engines just had a strainer on the pickup on many models. If your engine is in great shape perhaps it won't need a filter.
But do you want to take the risk?. Try swapping the filter for a premium Fram or other high quality make. If the filter has an anti drain back valve you won't have any oil pressure at all until the filter body fills up.
Claud.
Re: Run engine without filter ? [Re: Merkava_4] #4576163
11/16/17 03:43 PM
11/16/17 03:43 PM
Western S.C. since 1996
CR94 Offline
CR94  Offline
Yes, he could, without causing any major problem (assuming no grit leftover in the housing), at least on the kind of cartridges I've seen. However, that exercise would be a waste of time and oil, because the cartridge can't cause ticking, unless it's plugged, and then he'd have worse problems.
2011 Toyota Prius now at 92K
